Computer connects very quickly (wired connection), but after about one minute computer goes off-line. message says 'problem with one or more of your network adaptars" however, when i connect to a wireless net. , computer stays online. no wireless available to me at present location. computer is a Toshiba
    Sergeant:
    Champion:
  • 217 Answers
Laptops have two adapters that work independently so even if your wireless works your lan may not. For your lan, (wired), network adapter first try to install the latest updated driver. Go into device manager ( right click my computer and choose/ properties/ hardware/ device manager ) scroll down to your network adapters and look at the properties/ driver and note the driver date and version. Next go to your laptop manufacturer and search your model under downloads to find the latest offered driver. If it is newer than the one installed on your computer go ahead and install it and that should fix your problem. If that doesn't work post back here with more information and we can go deeper into the problem.
Posted on Apr 07, 2011
Messaging is inactive on all lines after push functions button and enter 981
Hi. Inactive feature often means that there's a problem with your connection to the call pilot. Do you have lights on your call pilot? Did you assign a mailbox to the extension you're working on? Did you remember to connect the call pilot to a station port?
Jun 11, 2015 | Nortel T7316E 2-Line Corded Phone
I have an arcoaire condenser. dual cap.
Yes, Red to Com, Compressor to Herm, Brown to Fan. You should also have another wire from the condenser fan going to the Com terminal.
Jun 10, 2012 | Heating & Cooling
I have a HP Pavilion A6403W, when I turn on the monitor the message comes up on the screen VGA input no signal and DVI no signal then it goes to sleep. CAN YOU HELP PLEASE
The monitor is telling you that it's NOT receiving a signal from the video card connected to your computer. Check the cable that goes from Monitor to Computer. Make sure it's secure. If it's secure, I would recommend you re-seating the video card, just make sure you remove power from the computer and you ground yourself. If you are not comfortable doing this, then I would recommend visiting a local mom and pop computer shop and have the technician take a quick look, should only take about 5 minutes for a decent tech to diagnose the cause.
Hope this info helps!
Feb 20, 2011 | HP Pavilion Desktop with Intel Pentium...
Liftmaster Chamberlain Garage Door Opener Transmitter 300MC: I'm tryin to connect the sensors on my garage open...
IF YOU HAVE THREE SCREWS THE WALL BUTTON GOES TO 1 AND 2
THE EYES
THE WHITE WIRES W/BLACK LINE GOES TO 3
THE PLAIN WHITE WIRES GO TO 2
IF YOU HAVE SLIDE IN QUICK CONNECT THE WALL BUTTON GOES WHITE WITH RED TRACE TO RED.
THE SAFETY EYES WHITE WITH BLACK TRACE GOES TO GRAY PLAIN WHITE GOES TO WHITE
HOPE THIS HELPS
May 18, 2010 | liftmaster Chamberlain Garage Door Opener...
Same problem
Check the Inverter card Connector which goes to pannel,Next Panel to AD card signal Cabble,..
Jul 10, 2009 | Princeton Digital VL1918 Monitor
DeLonghi Planus quick connect split heat pump.
I was told by a delonghi technician that it does this to defrost the unit.
Hope this helps.
Apr 16, 2009 | DeLonghi Heating & Cooling
No directions for attaching a phone line to mfc 240c.
small phone line goes from your wall switch to the rear of your ADSL modem, then the fatter wire goes from the modem to the input on the rear of your computer.
If it is wireless modem,,and you have a wireless connection on your computer then it should discover the connection by itself, after hooking all the wires up properly
Jan 16, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Wiring compressor
The two terminal cap is only for the new fan motor. Connect the compressor wire back where you found it, on the 3 terminal cap. It's the terminal marked, "herm". The "common" terminal on the 3 terminal cap must still be connected to one side of the 220 power at the contactor. One side of the 220 goes to the common on the compressor. The other side of the 220 goes to the run winding on the compressor AND the common terminal on the 3 terminal capacitor.
Jul 18, 2008 | Carrier 38CKC036 Air Conditioner
Conection
Find the Audio card of you computer. Mostly audio card jack had label line out or audio. Also audio out jack was light green in color.
Jun 17, 2008 | Boka 81000 Computer Speakers
For dummies
Hello, Good question..Phone line to DSL modem, Ethernet cable to WAN port on Router. If connecting a PC wired to Router, connect Ethernet cable from 1 of 4 LAN ports on Back of router to ethernet port on PC. This would be Physical connection...
It's always smart to set a restore point in case something goes wrong during installation of any program. For wireless connection from laptop or PC: install router software on computer. Reboot computer. In browser address bar enter 192.168.1.1. This brings up a window for user name and password. Enter "admin" for both. This allows you to change many settings including Changing SSID(Router Name), User name and password. Enabling WEP or WPA security. Hope this Helps, Good Luck..!!
Mar 26, 2008 | NetGear RangeMax WPN824 Wireless Router...
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
