Question about Sta Rite Sr333lp - Max E Therm - Pool & Spa Heater - Dual Electronic Iginition Lo - Nox - 333,000 Btu - Propane Gas
I have a Sta-Rite heater, model #SR333LP the heater shows an error message EO1 and will not run. The factory technician I spoke to advised me that I need a temperature sensor. What is the part number for the temperature sensor and is it difficult to install. Thank you.
PartsCenter
  • 125 Answers
SOURCE: Pool heater not working
sounds like it is not getting enough water flow. Check to see that there is water going out of the heater. Here is a site you can check trouble shooting guide.
Posted on Feb 26, 2009
PartsCenter
  • 125 Answers
SOURCE: sta-rite heater Display shows 125 degrees, won't activate heater
sounds like the temp sensor is bad. Sta-rite Heater
  • 83 Answers
SOURCE: sta rite 400na gives error code 05 after about 30 seconds
I am not sure if you have received an answer to the issue, or not, but just in case! An EO5 error code is an open stack flue sensor, or switch, There are two forms of the stack flue sensor, so you will need to know which one you have on the heater.
What this error code means is that the sensor "read" the flue temp to be over 500 degrees. Usually, it is just gone bad and reading the wrong temp.
Posted on Jul 14, 2009
  • 990 Answers
SOURCE: Sta-rite pool heater shuts down as soon as the
Between the two water pipes on the left side of the manifold is a two inch plug. When you take this plug out the thermal regulator assembly will come with it.It consists of "O" rings, a spring and what looks like a thermostat in a car. This is the probal bad part although it could be the spring also. You can get these parts seperatly or in a kit. If this is an older heater the kit is the way to go so you get all the nessary "O" rings and you will be covered on everything you need.
Posted on Dec 08, 2009
  • 3 Answers
SOURCE: sta-rite spa heater records wrong temperature
The problem most likely. Is that the temp sensor in the heater is faulty.The temperature sensor is located on the in/out water connection header on side of heater. More information is needed to be 100% sure. But, due to the complexity of those heaters it is recommended that you find a qualified service company to diagnose and repair the heater. Not recommended to repair yourself.
Posted on Sep 30, 2011
SR333LP pool heater continuously cycles ON/OFF, the fan stays on
The age and over all condition of the heater would help. Try removing the Thermal Reg and see if it smooths out. If the heater responds, replace the Thermal Reg with a new one.
Jun 11, 2017 | Sta Rite Sta-Rite Max-E-Therm High...
Heater wont start has code EO1 model SP 400LP
eo1 is a thermistor failure. problem is either with temp sensor, wiring from thermistor to circ board, or the circ board itself
Jun 13, 2014 | Sta Rite Sta-Rite Max-E-Therm High...
SR333LP turns on but does not heat
hot surface igniter may not be getting hot enough to ignite the gas
Jun 05, 2013 | Sta Rite Starite 333 Btu Propane Gas...
My Sta Rite SR333LP Pool Heater is leaking by the inlet valve area
check gas pressure if low it over heated if ok heat exchange is going check chemistry
Mar 25, 2013 | Sta Rite Pool & Spa
E01 message when we attempt to turn on pool heater
These pool heaters have a great troubleshooting section in the users manual (link below). Try walking through that step by step. It should help you correct your problem in no time.
http://www.backyardcitypools.com/images/bwp/Max-E-Therm-Manual.pdf
Jun 04, 2010 | Sta Rite Sta-Rite Max-E-Therm High...
Pool heater on but not heating
Here is a manual that will help you troubleshoot.
Run the diagnostic tests pages 15 - 16 and then see pages 17 and 18 for troubleshooting flow chart.
http://www.starite.com/pdf/S5600PS(2-8-01).pdf
Kelly
Feb 22, 2010 | Sta Rite Sr333lp - Max E Therm - Pool &...
The EO1 signal comes on the heater
EO1 is a signal for low voltage. Your heater will run on 110v or 220v and you need to check your voltage comming into the heater and the wireing to the unit. Then check to be sure the heater is wired to that voltage. I hope this helps.
Jun 13, 2009 | Sta Rite STA-RITE CONTROL BOARD KIT -...
Feb 21, 2009 | Sta Rite Sr333lp - Max E Therm - Pool &...
Sta-rite pool heater SR333LP
This heater has a thermal regulator and a high limit that could be the problems. If it were a high limit that was bad, the display would show the error when the heater goes off. In the absence of an error, one would look to the regulator. A bad regulator would cause the water flow to bypass the exchanger and cause a slow heat. The part is easily replaced and runs about $90. It sort of looks like a car thermostat and also has a spring. It is accessed by removing the large black plug near the plumbing inlet/outlet.
Dec 16, 2008 | Sta Rite Sta-Rite Max-E-Therm High...
Sta Rite Sr333lp - Max E Therm - Pool & Spa Heater - Dual Electronic Iginition Lo - Nox - 333,000 Btu - Propane Gas Logo
119 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
steve morris
steve morris
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
