Question about Mitsubishi WD-57733 57" HDTV
My tv looks like it has dust oand dirt particles all over the inside of the screen. When I watch tv I have spots everywhere? How do I clean it and with what?
  • ram6450ram Apr 07, 2011
    is this an lcd projection set?
The wd 57733 has sound but no picture and turns off on its own after a few minutes.
Posted on May 06, 2011
Spot's on tv screen's
If the spots are coin sized or so, its likely dust. These tvs are know for dust particles getting on the len inside and causing issues. The tv needs complex disassembly and cleaning to solve the issue. The only tool required is a philips screwdriver but it does require some know how. A air compressor or can of compressed air is helpful also. Let me know if I can assist you further, the directions could be quite lengthy. Thanks
Jun 03, 2010 | JVC HD-61FN97 61" Television
Dust spots on images
this will give you the idea how to clean the lens and have lens cover which is available in market to protect it from dust
http://www.picturecorrect.com/photographytips/207/cleaning_camera_lens.htm
thank you
Sep 22, 2009 | Leica M8 Digital Camera
Black particles coming out of the room air conditioner
dirt, dust, or mold. could also be the tubing insulation flaking off. either way, open it up and clean it out. the dirt, dust, and flaking insulation can restrict air flow through the coils and cause the ac to not function properly. if it is mold, it's can cause sickness (legionaire's disease). do not use chemicals on the coils. it might be best to replace the ac alltogether. to prevent mold: when installing the ac, make sure the unit is slightly tipped towards the outside. any condensation that collects on the coils will drain out. failure to do so will result in water pooling inside, and this can cause mold.
Jul 30, 2009 | Kenmore 73259 Air Conditioner
DARK SHADOW EFFECT UPPER CORNERS OF SCREEN
I would check for dust particles before I attempted any type of repair on the unit.
Dust particles will appear as dark spots that are larger than the size of an individual pixel. It must first be determined if the particle(s) are on the LCD panels or the screen.
May 27, 2009 | Sony KDF-E42A10 42 in. LCD Television
Grey "dust spots" on screen and on pictures
on the surface of the CCD, that's a picture sensor chip, inside the zoomunit there will some contamination such as dust or an other particle
The ccd surface must be cleaned by an camera repair center
regards Rob NL
Apr 30, 2009 | Cameras
White spots on screen of my Samsung DLP TV
What causes the DMD board to go out?
No Picture, but have sound
Had a new lamp put in this morning
TV now has 2 white spots
TV - bought in 2003 for $3600.00 and only used 5 months of the year
Jan 21, 2009 | Samsung DLP HL-P5663W 56" TV
Gray spots on screen on a JVC HDILA model HD 56G 787
The gray spots are caused by dust on your lens, very easy to clean.
Power down the TV.
If you open the right side access panel (right side as you are looking at the front of the TV) you can see it in the middle, it's not very big. Using a scratch/lint free cloth, gently wipe off the lens or use a vacuum to **** up the dust being careful not to actually touch the lens.
Replace the access panel and enjoy your spot free screen.
Sep 29, 2008 | JVC HD-52G786 52" Rear Projection HDTV
JVC HD-56G886 56INCH REAR PROJECTION TV
I fixed it!!!! If you can open one of the sides (on the JVC there is a little door with a screw), then you can clean the projector lense in the middle on the bottom. It kind of looks like a big light bulb. It seems there is just dust on the glass that is projected onto the screen. We had a big gray spot and cleaned it with a damp glass cloth and Ouila! It disappeared. I scored MAJOR brownie points with my husband for this one! He wanted to replace the TV!
Sep 25, 2008 | JVC HD-52G786 52" Rear Projection HDTV
Sony kp-53hs10
you can get lamps online or from the manufacturer and to clean inside just unscrew the particle board on the back on you can vacum the dust out. dont use a duster or youll get dust everywhere.
Sep 21, 2008 | Sony KP-53HS10 TV
Dust particle inside lens
if its dirt, then it would be better to gave it serviced by an authorized sevicer. check also if the spot blinks and if it is..............its a dead pixel.(dead pixel os not a malfunction)
its normal with all lcd screens. you may set up repair file for yet camera on www.sony.com/repair or call 1800-222-7669.
Jan 16, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Mitsubishi WD-57733 57" HDTV Logo
180 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
