Question about Pool & Spa
I had high pressure before I power washed my pump filters.Now that the pressure came down my Polaris 380 is not working-i checked the belts and they are fine.The cleaner just points down from the front looks like it has too much pressure but it just sits there.I don`t know what it could be?Can you help?
    President:
  • 1,378 Answers
How old are the elements? Power washing them is not helping and if they are more than a couple seasons old they'll need to be replaced. One of the drawbacks to a cartridge filter is that no matter how much you clean the element(s) after a couple of seasons the element material breaks down and they need to be replaced.
To confirm remove the elements and run the system. If pressure returns to normal replace them. If not something else is restricting flow. Start with any shutoff valves and then any check valve(s) in the plumbing and go from there.
John
Posted on Apr 08, 2011
Why on a polaris 380 would water pour out of pressure relief valve and not make it to vacuum
check inline filter or check to see if hose is collapled sometimes the bend where they go into the polaris
Jul 12, 2014 | Polaris 380 In Ground Pool Cleaner
I have a polaris 380 which has stopped working and the pressure relief valve is opening. The inline filter appears to be clean, but I am thinking that there must be an obstruction in the polaris nozz
pressure relief valve on sidewall check oring make sure fitting has both tangs if missing replace if ok see if inside Polaris there is a obstruction
Jul 15, 2012 | Polaris 380 In Ground Pool Cleaner
The wheels on my polaris 360 don't turn
if pressure ok look inside and check hoses and belts and gears on wheels
Jul 25, 2011 | Polaris 380 Automatic Pool Cleaner with...
I have a polaris 380. I have replaced the belts and several of the bearings. The wheels all turn at the same time when you spin one of them, however when it is in the pool and I check the RPM it...
If all the belts, bearings, shafts, etc are in order and the wheels don't turn then the turbine is not providing power to the system. This turbine is under a cover inside the cleaner. Remove the cover to inspect it (look for any mechanical problems). You can also connect water pressure to it at this time to see if the jet that turns it will make the turbine turn. If the turbine is being hit by a jet of water it should turn if the friction in the belts, bearings, shafts, etc. is not too high.
Jun 23, 2011 | Polaris 380 In Ground Pool Cleaner
Polaris won't move and seems to be nose down. The tail is moving but thats it. also when i bring the tail out of the water, it doesn;t have much water pressure shooting out.
Check the pool cleaners filter screen in the in-line filter and clean, if necessary.Clean the skimmer basket, pump basket, and pool filter. If one of these is full or clogged, it could be weighing part of the cleaner down. Check all of the hoses, connections, and swivels for leaks that could cause loss of
water pressure. Finally, make sure that your wheel RPM is set correctly (between 28-30 RPM)
Mar 02, 2011 | Polaris 380 In Ground Pool Cleaner
My Polaris 380 just stop moving the pump was run and had good pressure turn one wheel they all turn freely also tail dose not move
Check several things if these pool cleaners stop moving. Check the filter screen in the in-line filter and clean, if necessary. Clean the skimmer basket, pump basket, and pool filter. Check all of the hoses,
connections, and swivels for leaks that could cause loss of water pressure. Make sure that your wheel RPM is between 28 and 32. Adjust your thrust if necessary to get RPM to that level.
Aug 03, 2010 | Polaris 380 In Ground Pool Cleaner
Which pressure should i use on uwf polaris assembly 380
It might not be your booster pump. First, check the filter screen and clean if necessary. Often, this is the only problem when these pool cleaners are having problems. Clean the skimmer, pump, and filter also. You will also want to check all connections and hoses to make sure that you don't have a leak.
Mar 14, 2010 | Polaris 380: Polaris Booster Pump
Polaris 380
polaris has belts in side it if your handy you can replace them your self if not any pool place can do it but it is a belt i have a 380
Jul 21, 2009 | Polaris 380 In Ground Pool Cleaner
Pool & Spa Logo
42 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
