Question about Celestron NexStar 11 Telescope
The LCD display on the handheld remote seems to be "fading". I'm running it on AC current, so that shouldn't be the problem. Could I have mistakenly turned off the display? Please advise. Thanks!
  • 7 Answers
Probably too late, but you can change the brightness on the display. You may have accidentally turned it down. Let me know if you still have the problem and I can tell you how to access the brightness function on the hand controller.
Posted on May 10, 2009
The digital display is very faded or nothing at all so can not read to set timer. Is there a part for this??
[PDF]USER MANUAL - Newegg.com
images10.newegg.com/User-Manual/User_Manual_89-262-370.pdf
To get the most out of your new VIZIO product, read these ... Follow all instructions. ...the provided plug does not fit into your outlet, consult an ... Doing so could short circuit parts causing a fire ... the screen of the coaxial cable is intended to be connected to...... setting is too high, the picture may appear faded or washed out.
GPCT Multi Function Digital Talking Projection Alarm Clock ...
www.amazon.com/GPCT...Digital.../dp/B00IDZ6V4I
Amazon.com, Inc.With a talking function, your alarm will report the current time in English so ... TimeSet, Dual Alarm, Sleep Timer, Indoor Temperature/Day/Date Display .... u pick theclock and look at the clock very near to see the faded LCD Display. ... but I wanted aclock that put the time on the ceiling all the time, not just when prodded.
[PDF]USER MANUAL - Vizio
www.vizio.com/documents/downloads/hdtv/.../UM_P602uiB3.pdf
VizioTo get the most out of your new VIZIO product, read these instructions before ... the provided plug does not fit into your outlet, consult an ... Doing so could short circuit parts causing a fire .... the screen of the coaxial cable is intended to be connected to.... Setting the Sleep Timer . ..... HDMI is the intelligent, all-digital interface.
No air conditioning and blank thermostat display
www.handyguyspodcast.com/.../no-display-on-the-thermostat-and-no-ac...
Jan 20, 2016 | Hardware & Accessories
Display for about 30 seconds then fade away
This seems the issue with the display panel cable connected from mainboard to display panel .Please get it checked.
Thanks
Aug 19, 2009 | Compaq Presario 1700 Notebook
Basslink Powerlight comes on then fades quickly
check to make sure your remote wire is hooked up to your amp turn on that runs straight out of the stereo not your power antenna also make sur you have a clean ground(no paint or rust) and also check your connections make sure you have a strong connection to all wire hook ups.......you should check to see that your remote wire has no tears in it or small rips or cuts because that can interrupt your current to and from the amp and radio
Jun 25, 2009 | Infinity BASSLINK Car Subwoofer
Replaced Display on Vostro 1400, now it's light/fading in areas
Sounds like the connections are either loose or not properly connnected.
Checke the connectors again, and make sure you're not bending any pins in the process.
Jun 16, 2009 | IBM ThinkPad R51 Notebook
Fading digital display on Thermador SC302ZS Double Oven
when the display is fading it has to be changed part number 492071 that is for a double oven display
Feb 19, 2009 | Thermador C302U Electric Double Oven
Not a typical backlight issue
Hi!
You can check the brightness with AC in the BIOS and match it with running in battery or else, when you plug the ac adapter, the lcd goes dim, press and hold the FN buttong and tap the up arrow then reboot and try to see if it will still do it. But still the best way to do it is going to the BIOS by pressing F2 at the Dell logo startup.
Hope this helps!
Thanks,
Karlox™
Jul 30, 2008 | Dell Inspiron 1150 Notebook
Problem setting Thermostat
It could be displaying the actual temperature of the room. You have to observe the LCD whether it changes.
Apr 19, 2007 | Samsung AS18A6RB Air Conditioner
Celestron NexStar 11 Telescope Logo
98 people viewed this question
Top Celestron Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Vernon Taylor
Lawrence Oravetz
Are you a Celestron Optic Expert? Answer questions, earn points and help others
