Question about Sylvania LD320SSX LCD TV
When I turn on my Sylvania TV model number LD320SSX, it just flashes various colors: white, Blue, Black, Red, Green. It wont turn off either the volume and Menu
rulds2008
  • 3866 Answers
SOURCE: I need the code to program my comcast remote for
Because each code is not unique and diffrent remotes have diffrent codes for the sae TV I would call comcast and have them send you out the remte manual. You did not tell me witch cable box you where using too so its hard to tell what remote your using.
Posted on Sep 23, 2009
hmerchant110
  • 7191 Answers
SOURCE: I have the Direct TV
You can program the Direct TV remote to control your TV by using the below steps:
1. Turn on the TV
2. Slide the MODE switch to the TV position.
3. Press and hold the MUTE and SELECT keys at the same time until the green light under the TV position flashes twice, then release both keys.
4. Using the number keys enter the 5-digit code (20675, 21268). If performed correctly, the green light under TV flashed twice.
5.Aim the remote at your TV and press the PWR key once. Your TV should turn off. If it does not turn off, repeat steps 3 and 4, trying the other code.
6. Slide the MODE switch to the DIRECTV position. Press TV POWER. Your TV should turn on.
For further details and programming procedures and codes, you can download the complete user manual for your remote by clicking this link
You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from:
http://get.adobe.com/reader/
Hope this solves your problem. For more help and clarifications, please reply to this post. Thanks for using FixYa.
Posted on Nov 28, 2009
  • 27 Answers
SOURCE: Sylvania LD320SSX turns off by itself.
your powersupply is dying in the set.. have it checked..
Posted on Apr 10, 2010
  • 8457 Answers
SOURCE: I have a lc320slx sylvania tv and I pushed some
This problems will not be solved by a remote control.Ur tv Tuner board is dead.Take it to the shop they will order a refurbish the Main Tuner signal board for u and replaced it.It will cost about half the price of the new tv.
Posted on Apr 28, 2010
SOURCE: Need code for dish network remote for Sylvania
hi! i have here a couple of codes for your sylvania TV, just try them, 1004, 1007, 1018, 1027, 1047, 1056, 1057, 1059, 1060, 1061, 1103, 1124, 1145, 1150, 1153, 1279, 1296, 1387, 1464, 1483. this is for sylvania HDTV 1046, 1465. this is for the tv/dvd combo 1150, 2092, 1464, 2408, 1465, 2260. this is for the TV/DVD/VCR combo 1027, 2064, 3105, 1124, 2078, 3088, 1296, 2213, 3147. this is for the TV/VCR combo 1145, 3095. hope this helps!!!! goodluck!!!
Posted on Jun 09, 2010
My flat screen Sylvania TV is flashing different colors what's wrong
Better late than never. The problem is that your TV is in the service mode. There are many ways this can happen. But, lets just get down to fixin this! With the original remote and the TV on. If the TV will not shut off, do this. Press the left cursor button on the remote, followed with pressing the right cursor. Power off the TV with remote, or press off button on TV.
Secondly, your TV will power on and off. But you have flashing colors. Do this. With the original remote and TV on. Press the up cursor button, on the remote, followed with pressing the down cursor. Power off TV with remote, or press off power of TV. Thanks for asking me, Matt of Martins TV Repair.
Jan 20, 2016 | Sylvania Televison & Video
Screen flashing colors
trying to find out myself came home today my trv doing the same thing not only does it not respond to the remote the buttons on the tv does not either
May 24, 2013 | Sylvania LD320SSX LCD TV
Screen only flashes colors, no controls function
remove power from the set and any box being used with it, after a while power both back up, a box or the set can cause this issue.
Dec 18, 2012 | Sylvania 32" Lcd Hdtv Dvd Combo - 720p...
Blue red and green screen
I too have this problem and am unable to find a solution. Someone please post a fix for this issue if possible??????
Jun 30, 2012 | Sylvania LD320SSX LCD TV
Flashing 3 colors red, green and blue to turn it off I had to unplug it. Trying to switching from TV to DVD. This have happened before. I don't have a remote but the service man reset it some how
Download the user manual to your TV. It will have all details about how to reset it to factory default. A factory default set should be done now. To download its user manual, click here.
Jun 21, 2012 | Sylvania LD320SSX LCD TV
My LCDTV has a problem, Model number is 6626LCT, Now on to the problem, While doing yearly cleaning on my tv as normal, after i plugged it in it was normal for 40 seconds, It flickered and the screen went...
Only suggestion is if set was plugged in when you did what you did--unplug it and any box or receiver plugged in and wait a while--plug back and let the equipment try to reboot.
Jun 06, 2012 | Sylvania Televison & Video
Sylvania LD320SSX 32-Inch 720p LCD HDTV/DVD Combo fails to turn on(power light flashes green, turns solid green 10-15 minutes then red). Leading up to this condition it would take several attempts to turn...
You checked for bad capacitors, but did you check for bad soldier joints?
I would start there. Also, be prepared to replace the Power Supply Board.
Aug 30, 2011 | Sylvania LD320SSX LCD TV
Apr 10, 2010 | Sylvania LD320SSX LCD TV
Sylvania LD320SSX LCD TV Logo
35 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
