Question about Gateway Computers & Internet
I don't have a any problem with my system, but i have a question with my FHD2400 wide screen LCD monitor, will it mess up my monitor if i hook up my playstation 3 to the HDMI spot, while keeping my computer hooked in to the DVI spot, and running both at the same time and just switch between the 2 using the monitors menu video inputs
  • 37 Answers
Hi
Sure you can do that it will work fine.
T.Boopathy
Posted on Aug 06, 2008
Hi I have a Gateway FHD2400 LCD monitor. Everything work fine but all buttons (inlude power and all select buttons) doesn't work.
If the control panel for the monitor does not respond there is no way to replace this. The monitor would have to be replaced if you desire that functionality.
However if the monitor turns on (without the need of the power button) and you do not need to adjust any of the settings then I would use the monitor until it could no longer serve its purpose.
Check the warranty status of the monitor and if it is under warranty you could get a replacement with a properly functioning control panel.
Feb 08, 2011 | Gateway FPD2275W LCD Monitor
Gateway FHD2400 flickering / blinking / flashing on and off whether connected to laptop or not. Only had the monitor for about a year, and I've barely used it. I connect it to my Mac Powerbook, and after...
Open the monitor, examine the circuit boards. Look for small components that look like small cans, these are capacitors. If you see any that look bulged on top, then your problem can probably be solved by replacing these. Check out the following sites;
http://www.youtube.com/watch?v=9Q6_TgNJvQw
Follow the directions and good luck!
Jan 18, 2010 | Gateway FHD2400 24 in. LCD TV
We don't get any sound from the monitor, Why?
This monitor doesn't have any internal speakers. You either need to buy some external speakers, or plug headphones into your computer.
May 15, 2009 | Acer X193W LCD Monitor
You need to set the monitor up. I have a 42" LCD TV, and there is a menu where you can set the aspect ratio to 'Auto', 'Full Screen', or "4:3". I had a similar issue with my DVD player. I'm sure if you go through your monitor setup menu, you should be able to solve this problem.
Apr 17, 2009 | Video Game Consoles & Games
Gateway FHD2400 24inch monitor HELP PLEASE!
well it's not the computer going to sleep but the monitor is (sort of) because your computer is telling to. it has to do with the Power Options (title dependent on OS - this is what it's called in Vista)
Go to Control Panel>>Power Options - on the left hand column click Choose when to turn off the display - I'm guessing you are set to 15 or 20 minutes for the Turn off the display dropdown - change it to something longer to satisfy your needs (Never is an option).
If you're not running Vista write back - it's slightly different but similar path.
Cheers.
Z
Mar 31, 2009 | Gateway FPD2275W LCD Monitor
How to stretch screen compaq tft5015
Right click the desktop - select graphic properties - you should have the option to stretch to fit or something like that. This could also be that your resolution doesnt match your monitor. usual wide screen monitor defaults are 1280/1024 or 1400/1068.. have a mess around and alter these - see which one fits.
Jan 25, 2009 | Compaq TFT5015 15" LCD Monitor
Dual Monitor Color/Brightness Differences
Correct the resoulution is not the same. Also you are using 2 monitors and using the system to power these great displays. Just dont hook up a docking station. The picture gets really bad..
Feb 13, 2008 | Computers & Internet
Computers & Internet Logo
50 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
