Question about McCulloch Garden
I have a McCulloch SUE 21cc hedge trimmer. The gear from the clutch drum to main drive of cutter is stripped. Need to know the part # for replacement and where to purchase, also need to know how to replace.
trippssmengi
  • 76 Answers
SOURCE: Long reach hedge trimmer
Try loosening the bolts up on the blades just enough to allow the washers to move freely a little, spray the blades down (but don't soak them ) with WD40 to lubricate the blades, that should solve it. If that doesn't do it then you may need to pull the gear housing cover off to see if something is jammed.
Posted on Jan 14, 2009
slohry
  • 87 Answers
SOURCE: thihl HL75 hedge trimmer engine will not run at full speed
Remove the cutting attachment, insert a screwdriver in to the shaft receptor and it should operate smooth with a slight bit of friction. if not then check the blade bolts and make sure the blades move freely. Lubricate the blades and the gearbox regularly. If the attachment end is good then turn the driveshaft by hand (with attachment still off shaft). If this too moves freely then go to the clutch.
Posted on Apr 10, 2009
  • 653 Answers
SOURCE: mcculloch petrol hedge trimmer, no petrol seems to be getting
There should be a strainer on the fuel intake line in the fuel tank. Take it out and clean or replace it, and check the fuel lines for cracks or leaks. If this doesn't fix it, disassemble and clean the primer button. There should be a little one way flap valve that opens to allow fuel to be sucked in from the fuel tank and closes to push the fuel into the carburetor.
Posted on Jun 06, 2009
SOURCE: gears on my Mcculloch Chester 510 Hedgetrimmer may
The problem was with a stripped gear on a mcculloch hedge trimmer. I chucked it on the scrap heap and am borrowing my father-in-law's machine until I have time to shop for a new trimmer. Problem solved, but sadly not owing to your service this time.
Posted on Jun 17, 2009
bbap
  • 71 Answers
SOURCE: I have a 22inch Craftsman Hedge Trimmer, Model No.
The likely issue is the gear pin has been sheared. The part is no longer available from Craftsman. (P/N from sears: 616255-001)
I had a similar issue with a similar electric trimmer. I removed the old pin and used a split pin and ground it down to the proper size. It's now worked for about 2 years just fine. This requires complete dis-assembly.
Posted on Sep 27, 2010
How do I change the clutch drum on my stihl hs81R hedge cutter?
hi all, I see a few people are in need of this question been resolved so heres the answer.
1st, of all you need to take off the gear box plate using a torx 27 tool to remove the 6 torx bolts.
2nd, you will need to remove the internal spur gear and connecting rods possible the full blade.
3rd, remove the external circlip that holds the drive pinion gear in place.
4th, you will need to remove the air filter cover
5th, next is the 3 torx bolts holding the gearbox casing to the engine 1 is at the back wich can be accessed through the ring that covers the rear anti vibration springs. the other 2 are either side of the casing sunk down a little bit. hopefully these can be easily located.
6th, next is the pull start housing/ top casing.
7th, at this point you should be able to carefully lift the engine out of the lower casing and get access to the clutch drum.
8th from the gear box side carefully tap the drive gear out of the bearing.
9th, give the gear box a good clean out to remove any old oil and any metal filings that may be hanging around.
finally re fitting is pretty much the reversal of this step by step although 1 thing to take into consideration is when putting the new clutch drum in be sure to have something softer than the clutch drum to tap it back into place using the centre of the clutch drum to avoid any possible damage on refiiting.
1 final thing, good luck. and don't forget to refill with grease
Nov 07, 2014 | Stihl Hs 81, 86 R, Rc, T, Tc Trimmer Parts...
Maxtra long pole hedge trimmer has bolt with stripped thread.
same thing happened to me, I had to make another one there made of some kind of puter
Apr 07, 2014 | Maxtra Trimmer 30cc 2-stroke Gas Pole Saw...
I bellieve I have sheared a pin or bolt. The trimmer runs fine but the teeth do not move. Any suggestions. Is there a operators manuel online?
Had the same problem with my Stihk hs 81 R hedge trimmers. Ive stripped it down and found that the clutch drum had sheared. Hope this helps.
Apr 28, 2012 | Black & Decker 22 In Dual Action Hedge...
Mcculloch Virginia hedge cutter manual
mcculloch virginia mh542 hedge trimmer, fires 1st time, will only tick over roughly on full choke only then stalls when throttle applied, I have fitted new plug'cleaned air filter and new fuel mix but no change.
Nov 25, 2009 | Garden
A drive gear seems to slipping when the blade cuts into thicker s
Yes you can get parts for it.The gears tend to strip the teeth.
Jul 06, 2009 | Homelite Expand-It Hedge Trimmer...
What ratio of oil do you reccomend for the
Depending on the age of the McCulloch cutter it could be 25:1 32:1 or on rare occasions 50:1.
Regardless you can't go wrong with 32:1. This ratio can be used in ANY 2 cycle engine with great results.
Jun 23, 2009 | Garden
Gears on my Mcculloch Chester 510 Hedgetrimmer may
Jun 16, 2009 | ECHO, Inc. 20 In. Double Sided Hedge...
Thihl HL75 hedge trimmer engine will not run at full speed
Apr 04, 2009 | Oregon Scientific Complete Carburetor for...
Garden Logo
54 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
