Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
The mower runs fine till you engage the blades then it goes dead
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly. Take a look at the pedal switch wiring. Also check the foot switch to make sure it is NOT grounding when you ease the pedal to it's normal resting position. This is the most common problem however..... Underneath in the clutch area make sure that the clutch wires are not grounded. There is a diode in the PTO clutch and if the diode fails it will present this symptom. Read the Black to Purple stripe wire on the clutch in BOTH directions. One way it should read open the other way it should read like a wire. Most of the time it the blade is engaging and the mower dies it is either the foot switch or a wire in the PTO Clutch area that is grounded.
Thanks for choosing FixYa,
Kelly
Posted on Apr 07, 2011
  • Kelly
    Kelly Apr 09, 2011
    I responded without being provided a model number. If you can locate or provide both a mower model number and an engine number I can locate diagrams to help you. Without a model number it forces me to respond in generic form that does not always result in a customer fixing the problem. From the rating it appears you still have the problem.
    Kelly
  • Kelly
    Kelly Apr 09, 2011
    When you say it goes dead... dead as in like you switched off the ignition or like it is not getting enough fuel? I am just guessing that this is an LT2000 model mower with a model number of 917.276813
    Using this Diagram:
    http://www.searspartsdirect.com/partsdir...
    2 things have to happen to get blade engaement and the engine running.
    1. The seat must be occupied
    2. The clutch brake pedal must be up.
    Power is routed from terminal M on the ignition switch to the black wire (in) on the pedal switch and the Gray wire (out) of the pedal switch. From there it goes to the gray wires on the seat switch (in & out) and then on to ground.
    To get blade engagement you must have Power to the black wires of the clutch (in and out) and Black to black on the seat switch with the sear occupied. The black wire OUT of the seat switch is a ground.
    ANY ground on the black wire coming from M on the ignition switch will kill the ignition. That ground can come from any of the following places. Pedal Switch, Blade clutch, or the seat swtich or the connecting wires to any of the swtiches.
    Kelly
2 Suggested Answers
  • 18 Answers
SOURCE: mower boggs down when blades are engaged
If all pulleys are turning (not bound up) check for belt route misalignment.
Posted on Jun 06, 2010
Mower won't start unless solenoid is arced
If it acts like the blades are engaged, try tracing the wires to see where they are shorted out, start by disconnecting the wires from the switch. You may need a new switch
May 08, 2016 | Light Garden
My john deere keeps shutting down when I try to engage the mower blades.
well first off be sure the throttle is all the way up secondly check to be sure the blads turn freely could be the belt is pinched or off one of the pullies and causeing to much friction for the motor to turn it
May 04, 2014 | John Deere Garden
Have a 1540 zero turn. runs fine till you engage the electric clutch to mow.backfires and won't run right. runs fine when you shut of mower blade drive
the electric clutch sometimes jumps of the steel retention dowl. That then pulls the wires and stops the motor. You will need to remove the clutch and reposition it over the dowl. You will also need to re-fit the electric connections. Watch out for the fuse as this will often blow.
Sep 04, 2013 | Ariens Garden
Husqvarna pto problem(?) disengaged blades to travel, would not engage after. Battery dead when checked after shutting off engine and wouldn't restart
Hi, first charge or replace the battery if necessary then check that the mower is charging the battery. The pto is probably fine but it needs battery voltage to engage. If the mower has stopped charging the battery may have had enough voltage to hold the pto in until you disengaged it but not enough to re engage it. Regards Phil.
Sep 06, 2012 | Garden
Electric blade clutch won't work and battery went dead
If you have a new battery and it went dead that quickly I would check the charging system on the mower engine. Many of them use a voltage regulator and if it goes bad it will not properly charge the battery. Get the engine running (do not engage the PTO) and use a multimeter set on DC voltage. Place the multimeter leads on the battery and you should see approximately 13-14 volts DC at the battery terminals when it is running. If less then that then it's a problem with the charging system and further tests would be needed to figure out if it is a bad regulator or charging coil.
Aug 23, 2012 | Husqvarna Garden
Craftsman ZTS 7500 dies when engage blades or when engage transmission
check the "kill switch" they are usually located in the seating area. it senses for pressure or seat angle and will kill the mower if nobody is sitting on the mower. Good Luck
Apr 17, 2012 | Craftsman Garden
Mower boggs down when blades are engaged
Jun 06, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
May 14, 2009 | Mtd Garden
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
563 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
