Question about Altec Lansing ADA 890 Computer Speakers
The soun bass is going down and desapear after 1 minute and back any momoent and again disapear
  • 27,725 Answers
If you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Posted on Apr 07, 2011
No sub woofer output or very little
Your sub amplifier is detecting an overdrive condition and reducing volume to prevent the output stage from burning up. When reduced volume doesn't work, output is cut completely for 10 minutes until things have cooled down.
Mar 27, 2017 | JVC KD-R740BT
Picture disapears after few minutes
I think the electronics inside it have failed. My guess is that because its the picture only, it will fail in the same way if you play dvd into it for the same amount of time. The failure happens after it has warmed up, if you take it out into the cold you may get 1 minute more before it fails.
It needs replacing, its not cost effective to repair something like this, the failed parts may have partially damaged other parts in the unit so they could fail after a repair.
Dec 19, 2013 | Televison & Video
Hi there I have an RAB030F clarion stereo in the car i just bought and no one can figure out how to change the time...any suggestions?
Setting the Clock
:$To turn the Power off, Press the POWER button ,) press and hold the BAND button a,wh ile
again. pressing the Function button 1 a to enter
2) Use the Up and Down buttons to adjust the clock display mode.
the volume. 2) Press and hold the BAND button m, while
A : Increases the volume. pressing the Function button 1 for 2 sec-
V: Decreases the volume. onds or more. This enables clock editing.
,#A Ci'4UTlOM
Audio Mode Adjustments
1) Press the AUDIOMODE button to select
the adjustment mode. The mode switches as
follows each time the AUDIO MODE button is
When this unit is turned on, starting and stop- pressinq the Function button 1 at the same
pressed:
BASSrrREB + BAUFAD -B Previous mode
2) Use the Left and Right and the Up and Down
buttons a, to adjust the bass and treble.
-=Adjusting the bass>
bb : Bass gets stronger.
4: Bass gets weaker.
-=Adjusting the treble:,
A: Treble gets stronger.
V : Treble gets weaker.
3) Use the Left and Right and the Up and Down
buttons a, to adjust the balance and
fader.
<Adjusting the balance>
W: Sound from right speakers gets stronger.
44: Sound from left speakers gets stronger.
<Adjusting the fader>
A: Sound from front speakers gets stronger.
8 : Sound from rear speakers gets stronger.
*The editable fields will be indicated by flash.
3) To move between the hour and minute fields,
use the Left (hour) and Right (minute) buttons
a.
4) To.store the clock setting, press the BAND
button a.
Aug 16, 2010 | Clarion RAB030F
TV Powers off
tap on the power supply borad not to hard
and have some one let you know if pix fark out
go all thur all the board soune like you have bad solder jonts
Aug 12, 2009 | Televison & Video
Gain conrol problems
relatively simple 2 leg pot. fix.
Under $50 to repair.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 03, 2009 | Jl Audio 500/1 Car Audio Amplifier
Motor fires off great and run good but at full speed after 15 mins it dies and won't start after 10mins it will start but at hight speed only after i get it going run good at 1/2 speed
What Year? Have the coils checked, they are located under the flywheel, some have been known to act up over time due to heat because of age. They time between dieing and restart souns like they had time to cool off until overheating again
Apr 17, 2009 | Light Outboard Motor Boat Bass Fishing...
RCA LCDX2620W 26 in
Hi this is Matt, some units have fans in the back, if you can open it and look in the back, also make sure its free of dust in the back, this can be from overheating, also bad solder joints on the power to the lights in the screen, can be this, you may need to replace the board, feel free to get back to me
Oct 26, 2017 | RCA LCDX2620W 26 in. HDTV-Ready Television
Bass problem
You're getting some sort of capacitor discharge noise on your signal. There's no easy fix for that. It will have to be taken in for service.
Mar 16, 2008 | JVC RV-B90 Boombox
White noise on screen with screeching sound
white unstable lines plus screeching noise it basically due to loose contact at input 1 like antena or cable wire or socket loose. 2 loose contact some where in your tv. 3 loose contact in some electrical thing. 4 loose near tuner section. hope this will help.
Oct 01, 2007 | Toshiba CF32F50 TV
Altec Lansing ADA 890 Computer Speakers Logo
47 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
