Question about Dryers
We have a whirlpool ultimate care heavy duty super capacity plus gas dryer model # LGR5848EQ6. We just moved and it had to be hauled up the stairs of the old house & down the stairs of the new house. It worked 3 or 4 times but now it just wont get hot at all. Ive tried unplugging it and restarting it a couple times with no luck. Someone said it was the egnighter? If so can my husband fix it
  • 3 Answers
Yes they r a known part 2 go bad if he has a elec meter tell him to check 2 see if there is conten through it once he un plugs the ignitor. also on the back inside back panel there is a sensor that could of went bad it is white about 1.5in long ck that also 4 contenthe parts r very easy 2 change.
Posted on Apr 07, 2011
My whirlpool ultimate Care II Heavy Duty Super Capacity Plus washer Very slightly agitates and don't spin dry
The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
Mar 21, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
My dryer is a ultimate care heavy duty super capacity runs fine but it wont heat up so it don't dry. Does it have a pilot or something i need to replace?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 20, 2011 | Whirlpool Dryers
Find serial and model number
Normally on top load machines open the lid and look toward the back hinge area inside the lid. It is usually on the back there. It may also be posted on a white sticker on the back of the machine.
Apr 30, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care Heavy Duty Super Capacity Plus
clutch could be it check if nothing is jammed between tub andbasket. if u have an oily tranny i would replace it
Feb 12, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Ultimate care supreme leaks underneath
First check the hoses to the machine. If they leak the water follows the hoses and drips on floor. Also check the hose connection at the washer. They will leak inside. Next it may well be a water pump going out or the plastic hose that is under pressure when operating. The pump is in the middle of machine underneth - Sorry - Good luck
Oct 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Does not dry clothes
If its not heating up correctly you could have a bad thermostat, blocked up vent or dirty lint screen, or possible the coils that go near the ignitor need replacing.
Sep 21, 2009 | Dryers
Ultimate care heavy duty dryer is not heating
SOUNDS LIKE YOVE GOT A CLO OF LENT IN THE LINT BASKET CLEAN AND LET ME KNOW HOW IT TURNS OUT
May 03, 2009 | Dryers
Agitator
if its a 2 piece agitator.. the gears in top of agitator is stripped out.. change gears be like new....spin top countor clockwise if it dont grap.. gears bad
Sep 28, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Dryers Logo
273 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
