LG 47 LED tv keeps restarting Problem: After some minutes, the picture freezes while the audio keeps going. a few seconds later, the lights begin to dim and the tv goes off and turns itself back on.
SOURCE: Tv cuts off and green light flashes
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
Donnieboy999
Posted on Oct 21, 2008
  • 19 Answers
SOURCE: LG 42LG5 TURN ON TV PICTURE GOES BLACK
This could be 1 of a few things here. Without opening up your set and trying to look at voltages or indiciator lights I couldn't tell you exactly without some more info.
Without looking at it myself here are my thoughts and where I would first look at.
It may be a main board because:
1) Main board processes all your audio/video signals. Bad main board means bad video processing. Could do that. Especially if the main board is not sending the right signal or a bad signal to the rest of the boards so they don't do their jobs.
It may be a power supply because:
1) Power supply is well, the power supply. If it's sending inadaquete voltage to the main board you may not be recieving enough juice to keep that main board doing your video processing or further up the line keeping enough juice flowing to your TCon board to keep it telling things where to go and what to do. The power supply sends voltages to your Ballast board(controls your lights) and to your main board through which power is supplied to your TCon board via a LVDS line and a +12/+16V signals. If the power supply isn't pumping out enough juice to keep the TCon or Main Board running, it could be a problem. By the same token it could be that your P/S isn't sending power out to your ballast board.
It could be a TCon because:
1) If the TCon is bad, you won't get your pictures. This could be the TCon board itself or the LVDS cable from your TCon to your Main. However, with few exceptions, if it's a bad TCon you're looking at a total panel replacement.
It could be a ballast board because:
1) The Ballast Board controls the lighting behind the LCD screen. If this isn't working right you won't be seeing much of anything without that back lighting. If this is bad, it's a panel replacement. These are not field replaceable items by LG.
Based on the symptoms, without more data or a eyes-on view of it, I would say you're most likely looking at a Main Brd or PSU problem.
Posted on Feb 21, 2009
SOURCE: frozen picture on LG LCD 37"
Try One of your working TVS and connect it to your cable outlet of the TV that is having problems. If that TV Does not work then there may be a degraded fitting or the Leg coming of the splitter to that outlet could have a Low Signal Problem
Next Take the First TV that was not working properly and put it on the cable outlet of one of the TVs that is working properly and if the TV set works on that Channel then you know it is not your TV that it must be the cable
Posted on Feb 28, 2009
  • 668 Answers
SOURCE: Sony Vega KDF-E5OA10,picture will not come on, tv goes off.
There is a real good chance that the lamp fan is not turning. If you look with a flashlight in the vent on the left side looking at the rear of the set and have someone turn on the unit, see if it spins. if it doesnt, the protect circuit in the tv will not let the set turn on. Replacing the fan will cure the proplem if it is not turning.
Hope this helps,
Skyassoc
Posted on Jun 18, 2009
  • 188 Answers
SOURCE: no picture on my philips 42PF7321D/37
Bad caps in the power supply must be replaced .
Posted on Jul 21, 2009
My LG tv model number 42LN5400-UA no picture
It is a common problem for the LG 42/47 LN series LED TV, the problem is defective LED back lights strip (strips).
You have to open the display panel to find the bad one & replace it. The part number usually is printed on the strips, read 6916L-11XXA, you may purchase it from EBay.
Aug 11, 2017 | LG Televison & Video
How to fix/ trouble shoot a 2015ish LG LED 47" TV that plays sound but keeps losing the picture.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
May 11, 2017 | LG Televison & Video
LG 47LW6500, I turned on the TV yesterday, and initially it came on but right a few seconds later the picture was cutting off then on then stayed off.
if you have sound problem is a back light led strip is faulty
if not main board is bad replace it maybe with more info i make beter answer
Mar 08, 2017 | LG 47LW6500 47 3D LCD TV
Tv turns on and screen flickers on for a second and then turns off, whats the issue?
Sounds like Back - light problem.Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis.If you wish to get some details; check the site linked here.Surf the site with patience.Pull up older posts.It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS].In such cases, the power supply board might need replacement.To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself.If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board.If this is the case, you have to replace the main board.
Jul 28, 2016 | LG 47LN5750 47" LED TV 1920x1080, 120 Hz,...
My LG tv will go on then after a few seconds the screen goes from black back to picture of and on a few times then shuts off. Help!
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
7 days ago - My 32' LG LED TV has suddenly lost picture! The sound is all right but theScreen is pitch black. After switching it on the picture flashes for a second and thenthe ... LG LED TV has no picture (black screen) but still sound - can it be fixed? Tags: ... a touch on the screen reveals nothing so it's not the back light.
Monitor going black after 2 seconds [Solved] - CCM.net
ccm.net > Forum > Hardware
Oct 9, 2012 - Brightness goes down, display draws less juice, and you can at least use .... it's the LCD's Inverter ... you have to replace it for it to go back to ... If the screen is turning off every two seconds or so and then it comes ... i turn my tv on it comes right on, but then after a few minutes turns off, .... Digital Trends for LG. No display in monitor
Jan 11, 2013
Ps3 and hdmi cable
Oct 8, 2012
More results from ccm.net
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
Dec 20, 2015 | LG Televison & Video
Bottom half of screen goes black
This is because full pixels of your TV is not getting invoked at the beginning .If you are able to view the picture as normal after 1 or 2 minutes, its fine.Else you need to call to service center and get this problem fixed.
Aug 08, 2009 | LG 42LC2D 42 in. LCD HDTV
Maxent 42" Plasma TV takes 3 - 5 minutes to sync after turning on
I had the same issue....thankfully, I had purchased an extended warranty from Best Buy...I had been in a panic, because I NEVER thought I would pay a grand for a tv, but I LOVE it...anyway.....I had the "Geek Squad" come to look at the tv....the tech took 30 secs....there is a problem with your Y-SUS (Y-sustain board)...it will need to be replaced...and...the tech called another tech, and he advised that the Z-SUS be replaced as well (apparently he had to go back to the same home after a Y-SUS replacement to change out a failed Z-SuS).....retail on Y-SUS is about $300...ebay has them for less than half that, if you think you can do it yourself...keep in mind that "Maxent" is a Zenith/LG product, so finding parts might be a challenge if you base it upon Maxent....hope this helps!!
Dec 01, 2008 | Maxent MX-42XM11 Television
LG DU-42PX12X Plasma, picture startes flashing then goes black after a few minutes
You need to get this tv service asap.i beleive that the problem is in the inverter board or yb board.
good luck
caypianan@yahoo.com
Oct 25, 2008 | LG 42PX5D 42 in. Plasma HDTV
Televison & Video Logo
426 people viewed this question
Top Televison & Video Experts
Electro Med Services...
