My epson won't wind the ribbon on and it keeps getting loose and not printing properly
    Problem Solver:
  • 5 Answers
Check if the ribbon gear assembly,Replace ribbon cartridge
Posted on Apr 07, 2011
My epson stylus cx6000 has stopped printing black. I've cleaned the print head, changed the cartridge and it still won't print black. What else can I do?
Be sure you are using genuine epson ink. Epson printers are "smart" and will not allow generic ink to work properly. Even after you replace a generic with a genuine it may take several print outs and alignments to get it to print again.
May 05, 2011 | Epson Stylus CX6000 All-In-One InkJet...
I just installed a new ribbon on my olympia deluxe and the ribbon keeps getting loose. Could that be because I installed the ribbon wrong? What could be the problem?
You probanly installed it wrong. Most T/W's spooled ribbons wind to the outside of the spool, however there were a few that wind to the inside. Withe the ribbon off type & watch the spool mech. install the ribbon so that it will wind onto the spool.
DickyO
Nov 09, 2010 | Olympia Office Equipment & Supplies
Ribbon feeds out with label
Your take up spool isn't working properly, bad motor or belt.
Oct 15, 2010 | Intermec EasyCoder PM4i Printer
Epson Artisan 800 continually indicating paper jam error--No jam.
Yes, that fixed the problem on my Artisan 800! Thanks so much for the info about slipping the cr scale back onto the u-guide on the back of the print head carriage, Larry P and dabaker!
For those trying this, the u clip is upside down so, from the front of the printer, you move the CR scale ribbon down a little and in towards you gently, in from the back towards the lower part of the rear of the print head assembly, and it will slip in on the top part of the ribbon into the u shaped groove (which, to be technical, looks more like an n-shaped groove, an upside down u). If it is loose and not clipped in, the CR scale ribbon will bow out easily on both sides of the print head carraige when lightly pressed towards the back of the printer near either side of the print head. (As pointed out in the service manual, do not touch the ribbon with your fingers, particularly if they may be greasy/greasty/gritty; use a clean tool for this-I used a q-tip which worked well for both testing the tension and for pushing it down and back into the proper guide slot.) If the CR scale ribbon is clipped in properly to the print head (properly seated in the n-shaped slot), it will bow towards the back of printer easily ONLY on the side that your press it from (ie left or right) but not on the opposite side of the carriage; the opposite side will remain almost entirely flush to the rear of the print assembly. Remember to press gently; you do not want to stretch or damage this scale ribbon if you can help it. If you have a small dental mirror and good light, you will be able to see the n-shapped clip (it's plastic and black on my 800 clearly. If the ribbon is correctly seated, it will be in the slot at the top and free at the bottom. Because of the use of u-slot in the previous posts, I was confused as to where to fit this in but then figured, nothing to lose and yep, it's actually the n-shaped slot at the top.
Jul 12, 2010 | Epson Artisan 800 All-In-One InkJet...
Brother SX 4000 stopped printing. Ribbon is
Remove and inspect the ribbon cartrige, wind the knob and make sure that the ribbon moves and reinstall. Check that the correction tape is installed properly. Check that the ribbon plate assembly is not in the correction position. Try CODE RESET (Q key)
Dec 22, 2009 | Brother Office Equipment & Supplies
RIBBON BECOMES LAX AS ALSO SLIPS OUT OF HEAD AND STOPS PRINTING ALTOGETHER. PRINTER LQ 300 +
make sure the ribbon you use it is genuine epson ribbon. and also adjust the liver by keeping 4 point .
Sep 08, 2009 | Epson Dot Matrix LQ-300+ Printer
Ribbon jam
i get the error RIBBON JAM anytime i try to print,even though i have changed the ribbon.Dan
Sep 11, 2008 | Epson DFX-9000 Matrix Printer
jasbo
jasbo
