When started the computer, it is working fine for some time. After some time, my mouse light went off and pointer in display screen is hanged. Then, computer is standstill without functioning. How to solve my computer problem?
    Problem Solver:
  • 16 Answers
Is it only the mouse that is not working? Is the computer answering the keyboard? If so, simply change the batteries in your mouse.
If the keyboard is not working, you will need to restart your system. To do so, hold down the power button (the one you use to turn on the computer) for about 5 seconds, until the computer shuts down. Then, wait a couple of seconds and turn it back on.
If this doesn't work, we will need more information.
  1. What were you doing when this happened?
  2. What Operating System do you have?
  3. What is your mouse model?
  4. What is your computer model?
Posted on Apr 07, 2011
    Problem Solver:
  • 5 Answers
Check power supply or memory,first try to replace the PSU or memory with a good one.check connections.
Mouse pointer disappers
I've seen this happen a couple of times when Word uses the initial preview "Read Mode" or Protected View . Try changing the mode by clicking on the View tab and changing the mode to Print Layout. When it happens to me, that seems to do the trick. If you don't want Word to use the Protected View, go into the Trust Settings for Protected View and uncheck the options in there...this may also keep it from happening in the future...good luck! :-)
Apr 24, 2014 | HP Pavilion 23xi 23" LED LCD Monitor -...
Samsung laptop cursor tweeking
Step 1
1. Open Mouse by clicking the Start button, clicking Control Panel, clicking Hardware, and then clicking Mouse.
2. Click the Pointer Options tab, and then do any of the following:
To change the speed at which the mouse pointer moves, move the Select a pointer speed slider towards Slow or Fast.
• To make the pointer work more accurately when you're moving the mouse slowly, select the Enhance pointer precision check box.
To speed the process of selecting a choice when a dialog box appears, select the automatically move pointer to the default button in a dialog box check box.
To make the pointer easier to find when you move it, select the Display pointer trails check box, and then move the slider towards Short or Long to decrease or increase the length of the pointer trail.
To ensure that the pointer doesn't block your view of the text you're typing, select the Hide pointer while typing check box.
To find a misplaced pointer by pressing the CTRL key, select the Show location of pointer when I press the CTRL key check box.
Change mouse settings
http://windows.microsoft.com/en-US/windows7/Change-mouse-settings
Step 2
If you are using touchpad, try reducing the Touchpad sensitivity and check
1. Click on the "Start" icon in the lower left corner of the screen. Select "Control Panel." Next select "Mouse" under "Hardware and Sound." You can also left-click the touchpad while the cursor is anywhere on the desktop. From that screen, choose "Mouse Pointers."
2. Select the "
Buttons" tab at the top of the dialog box that opens. This shows the type of touchpad device installed on your laptop.
3. Set the touchpad for right or left-handed use from this dialog box. You can adjust the double click speed of your computer as well. When you finish making any changes, click "
Apply."
4. Pick the "
Device Settings" tab from the dialog box now. You can see the touchpad for your Vista machine highlighted on this screen. Select "Settings."
5. Read the information provided in the next dialog box. It gives you options for tapping your
touchpad, using the buttons, scrolling, pointer motion and sensitivity.
6. Make any changes you want from the various topics. When you make a change, click "
Apply." Click "OK" when you finish making all your changes.
7. Do some work on your computer for a while, If the touchpad is still too sensitive, return to the "Mouse" menu and continue to adjust the settings until you get them just the way you want them.
Step 3
If the issue persists try to perform a clean boot and check whether the issue is still persists.
Follow the steps mentioned in the article given below.
How to configure Windows Vista to start in a "clean boot":
http://support.microsoft.com/kb/929135
Note:Once the troubleshooting is over, reset the computer to start as usual.
Also I would suggest you to keep in touch with mouse manufacturer
Oct 10, 2012 | Samsung SENS R460 LAPTOP LCD SCREEN 14.1"...
After Starting computer keyboard & Mouse get hang most of time. plz give me solution.
try blowing out all of the dust from your keyboard using a fine air blower from an air compressor making VERY sure there is no MOISTURE in the lines.
dust causes static which causes lots of problems with a computer and its parts
or
you might have to many programs loading at start up or you might have a virus run your antivirus program looking for a virus then
try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
as for the mouse
control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot or select properties under driver you can update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
hope this helps
Nov 24, 2010 | IBM Lenovo Mouse 76H6618
Mouse will not click buttons / Task manager allows mouse to work
remove the mouse and plug it again. go in setting of mouse control the speed and all if the same the test the mouse in different pc. if that time also same then your mouse not good. buy a new 1 or put it in a service center.
Jan 29, 2010 | Computers & Internet
Mouse Pointer Disappears
Run a dianostic on your memory or add more to the system
Mar 30, 2009 | Microsoft Wireless Optical Mouse
I have LG 700S 17" Monitor
Try tapping f8 when you start your computer and when at the MS startup menu choose
  • Enable low resolution video (640x480)
  • and if windows starts update your video driver and that should fix the problem, when you restart more than once the options go back to default (not low res video,whatever video driver is installed)
    Mar 12, 2009 | LG Studioworks 700S 17" CRT Monitor
    MS Wireless IntelliMouse 2.0 pointer direction reversed (up/down)
    Go into the control panel and click on the mouse icon and see if you can change to settings back to normal.
    If not then check under your start menu and see if the intellimouse software is installed there and go into it to change the settings from there.
    Feb 14, 2009 | Microsoft Wireless IntelliMouse Explorer
    Black screen with only mouse pointer
    well try to start pc in safe mode you can do this by pressing F8 key at windows startup after this remove your display(VGA) driver from device manager and then try to start window normaly if its start normaly then you have problem with your VGA.
    And if its does not work then try to reinstall your windows
    some times Asus and Msi motherboards have this problem,do nt know wthats is yours
    hope you have got answer
    regards,
    Ali
    Oct 30, 2008 | Computers & Internet
    Computers & Internet Logo
    52 people viewed this question
    David Payne
    David Payne
