While replacing the drum a thin metal pin connector fell out. Where does it go?
    New Friend:
  • 140 Answers
Yes you can fix it. in drum.
Posted on Apr 07, 2011
Hello......can anybody give any solution for this problem : my VGA Cable disconnect from the 15 Pin gents connector of Crt monitor of philips model no. 107E61 I want to fix it but I could not understand...
These connectors come with 15 pins and 9 pins. But be carefull, the nine pin connecter uses a tottaly different color code. Thats for an oldschool gamepoort or midi connector. But I think the vga connector has 3 rows of pins total of 15. But the nine pin connector has probably two rowes of pins. And thats no vga connector, but an connector for an serial port.
If it has three rowes (see Fig-2 below) but uses 9 pins then its an RGB instead of VGA.
Fig-1
Fig-2
Fig-3
Mar 19, 2017 | Cars & Trucks
In iphone4 speaker sound not working
The speaker is sometimes disabled when you connect the 30 PIN sync chord. If the 30 PIN connector is damaged, it can cause the speaker to not work, or to work intermittently. Try using a thin object (like a safety pin or something similarly thin, preferably something non metallic and non conductive) and gently jiggle the 30 PIN connector on the iPhone while playing a sound, (like a music file in the music player). If the sound starts playing again you have found the cause of your problem. Unfortunately if the connector is the problem you will need to be careful in the future when you disconnect your sync chord.
This is most often caused by placing the iPhone into a sync port designed for the iPhone 3GS and earlier models. The iPhone 4 and later needs support to keep it from straining the 30 PIN connector on the iPhone 4 or iPhone 4S.
Good Luck.
Apr 08, 2014 | Cell Phones
Sharp AL-1655 CS copier - machine is 4 years old and has new TD cartridge. It was dumping excessive toner which I cleaned up. Also, made grinding noise. When machine opened and TD cartridge removed, I...
The part that you are talking about is not from the fuser unit. It is from the drum unit, it is most likely the primary charge grid. It is part of the drum that charges the drum..... You may just want to replace the drum unit..... If the grid fell off the plastic holder may be broken... Good Luck
Mar 31, 2011 | Sharp Office Equipment & Supplies
When I put the cartridge back in the copier, a long thin screen fell off. It is about as long as the cartridge and about a half inch wide. I do not know if it fell off the cartridge or if it came off the...
This screen sounds like the charge corona grid. The grid is about 1 inch wide and a foot or so long. If so then it came out of the drum cartridge. If you look at the top of the drum cartridge, there is kind of a chrome metal bar with plastic "blocks" at either end. This is the charge corona assembly and that is where the grid fell off.
You can try to install it or as you suggested you can just replace the drum cartridge.
Good Luck and Thank You for using Fixya.
Sep 25, 2010 | Sharp AL 1631 Copier
Of glass defroster rear of my car chevrolet cavalier 2004, is not working I checked the fuse box and are well need help to fix this.
Check the bigger metal leads that connect up to the thin rear defroster grid. Often there are crack lines that result in no electrical conductivity. There are repair kits available to remedy this or you can try to carefully re-solder the bigger leads but you may need the kit for the thin lines.
Dec 03, 2009 | Chevrolet Cavalier Cars & Trucks
LE light is displaying and there is a metal on metal sound when it tries to spin after a rinse. Drum wont spin
It is a locked motor error. One of the following is causing the problem but you may need the help of a qualified appliance technician:
  • The connector (3-pin, male, white) in the motor harness is not connected to the connector (3-pin, female, white) of the stator assembly. Connect them properly.
  • The electrical contacts between the connectors (3-pin, male, white) in the motor harness and 4-pin, female, white connector in the main board assembly is bad or unstable. Trace the motor harness back to the main board. Clean the connectors and connect them properly.
  • The motor harness between the stator assembly and main board assembly is cut or open. Reconnect or rewire.
  • Motor winding is defective. Check the resistance between the terminals of the stator. Resistance should be between 5 to 10 ohms, otherwise replace the stator. Refer to the illustration above for the stator removal.
  1. Disassemble the back cover.
  2. Remove the large bolt on the center shaft. Ask your helper to hold the inside of the drum.
  3. Pull out the rotor out of the shaft.
  4. Remove the 2 screws from the tub bracket.
  5. Remove the 6 bolts on the stator.
  6. Unplug the 2 connectors on the stator.
  7. Pull the stator out of the tub.
  • The hall sensor is out of order/defective. It is located at the stator assembly. If the hall sensor is out of order, it cannot detect magnetic field and the main board sees it as the rotor is locked then displaying the error code. Replace it if no evidence of defect is found above.
Nov 25, 2009 | LG WM1814CW Front Load Washer
When I apply the brakes on my '02Dakota only the forward brake shoe moves against the drum. Have replaced wheel cylinder but makes no difference. Both shoes move when I loosen adjuster cable. Have this...
you mean parking brake cable? loosen parking brake cables put drums on , and adjust shoes till they lightly drag, now apply brakes a few times and check the adjustment again, if all ok, now adjust park brake cables, you want to adjust so park pedal goes 5-8 clicks till the wheels are "locked up" and the wheels spin free with the park brake off
Oct 18, 2009 | 1992 Dodge Dakota
Wire fell out of my sons drum set. it's the symbol wire
I just fixed this problem on our WII drums, the entire connector was ripped off the wire. You can get a repalcement jack at Radio Shack (pair is $4). You will have to carefully strip the shield and center conductor, tin with soldering iron and install new jack. Make sure you put the connector shell on the wire before you install the metal jack. Works like new.
Jul 04, 2009 | Nintendo Rock Band for Wii
Whirlpool top-load washer
from the top and if you dont have the spanner wrench to remove the tub you are headed for a much bigger problem.Note:the spanner wrench ranges from $29.95 and up if you can find one less grab it and re- post this problem and i'll take you through the repair .
Please rate This !!!! Thank you!
Jul 25, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Parts fell out
WE FIXED IT!!!!! Ok my fabulous husband fixed my automatic thread foot last night and now I am sewing away. Here is what he did best I can describe. when you engage the thread shuttle, a piece comes down from the right of the sewing machine. I has a spring on the back and a very thin piece of wire with a white plastic moving part. the foot has to snap under the white plastic thing... so you have to very carefully take the white thing out of the track and then put the foot in. the bar side with the larger metal pin goes here and the foot should be facing towards the needle. Hope this helps and if I didn;t explain it well please leave me a note and I will try again :)
Apr 18, 2008 | Brother SE-270D Computerized Sewing...
13 people viewed this question
k24674
