Question about Frigidaire FER231A Electric Dryer
Dryer will not heat up but element is intack an has good connection
  • 3 Answers
On the back under the back panel there is a sensor wit 2 wires going 2 ti these r the most commen part to go bad.
Posted on Apr 07, 2011
Does not heat up
what type of dryer rate these
Open The Cabinet
  • Unplug the dryer's power cord from the electrical outlet. Remove the toe panel by inserting a putty knife between the toe panel and the front panel. There are retaining clips 4 in. from each corner. Slide the putty knife blade over each retaining clip and pull the toe panel away from the dryer.
Test the Heating Element
  • If you own an electric Whirlpool dryer, locate the heating element. The heating element is the workhorse of the heating operation. The heating element is most often inside a can. The thermostat mounts to the side of the heating element can in most Whirlpool dryers. The thermostat looks like a small oval part with two wires connecting to each side.
    Pull the two wires that connect to the heating element terminals. Set a volt-ohm meter to the RX1 scale to check the continuity of the heating element. Clip each probe from the volt-ohm to each of the heating element terminals. A good element will give you a reading between 8 ohms and 12 ohms. If you get no ohm reading, the heating element is faulty and you will need to replace this part.
Jan 15, 2013 | Dryers
Maytag dryer heating element won't come on
you should have a nominal 240 volts between the 2 heating element connections
Feb 07, 2012 | Dryers
My dryer is turning but the clothes are not drying. There is no heat in the dryer.
Check the dryer heating elements that they are intact. You will have to open the back. Chek for fuses in the dryer. Good luck
Jul 02, 2011 | Dryers
My dryer wont heat up its not the heating elment
If the heating element is good, then you need to check the voltage to the element. I would first check voltage at the heating element connections, should be 220 volts.Then work back through the start switch and dryer selection switch.
Jan 10, 2011 | Dryers
My GE dryer, Model no. DDE7200SBLWW, does not produce any heat. I cleaned all the lint, and have good airflow. All of the thermostats (4) tested good as well as the thermal fuse. With the dryer running on...
do you have 3 terminals to the heating element,if so check the neutral terminal,if this terminal breaks from heat stress the element can't function,not all have 3 terminals,if only 2 terminals then make absolutely sure theres 240 volts across these terminals,if not it will not heat,if you have some jumper leads of the correct size,bypass all thermostats,cycling switches and the thermal fuse just to make sure they metered out as good,also just to be sure check the terminal block where the power enters the unit for any high resistance or burned connections,if theres a hi resistance it will show 240 volts on a meter,but you won't get enough current thru the connection to properly heat the element,also flip the breaker on and off as these can be spookey at times too
Nov 21, 2010 | GE Dryers
Dryer will spin but not dry , heat element is fine
Try replacing the high limit switches if the element is fine. The limit switches will not allow power to the heat strips if they are blown. They are the little silver buttons on the heat strip. There are usually two wires connected to them one coming from the controls and one from the heat strip itself
Dave
Mar 05, 2010 | Magic Chef CYE4000AWW Electric Dryer
Kenmore dryer makes no heat
replace the heating element. Or the control panel has weakening capacitor not sending correct current flow to the heating element
Jul 09, 2009 | Dryers
NOT HEATING UP
Better you can check all the following -
If your dryer doesn't heat, check these:
Power from the house
Heating element
Thermal fuse
Wiring
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
good luck......
Mar 29, 2009 | Dryers
NO HEAT
Check for 220 volts incoming at the terminal block where your cord connects.
Make certain the dryer wiring is good there also.
Check the heating element to a ground on the dryer.
Check the continuity tthrough the start switch on the motor.
for the heater wire connection.
Mar 09, 2009 | Whirlpool LER4634J Electric Dryer
Admiral Dryer will not heat
Bad connection
this wiil cause this make sure to use a Hi Heat connector abnd the connections are tight
Apr 27, 2008 | Whirlpool LER5636P Electric Dryer
Frigidaire FER231A Electric Dryer Logo
46 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
