Question about Samsung Televison & Video
I want to get the master settings for my pn50c450b10 flat screen tv. How do I get that information.
I bought a LG tv model# 22LG3DCH and I cant program the chanels it says no signal but other tv pics up just fine.How do I fix it?
[PDF]Commercial Mode Setup Guide - LG.com
www.lg.com/.../32ld345h-commercial-mode-setup-guide....
LG ElectronicsThe model and serial numbers of this TV are located on the ... However, there is noguarantee that interference will not occur in a particular ... the TV by the hanging power and signal cables on the back ..... program guide (EPG) data provides additionalchannel and program ..... If set to 1, cannot tune from current channel.
How to resolve the No Signal or No Channels in Master List ...
? 2:07
https://www.youtube.com/watch?v=Tk7EUAEncsQ
Oct 6, 2014 - Uploaded by VIZIO
How to resolve the No Signal or No Channels in Master List message. ... Show more ... Why Does My TV Say ...Missing: 22lg3dch
LG TV "No program information" - HDTV - Streaming Video & TVs ...
www.tomsguide.com/forum/55640-4-program-information
May 24, 2012 - 7 posts - ‎5 authors
I bought a 35" LG TV a few months ago. ... TV on and it was (and still is) displaying "No program information" instead of ... All other information about the current channel is displayed OK. ... Diamondhead said: ... Can't find your answer ? ... a LG Sound BarModel LAS350B to a Toshiba TV Model 32C110U1?
Jan 05, 2016 | LG Televison & Video
On-Screen Display setting is set to off
turn off the tv for 24 hours as this resets tvs to normal most of the time. if this does not solve the problem google master reset for your model of tv
Mar 08, 2014 | Pioneer Elite® PRO-101FD TV
Blinkingscreen modelkp53hs10
Likely due to age of set the master screen control or the individual screen controls in the set are just set a bit too low---set detects this (called akb) and a simple adjustment may inside the set correct this.
Look or have a tech look first for the master screen and bring it up just slightly until blinking picture stops.
Nov 02, 2012 | Sony KP-53HS10 TV
I have a old 52 inch sony tv turns on but picture blinks off and on whats wrong
A lot of their older sets (both regular TV sets and big rear projection set had this issue).
In either case it may mean with age the MASTER SCREEN control/s need to be adjusted slightly up---if too dim a picture it will blink.
A model number would tell me what to try.
Models beginning with KP are large projection and ones with KV are regular sets.
Mar 31, 2012 | Televison & Video
New out of box tv won't come on, no lights no screen, tried several working outlets. can't turn on with remote or with button on tv
Look under the set or on the side for a Master Power Switch. If there is one turn it on. If not, take the set back and get it exchanged.
May 27, 2011 | AOC LE24H067 24 in. LCD TV
BLACK SCREEN NO AUDIO POWER LIGHT IS ON
Since the screen is coming on I do not think it is a problem with the power supply. It sounds more like a problem with the audio/video main board of the set. Is the set under warranty?
Jul 13, 2010 | Sony KDL40EX400 40 in. HD-Ready TV
Need to unlock parent control
Press menu, the on screen display menu opens with set up highlighted. Use the up and down arrows to find the features section. use the right arrow to enter.then use the up and down arrows to highlight password. Enter the numbers 3448 for the old password. Then enter a new password. You can enter 0000.press enter. The number 3448 is the master password for resetting the password. I hope this information helps you with your problem.
May 21, 2009 | Insignia LCDTV26 26 in. Television
Can't get parental control screen off
The original factory password is 0000. Four digits.The factory master password for resetting the password is 3448.Put this number in and it will allow you to set a new password. If you never inserted a password you should try the 0000 number first to see if this works. If these numbers do not work for solving the problem. Call Insignia customer support at 1-877-467-4289. You can also visit the website www.insignia-products.com and go to the customer support section and get help there. I hope this information helps you with your problem.
May 21, 2009 | Insignia IS-LCDTV32 32 in. Television
Refresh rate at 60 Hz?
http://support-us.samsung.com/cyber/popup/pop_troubleshooting.jsp?ia_cd=02010100&model_name=LN52A630M1F
According to the Samsung website, the on-screen information is in relation to the incoming signal, not the TV settings which are being displayed.
As long as you have the 120 Hz turned on, the TV will display the picture at that refresh rate. However, the on-screen information will not reflect that.
Very ood.
Dec 19, 2008 | Samsung LN52A630 LCD TV
My lcd tv is locked how do i unlock it
i called the help line and they said the only way to fix this was to call best buy and order a new, original remote for the television
the number the help line gave me was1-888-237-8289
May 02, 2008 | Insignia LCDTV26 26 in. Television
Televison & Video Logo
55 people viewed this question
Henry  Thomas
Henry Thomas
