Question about Polar Exercise & Fitness
My heart rate monitor was working perfectly well and then the next day the screen on the watch was frozen. No indication of low battery etc (battery replaced 3 months ago). The monitor is about 18 months old. Help?
  • dear_patrici Apr 07, 2011
    No change. Screen on the wrist unit is still frozen.
    My heart rate monitor is a Polar FT80 if that helps at all.
  • 794 Answers
Hi dear_patrici,
If the Polar heart rate monitor's screen is frozen and seems like there's no reaction from any of the buttons when pressed you need to reset the wrist unit. To reset, just press all the buttons at the same time for 3-4 seconds. Your settings will be saved except for the time and date.
Hope it helps.
Thank you for using Fixya.
Posted on Apr 07, 2011
  • Jemalyn Labaguis Apr 07, 2011
    Hi dear_patrici,
    Kindly try once again doing this: pressing four buttons (UP, DOWN, BACK and LIGHT) on your Polar FT80 simultaneously for four seconds. You may also want to try to refresh the system by taking battery out and put it back again. If still this will not work then you might need to do a master reset on your Polar, this means it will be put back on it's default settings. For the process you have to contact their customer support. If you're in the US the number is 1-800-227-1314, from Monday to Friday 8:45 am - 5:15 pm EST.
    Hope it helps.
Polar ce0537 batteries
Hi Garry,
I suggest the first thing to try is to replace the battery.
It uses a DL2025 or a CR2025. Your battery should measure 3 volts, and should be constant. Some batteries will hold some charge, appear OK, but have no power and the voltage drops very quickly.
Check the replacement procedure for the battery. Check the battery flat metal holding strap is clean and in place correctly.
Make sure you can reset the time as this will indicate the heart rate monitor is working
Feb 04, 2014 | Exercise & Fitness
I just put a new battery in the Polar F4 heart rate monitor watch and it does not work. The battery died about 2 years ago and I never replaced it until now. How can I get the heart rate monitor working...
This is a common issue. The Polars and other Heart Rate monitors are not designed to be fixed by the consumers except for very specific models. These only look like watches, they are in fact mini computers and very susceptible to internal damage if not handled properly.
You need to send the unit it to a Polar Authorized Service Center to have fixed properly. There is not reset within the computer, if you had done everything correctly then it would work.
Dec 12, 2010 | Polar F4 Heart Rate Monitor Watch
The heart rate function has turned off. So the calorie count won't work. Everything else is working fine. It happened about four days ago. I have lost my owners manual.
Press and hold the reset button, for 5 seconds, while in Time mode. this will reset the heart monitor and the symbol will reappear on the screen.
Nov 26, 2010 | Sportline 915 Solo Heart Rate Watch
Heart rate writst watch won't work
Here is the manual for your heart rate monitor:
http://www.omronhealthcare.com/img/shop/hr-100c---2003-hr100cinst-rev-a.pdf
The size of your wrist shouldn't matter, because you can actually mount the monitor to a bike handle, so you don't have to be wearing it at all. It's just acting as a receiver, displaying the info. Are you wearing the transmitter belt, is it positioned correctly, and tight enough? Are you putting water or gel on the backside of the transmitter so that you get good conduction and contact? Is the transmitter belt within 20 inches of the monitor receiver display?
The transmitter battery might be low. If so, the symptom would be that your readings can be erratic. I know you said that you just bought it, but batteries can be low in new products. ..How many times have you bought a new digital watch only to find that it had a low battery...You can replace the battery in the transmitter with a lithium 3v battery #CR2032. Do you see a low battery indicator? If so, the display (receiver) battery also needs replacing and it uses the same battery as the transmitter.
Hope it helps, please let me know.
Thanks
May 09, 2010 | Omron HR100C Heart Rate Monitor
"LoBATT" stays on in TIME mode (doesn't flash) ?
"lobatt" display is the watch battery. The foot pod uses the LED to indicate low battery and the heart rate monitor wont give a reading.
Oct 05, 2009 | Garmin Forerunner 50
I have a mio euorfit heart monitor watch. During my workout I
Yes, you definetely need battery replacement.
As the hart rate monitoring is most sophisticated part of the device, it has more IC (Integrated Circuits) than any other features.
More IC's means more power is needed, so, if the heart rate monitor is starting to malfunction, that's the very first sign of underpowered battery.
Find your nearest watch repair shop and ask for battery replacement.
Do not forget to rate, please.
Jan 23, 2009 | Mitac Mio Fit Heart Rate Watch
Every heart rate monitor - replacement battery doesn't work.
This link might be helpful...under the picture of the given product click on "great information about this product" It gives all the specs and troubleshooting ideas. I hope this is helpful.
http://www.heartratemonitorsusa.com/Pages/TRANSMITTERS/T31-coded.html
Dec 06, 2008 | Exercise & Fitness
Exercise & Fitness Logo
207 people viewed this question
Top Polar Exercise & Fitness Experts
Jerry Greenberg
Jerry Greenberg
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Polar Exercise and Fitnes Expert? Answer questions, earn points and help others
