Question about Garden
Mower starts fine rpms are good then when I engage the mower it loses power.still cuts but loses power.Plug is good.
  • 577 Answers
Do you have fresh gas or is it left over from last year? if mower has a choke lever try putting choke on 1/2 way and see if that helps it run better. If that helps then you need to clean your carb, dissemble it and clean good with carb clean and take a bread tie and burn the coating off it and use it and carb clean to make sure all jet holes are open and your inlet screen is clean also remove needle and seat and check them, might as well replace them while you are there, what happens is the needle is neopreme and with todays gas it makes it swell up and deteriorate,therefore less fuel is available and engine runs lean...good luck
Posted on Apr 07, 2011
    President:
  • 1,273 Answers
Hello, W/D here.
A partially plugged air filter will cause this to happen. Check this and clean or replace if necessary.
Best regards, --W/D--
John Deere loses power under pressure what can cause this
what is the unit? have you checked fuel filters air filter? is the tank outlet blocked with debris?
Sep 14, 2014 | Garden
Why doesn't my Toro z master PTO not engage
check to see if pto will engage if not check voltage at pto if non blown fuse if fuse not blown and power to pto bad pto jump the pto at pto with battery in mower does it start pto if does good pto have to check volts at switch check there start with that let me no what happened
Sep 04, 2014 | Toro 60'' Com Zero Turn Lawn Mower 27hp...
Why does the engine slows down when engaging the blade
check fuel filter and pump pressure starving for gas
Jul 02, 2014 | John Deere Garden
Husqvarna riding mower smokes when cranked and dies when engaging blades
If it dies when engaging the blades it's not getting enough juice to do so. Test the battery and make sure you are getting at least 12 volts. If not, charge it. If so, the solonid is going bad.
Apr 13, 2017 | Husqvarna Garden
Motor chokes and misses under moderate load and loses power
Sounds to me as tho it might need a carburetor adjustment, providing there is an adjustment screw on the carb. Sounds like the engine is running a bit lean. Did this problem occur right after the carb cleaning, or was it there in advance? Is there a fuel filter that might be clogged?
Jan 18, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Loss of power when engaging deck
check your compression. if you have a two cyl engine, start it and ground out each cyl (or pull off the plug) see if engine changes the rpms if one don't change check spark and compression on that side. if you only have one cyl go back to checking compression. get back to me with what you find. ps check your belts to mack sure nothing is in the pulleys like a stick and check under your deck to make sure you don't have a grass build up.
May 12, 2009 | Craftsman 42 in. Precision Cut Plus 24hp...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
