Question about Dacor DMT2420SS Microwave Oven
Microwave Our microwave key pad is not working. The light is on when you open the door and : is flashing but we cannot set the time and none of the touch pad works
  • Anonymous Feb 16, 2009
    some of our key pad works so we can use the microwave, but the clock has disappeared and cannot be reset. Any of the programmed keys do not work.
  • 1 Answer has links all over the internet advertising a simple fix for microwave displays. I ordered one and they never sent it. Had to file a claim with Paypal. No communication until I threatened them, then they said it's on its way. I waited another week and it sitll didn't come. After six weeks of trying to get my money back, I finally got a refund. Now I have to start all over. Any suggestions for replacing a display BESIDES this sham operation?
Posted on Jul 07, 2009
My LG intellowave microwave's touch pad/control lights is coming on and I can set the time to microwave but the on and off touchpad doesn't want to work
The touch pad switch is faulty. You have to replace it
If you wish to get some details; check the site linked here. Pull up older posts.
Sep 01, 2016 | LG Microwave Ovens
Burns my popcorn constantly. is there a different setting i can put it on?
Solution to your microwave problem is given as below.
* 1 Set your Daewoo microwave on a countertop near an electrical outlet and plug it in. Open the door and place the circular roller guide in the center of the oven cavity, then place the glass cooking tray over it.
* 2 Set your food on a microwave-safe dish and then put the dish on the cooking tray and close the door. Make sure that it latches properly.
* 3 Turn the upper knob to select a power level. Power levels include "Defrost," "Med-High," or "High." If your Daewoo has a touch pad, touch the "Microwave" button once to set the highest power level. Touch it consecutive times to lower the power level.
* 4 Turn the lower knob to set the cooking time. For cooking times less than two minutes, turn the knob up past the two-minute mark, then back to the correct time. For touch pad models, enter in the cooking time with the numerical keys and then press "Start."
* 5 Open the door at any time to stop the cooking and check the temperature of your food. Shut the door to automatically continue cooking, or turn the timer knob to the right to add more time. For touch pads, press the "Stop/Clear" button, then key in a new cooking time and press "Start."
* 6 Open the door when the timer reaches the "Off" position and take out your food.
Sep 24, 2011 | Daewoo KOC-925T Microwave Oven
None of the keys work
the touch pad has a ribbon cable that connects to the control board poosible that the touch pad has failed or the control board itself.... most of the time the touch pad fixxes the problem... if you have power and all still try ordering the touch pad for the unit...
good luck to you
Jan 09, 2011 | Microwave Ovens
I have a GE microwave and F3 has just come up on the display screen???
F3 Shorted key panel (touch pad).
1. Will occur if a shorted key panel is detected continuously over 60 seconds.
2. Replace key panel (touch pad).
What you can first try before replacing the keypad is first unplugging the microwave. Then you can get access to the panel by first removing the top grill and then unscrew the top of the control panel. There is a strip that looks like tape which attaches to the control panel which you need to wipe off and then blow dry. may not work the first time but be patient. also clean the bottom of the door and the latches to make sure the connection is clean. After that is should hopefully work without replacing the touch pad.
Let me know how this works out for you.
Apr 26, 2010 | GE Profile Spacemaker Over-the-Range...
Our GE Profile started beeping and flashing f 3. None of the buttons will work now.
This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad). Once the key panel is replaced, the issue will be solved.
Nov 25, 2009 | GE Profile Spacemaker Over-the-Range...
While cleaning it the vent began to open and close and the microwave would not shut the vent down when the keypad was used to end the cycle. Now it only shows F3 on its screen when we try to set it up...
The "F3" error code means "Shorted key panel (touch pad)". The correction is to replace the key panel aka a membrane switch or a touch pad. The control panel in that case is just a plastic frame.
please rate this help to keep us online
Aug 17, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Oven
I report from owner manual.
F3 means : Short circuit on key panel (your touch pad).
You get F3 error if a shorted key panel is detected for more than 60 seconds.
Solution: . Replace key panel (touch pad).
Try first unpluggign power cord for five minutes.
If you think that the problem may had been caused by water inside the keypad you can try using an hairdryer on the keypad, taking care not to melt the keypad plastic.
If that does not work, then replace the keypad.
You can buy replacements here. or Order GE Microwave Ovens Parts Here
Mar 08, 2009 | GE JVM1630 Microwave Oven
Dacor DMT2420SS Microwave Oven Logo
177 people viewed this question
Top Dacor Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Steven Clarke
Steven Clarke
Are you a Dacor Microwave Oven Expert? Answer questions, earn points and help others
