Question about Whirlpool Refrigerators
I have a Whirlpool refrigerator Model: ET18HPXHW0 0 Ser. EK0425816 Type: C18TFA00 My problem: I have had a lot of water pooling in the bottom of my fridge and on shelves - big mess! I located the problem - water is dripping from an opening in the top of the fridge which I am assuming is coming from the freezer. This has been happening for quite some time now and I am collecting a glass full of water of few days or so. Could you please tell me what the problem may be and how I myself can fix it? Thank-you for your time. Sincerely, Erin Breckon
aborcass
  • 2651 Answers
SOURCE: Water collecting in refrigerator and ice collecting in freezer
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you access to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somewhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wire around the heater( black heater right above the drain trough) and stick it in the whole maybe an inch or so. now every time the heater comes on to defrost it will prevent the hole from freezing over
Posted on Mar 15, 2008
  • 1122 Answers
SOURCE: Dripping water
YOUR DRAIN FROM FREEZER TO DRAIN PAN IS CLOGGED,LOOK INSIDE TOP BACK OF REFRIG. SHOULD BE DRAIN HOPPER,REMOVE AND CLEAR OUT DRAIN,THANKS-MIKE
Posted on May 29, 2008
aborcass
  • 2651 Answers
SOURCE: Whirlpool has water drip inside fridge
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Posted on Oct 26, 2008
SOURCE: Water on btm of glass shelves and water in bottom of frig
sounds like you have a gap in the door seal, which results in condensation forming inside unit. Use a blow dryer to heat the seal around the door and ensure that the fit is tight.
Posted on Jan 08, 2009
  • 29 Answers
SOURCE: Water dripping into refrigerator from freezer
DRAIN TROUGH IS PLUGGED OR FROZEN. EMPTY FREEZER AND REMOVE LOWER TRAY TO SEE A HOLE ALL THE WAY IN THE BACK USUALLY IN THE CENTER. CHECK TO SEE IF WATER CAN DRAIN THROUGH BY POURING A CUP OF IT INTO HOLE. IF IT IS FROZEN POUR HOT WATER UNTIL IT THAWS, IF PLUGGED REMOVE THE OBJECT.
Posted on Jan 29, 2009
Whirlpool refridgerator with top freezer. Water leaks and pools at bottom of refridgerator under crisper. How do I fix the leak?
Here is a Utube video that will do the trick. Might not be your model, but same gig.
https://www.youtube.com/watch?v=VHD556AQ894
Dec 22, 2014 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool refrigerator is leaking water
If the water is pooling around the bottom of the fridge I would pull the fridge out and pull the panel of the back of the fridge and check to make sure the black plastic drain pan is in place and the white or clear plastic hose coming from the bottom of the fridge is aimed at the drain pan, if they are not then that would be why you have water pooling up under the fridge. Generally the Walter gos into the drain pan after defrost and the heat from the discharge lie of the compresser evaporates the water and it should never overflow. Hope this helps
Sep 08, 2012 | Whirlpool GB2FHDXWS (63 cu ft) Top Freezer...
I have a whirlpool side by side model # ED5VHGXMB10. It leaks water into the bottom of the freezer. I have re adjusted the water tube that dumps water into the ice maker thinking it was shooting over the...
Below that panel in the freezer (evaporator cover) is the drain trough. Most likely it is clogged.
Using a baster, with hot water and bleach mixed deluge till it flows down to the drain pan underneath.
Dec 31, 2010 | Whirlpool ED5VHGXM Side by Side...
I have water pooling in the bottom of my Whirlpool Gold refrigerator. How do I fix it?
if top freezer the drain has frozen over and will need the drain cleared and a heater kit installed.. mm
Aug 18, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool refrigerator has water pooling under crisper
  1. take all things out from freezer
  2. open back wall of freezer
  3. clean the drain hole in the bottom middle
  4. put all back
  5. good job you fix it
Dec 29, 2009 | Refrigerators
Water pools under the veggie crisper
yoor problem is with the drain, when your refrig goes into self defrost the water melted from the defrost needs some where to go. There is a drain for this purpose....it is normally a tube that leads from the rear of freezer to pan by compressor. when this gets blocked the water has nowhere to go except into the freezer vent and down the bottom of the refridge compartment. you will need to clear the blockage in the drain tube...if you are still haveing a problem i can tell you how.
Jun 21, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water pooling into bottom of refrigerator.
Empty the machine and let it dry out, it sounds as if the Styrofoam between the freezer and refrigerator is breaking down and holding a lot of condensation. Is this an older machine? If the problem reoccurs, there is nothing you can do to mitigate it.
Jun 19, 2009 | Whirlpool GR9SHKX Top Freezer Refrigerator
WATER POOLIN AND FREEZING AT ON FLOOR OF FREEZER. ICE MAKER NOT HOOKED UP
you have a blocked drain remove back freezer panel
at the bottom you will find a lot off ice remove it with hot water and clean drain hole the pop is the ice cracking
Apr 17, 2009 | Refrigerators
Refrigerators Logo
149 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
