Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Craftsman 17hp 42" cut riding
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 27 Answers
I had the same problem right now I'm looking to see what it is called but if you are not getting any spark check the flywheel and the magneto what I did is took the magneto off and tightened back when if did I made sure I pushed the magneto against the flywheel. Then I made it turn and it started
Posted on May 20, 2014
  • Logan Burkes May 20, 2014
    Sorry that was for a 18 hp gt 6000
  • 608 Answers
Sounds like its not getting enough fuel. clean the fuel system and the carby. The valve clearances also need to be checked.
Posted on Apr 11, 2011
  • richardtl72 Apr 11, 2011
    When I worked on it previously I drained off all the fuel and cleaned the carb with come carb cleaner and a toothbrush. I can smell the fuel coming out the exhaust so I know it's getting in. During one of my attempts to start it I sprayed a light stream of carb cleaner into the carb hoping to help it start but it only backfired on me.
  • Phil Walker
    Phil Walker Apr 12, 2011
    Check the valve clearances and compression. Also check that the flywheel key has not shared. If all that checks out have the CDI unit tested(kohlers are renounced for them failing)
My 24 hp 42 inch craftsman lawn tractor starts fine but continually backfires when running, plugs are dry and carbon free, air filter clean, any ideas on what I can do?
Yes I would figure out who made the motor, B&S, Kawasaki, Kohler, Tecumseh are common. Go to their website, find your engine model number and get the valve clearances. Find a mechanical person in the neighborhood, avoid brothers-in-law, and give him a 12 pack of beer to adjust the valves for you. I think you will find your mower runs way better, backfiring will be gone. After 100 hours or 3 or so years you will note most of those companies recommend an adjustment. You most likely have a 2 cylinder and there are two small rocker covers near the spark plugs, Pull off the covers and the rockers will be exposed. Adjusting the gap between the rocker and the valve takes some skill and understanding of where the pistons are in relationship to the valve train and doing it wrong can be expensive. I know there are many videos on youtube if you want to take it on yourself.
Sep 13, 2011 | Craftsman 42 in. Precision Cut Plus 24hp...
Craftsman lawn tractor 917.271060w/kohler 15.5 hp engine cranks but backfires thru carb and wont start.
my 15 hp kohler engine backfired while i was using it, now it wont crank and backfires thru carb
Oct 10, 2010 | Craftsman Garden
I have a craftsman Dlt 3000 riding mower with a 20hp kohler v twin . engine starts and runs for 5 seconds and shuts off
no model # on my DLT3000. Replaced rear fender a few years ago where the model # used to be. I can't get the right parts w/o model #. It was by my dad sometime between '04 and '07. It's red w/42" cut, 20hp koler pro motor.
Sep 18, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman riding mower-what year was it made
Hello! The 917= American Yard Products...A major supplier to Sears...The first six digits of the SN#...00/00/00= date of manufacture...In your case...May,1,1997...
Guru.....................Saailer
Jul 08, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Tractor wont start
For a small gas engine than won't start, think FAST -- Fuel, Air, Spark, Timing. You've replaced the filters and spark plugs and squirted in some starter fluid, eliminating the simple common fuel, air, and spark problems -- but I because of the backfiring I think your problem is in the timing -- like a sticking valve. Probably more than you want to tackle at home, but might not be as expensive as an engine replacement. Take it to a good small engine mechanic -- best bet is a lawn equipment shop that has been around many years. Drive a little farther to get to one if necessary.
Jul 02, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My craftsman 15.5HP kohler riding mower turns over
Try cleaning or better yet, replacing the spark plug. Depending on age and how your tractor was maintained, there are other possible causes.
  • Gummed up fuel system
  • dirty fuel filter
  • defective or misaligned armature/magneto (part that causes your plug to spark, igniting the air/fuel mixture, thus starting the engine)
  • throttle linkage/cable problems
  • low oil level. Some Kohler engines use a low oil shut down sensor which won't allow the engine to run or start to avoid internal damage.
  • Mechanical engine problems
I hope you find this solution helpful. Please rate it thanks for using Fixya!
Nov 05, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I need a diagram for a Kohler carburetor on my Craftsman riding mower, 17HP. WHere can I get one?
I dont see any Diaphram listed. I would go to your local Yard equipment Dealer that handles Kohler. but my reference books show no diaphram or even a model ca
Sorry
Oct 19, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Have 2 craftsman riding mowers 42"cut one 16,50 kohler engine/the other 17hp. both have the same symptoms won't start tried plugs primed cylinders with starter fluid also gas, seems like they have no spark...
Take spark plug out ,put sparkplug wire on plug and let it lay against block. Watch to see if plug fires. If not change coil. Hope this helps.
May 18, 2009 | Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
577 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
