Question about Minolta EP4000/5000 CS/PRO Copier
I have a Minolta ep4000 copier. The bottom letter tray platform where the paper sits on is stuck in a high position. The copier will not allow that tray to feed paper. I tried to turn the machine on and off, but the tray will not reset to the lower level. Any ideas? George
  • Minolta Master
  • 6,161 Answers
With the draw closed and the machine on is there a small wrench Icon on the control panel lower left. If so touch it screen will change then once on new screen open close the front door, see if that resets your draw electrical.
Posted on Feb 22, 2015
5 Suggested Answers
Cogz
  • 1326 Answers
SOURCE: smudge on the paper
When you say smudges, do you mean toner spot or blobs of toner on you pages? If you get random blobs of toner... You need to take out the drum unit & remove the primary charge unit & remove the drum & vac. out a small little grove that seats right below the developer mag roller... It is most likely filled with toner and is dropping on to you paper as copies are being made. Good Luck
Posted on Feb 27, 2009
SOURCE: Minolta ep4000 sorter bin is stuck. code is
how to solve cob60 error in minolita 3000
Posted on Mar 02, 2009
  • 990 Answers
SOURCE: minolta ep4000 copier code c0520 where is the
Hello sir; In the upper front left corner of the machine there have a PWB-1 switch board , just press S-1 switch to reset.
Posted on Sep 18, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: Minolta EP4000/5000 CS/PRO Copier how do i change
Open the large front door. The toner bottle is at the upper left side. Swing it out by pulling out on the left side. Slide the old toner bottle out of the gray holder. Now take the new cartridge, keeping the hole with the seal on it on top. Slide it into the holder where the old one was. There are 2 "pegs" on the bottle that will clip into a clip on either side. Once fully installed simply pull the plactic tape towards you to remove it from the bottle and swing the new toner back into place and close the front door. Thats it!
On most of the 4000/5000 models the toner instructions are on a label inside the front door.
Good Luck and Thank You for using Fixya.
Posted on Jun 03, 2010
Exit tray broken for a Minolta CSPro EP4000
Legacy machine from Minolta now Konica Minolta. Try ebay? Or super glue. Try the web sit below Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Apr 18, 2013 | Minolta EP4000/5000 CS/PRO Copier
Minolta ep 4000 how to disable the third paper tray
If the 3rd paper tray is LCT (large capacity tray) disconnect the tray electrical connector on the rear side,or not close the tray.
Feb 27, 2013 | Minolta EP4000/5000 CS/PRO Copier
I have Minolta Copier CSPRO 4000; it has error Code: c0372 please help
The bottom paper draw and duplex section have each a plug you plug into the copier in the rear. you mite want to check them for loose connections or the connectors themselves the code is stating that copier can not talk with bottom draws or the duplex section which makes your second side on a single paper. Open close front door to reset and could reset the machine power it off disconnect bottom draws and duplexer then just use the copier that way.
Jan 10, 2013 | Minolta EP4000/5000 CS/PRO Copier
Where is the left paper jam Sensor in the Minolta EP 3010? My EP3010 always tells me, that there's a paper jam at the heating unit. However, there is no paper stuck at the heating unit and I can't find the...
Open the front door,remove the fusing unit(1 screw,2 connectors,ground plate wire in the back side),remove the exit lever(in this components is the exit paper actuator black colour in the right side).Change the actuator(it is damaged),and OK.
Dec 02, 2010 | Minolta EP4000/5000 CS/PRO Copier
Error Code C 099b
I can't locate that exact code, but C09XX are paper feed section codes, check the paper sources for properly loaded paper, also does the size of paper in the drawer corospond correctly to the size displayed on the control panel?
If you have adjustable trays are the edge guides against the paper?
Does there appear to be a double or stream feed?
Are any of the pages damaged before they were removed?
Mar 30, 2009 | Minolta EP4000/5000 CS/PRO Copier
Both paper cartridges malfunctioning of minolta 4000 (i dont know the solution)
Do you see a small wrench in the bottom left corner of the displa pannel? If so press the wrench and the display will change then open and close the front door and try to open the paper trays. If it dose not work you may have more then a basic problem. Good Luck
Mar 06, 2009 | Minolta EP4000/5000 CS/PRO Copier
EP4000 Back to back copying paper jams
THE INK MAY NOT BE TOTAL DRY WHEN MAKING BACK TO BACK COPIES, SOMETIME YOU NEED TO LET THE PAPER TONER DRY, LET THE PAPER COOL OFF BEFORE PUTING IT THREW THE MACHINE AGAIN, AND I KNOW ITS A PAIN IN THE BACK SIDE.
TRY IT
CANDYMANGANDY
Jan 28, 2009 | Minolta EP4000/5000 CS/PRO Copier
EP3050 error code C0040
A C0040 error code indicates a problem with the suction deck fan. It has nothing to do with the paper lift motors.
The fan is accessed by removing the rear cover of the copier. It is right in the center. These are readily available (p/n 9313-1310-61) although they are not cheap (around $200 retail).
Nov 15, 2008 | Minolta Office Equipment & Supplies
Hp 4700n
Have you would try a different paper cassette.
Usually that clunking noise is associated with gears not mashing.
Is the lifter lifting the platform or not?
There might be something above the paper tray, maybe even the paper input assembly preventing the paper platform from reaching the top.
Check these and let me know what happens.
Oct 03, 2008 | HP LaserJet 4700N Printer
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
