Question about Sony Computers & Internet
Thanks, the screen does not fill the monitor after I added "optimize msn with Bing"- I checked the Apperance/setting to the 17 " standard but black margins and I do not know how to work with the side button. And the margin on the top screen is too small- stuff is nipped off, after 3 wasted hours with Dell, i am doing much better now, but need to do that adjustment. THANK YOU
    Scholar:
  • 72 Answers
Dude just use the monitor on screen adjustments to center and size your screen...
Posted on Apr 07, 2011
I have an acer al1716 monitor and since 2 weeks ago on the screen apears a box with the " input not suppported" message, then the pc shuts down. i may have changed the resolution settings and now...
the video settings on your computer has changed to a setting that the monitor doesn't like! try entering your computer in safe mod and change the setting to a max of 1024x768. however, if your video card has a dual output and you have 2 monitors connected at the same time then this is your problem. make sure that the 17" lcd is monitor 1 and the other monitor #2. one of the monitors is set higher the the 17" lcd and when it is not connected the computer may think this the setting for the 17" lcd and not the other monitor which may be hdmi or 1900x1080 which the 17" cannot read this it is out of range!
Aug 24, 2011 | Acer AL1716 17" LCD Monitor
I have a 24 "
First check to see if you have the correct graphic card drivers installed.
Then change the resolution. In some monitors, if the resolution is set too low, you get the condition you describe. The system thinks it's sending to a smaller monitor.
Jul 21, 2011 | AOC Monitor
Faulty monitor ctx pv720a. The screen has the
Try another cable, or check the plug for bent pins. If they are all good, check that the monitor is set for VGA input (if it supports VGA and DVI) as it may be looking for a different input. Then replace the monitor. It's not common, but video processing circuitry can sometimes fail, and yours may have. New 17-inch LCD monitors are quite inexpensive now, so it would probably be more economical to replace this one than to try repairing it.
Jan 01, 2011 | CTX PV 720 17" LCD Monitor
How to stop IE8 from hijacking my homepage settings? Every day when I boot my computer and run IE it has changed my home page to MSN and Bing. I change my home page back to Google and the next day MSN and...
Uninstall "Bing" search engine from "Add/Remove". Then Reset your IE8 back to default settings from the IE 'Tools' ->"Internet Options". Then in the "General" set your homepage back to Google and click OK. Resart your IE8.
If it doen't work, download this utility "HijackThis" run and delete the IE start page, and perform the above again.
Hope it helps.
Oct 18, 2010 | Microsoft Internet Explorer 8
Webpage error details User Agent: Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.0; Trident/4.0; GTB6; SLCC1; .NET CLR 2.0.50727; Media Center PC 5.0; .NET CLR 3.5.30729; .NET CLR 3.0.30729;...
Have any toolbars or new sofware been added recently? If so and you are using Win XP you may want to try a system restore to a previous point before the changes were made or uninstall the toolbars completely. Also disabled all Pop-Up blockers to see if that has any effect.clean up ur registry using reginout
Sep 23, 2010 | Microsoft Internet Explorer 8
After installing windows vista and adding graphics driver screen shrunk
Go to Start > Control Panel > Personalization >Display Settings.
Adjust your resolution down which will fill the screen.
Each time you adjust it, it will show you what the screen will look like and you will have the opportunity to save that setting or revert.
Nov 05, 2009 | LG Flatron L1715S 17" LCD Monitor
The menu constantly pops-up on my Samsung 17 inch LDC monitor
what does the pop up menu say? I'm guessing it says something like "Optimal settings are 1280x1024, Press 1 to confirm, press 2 to disable". If the message is anything like this, your monitor is trying to tell you that your display settings are less than optimal. You can either disable the message by "pressing 2" or changing your display settings to the recommended resolution. If the menu you're getting is just the control panel and there's no actual message, leave your computer on, reach around the back and disconnect the power cable from the monitor, wait 5 seconds and plug it back in. Samsung monitors sometimes have a glitch and need to be reset.
May 13, 2009 | Samsung SyncMaster 173V 17" Flat Panel LCD...
It saysmy pc video resolution is out of range
to chabge resolution go to click start
control panel
apperance and themes
display
settings
and down towards lower left hand you'll see screen resolution
then move bar to 1024*768
Mark
Apr 11, 2009 | Samsung 710V 17" LCD Monitor
Samsung SyncMaster 710N 17 in. Flat
hi
I am a technician-informatic. I have repaired about 40 Lcd Samsung monitors with thees problems - not optimal resolution mode and dark screen problem. So i decided to made manual how to repair lcd samsung monitors.The repair process is very simple 10-30min. does not need a lot of experience in electronics and expensive instruments.
if you are interested check it on eBay.
Samsung monitor repair manual guide 710n,913v,510n more
or just enter number in search field: 220409788372
thank you
Oct 29, 2007 | Samsung SyncMaster 710N 17 in. Flat Panel...
Computers & Internet Logo
173 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
