Question about Garden
I am having trouble starting my lawn trimmer. Its relatively new and I have changed the petrol to make sure its 'fresh'
  • 577 Answers
Purchase some carb clean and take your air box(filter) off and hold throttle wide open spray short burst in then try to start, if fires up and quits,try until it goes, prob have to work old gas through it, also make sure your primer is functional full of gas and works o.k.
Posted on Apr 07, 2011
Bulb will not fill with gas, had trouble last time of use but never before that 5 years old
talking lawn mower ot petrol trimmer --get a new bulb from any mower repair shop get a new diaphragm kit was well
Jun 03, 2017 | Craftsman 29cc 4Cycle Straight Shaft...
Dont start
If plug is not fouled and you have ignition, then the diaphragm (fuel pump) in the carburetor is no good. Try a carburetor kit . Caution - do not use compressed air or carburetor cleaner on these weed trimmers. Many employ one way check valves imbedded inside the carburetor by the primer bulb and the cleaners and compressed air can damage the valves resulting in carburetor replacement.
Nov 23, 2013 | Garden
I have a weed eater trimmer that wont start. ben sitting for a couple years and i replaced the fuel lines andcleaned the carb. still nothing, what do i do?
Try cleaning the spark plug, make sure it sparks. Put some fresh gasoline in the tank, check start stop switch.
A easy way to check whether the problem is related to carb or not is:
remove the spark plug put some fresh gasoline in the cylinder, put the spark plug back
pull the starter a few times if it starts for a few seconds it means is related to carb.
Be carefully when handling gasoline.
Aug 05, 2011 | Troy Bilt Tb70ss Gas Trimmer
Engine suddenly quit and will not restart or fire.
Hello. Begin by changing your air filter. If the air filter is dirty or has too much oil in it the trimmer will not start. Next, change the spark plug. Then check the fuel filter inside of the tank to be sure it is not clogged.
Finally, I do have a customer now and then who accidentally puts in the wrong fuel [for instance straight gas instead of the gas and oil mix required]. If this is a possibility, drain the tank and start over with a fresh gallon of gas and a fresh 2 cycle oil mix. Joe
Oct 24, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Mcculloch t 240 petrol will not start
If your petrol has been sitting in the machine for a long time then yes it is your petrol. Mix a new batch usually you cannot let that sit around for more than 30 days, I always try to use fresh mixes, usually that means making smaller batches unless you use your trimmer quite a bit, most people do not though and that's when problems arise.
Jul 04, 2010 | Garden
Engine cut out!
could have water in fuel bowl or tank,coil could be heating up and stop firing or the plug
Sep 09, 2009 | Garden
I have a rhobi strimmer only 2 years old wont start
I presume this is a petrol one. The fuel can dry in the carby and stop the unit from starting. Use fresh petrol.
I am not sure about the ryoby unit, but if there is a air filter, take it out and dip it in petrol, then try to start with the normal proceedure in the manual.
Jun 16, 2009 | Homelite Mighty Lite Lawn Trimmer
Ryobi line cutter - petrol lines all broken
Petrol lines disintegrate when fuel is stored in the trimmer for long periods of time. These can be obtained from any small tool repair store. Just remove them and install new ones. They just slip through the holes in the tank, re-attach the fuel filter on the supply line. Make sure that the line is long enough so that the filter rests on the back/bottom corner of the tank. Be sure that the lines are attached to the proper ports on the carb>
Dec 22, 2008 | Ryobi 15" Electric Factory Reconditioned...
Mountfield sp470
Hi, first you'll have to change the air filter and the spark plug. now, go buy some hi octane gas. drain the old gas and put the fresh gas in. if this don't solve your problem please write again.
Nov 20, 2008 | Garden
Garden Logo
957 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
