Question about Garmin Nuvi 265W GPS Receiver
When i connect my garmin to my computer it will not go into usb mode
  • 464 Answers
If you are connecting the GPS via USB and find that it does not go into mass storage mode the first thing to do would be to try your other USB ports. If this does not work try to get it to connect to someone else's PC. If you are unable to do this the unit will have to be sent off for warranty or repair. For your unit I would recommend just upgrading to something a little bit newer, it would be more cost effective and leave you will a newer more up to date unit.
Hope this helps!
Posted on Apr 07, 2011
2 Suggested Answers
SOURCE: Broken USB Connector (Garmin nuvi 200)
USB connectors are too fragile for the constant in-out service they get. But I have solved the problem, at least for standard Type A. The plug end (its steel case slips into the port end's steel case) is functionally female; it accepts the 4-pin tongue of the port and squeezes it between the 4-pin tongue of the plug end and the steel case of the plug end. So when the plastic tongues wear down, the squeeze isn't tight enough. Solution: take a small vise-grips and make the plug's steel case a little thinner, like a weight on a grilled cheese sandwich you're making. Then when you plug it in, it will resist a bit and feel tighter. And it will now work!
Posted on Feb 17, 2011
Computer doesn't recognize garmin
Your computer uses USB Mass Storage Mode to detect your Garmin unit. If your computer does not detect your Garmin unit, you can try these troubleshooting steps:
Unplug the USB cable from the computer.
Turn the unit off and then back on again.
Plug the USB cable into your computer.
The unit either automatically goes into USB Mass Storage Mode or displays USB Mass Storage Mode as an option on the screen.
Note: If your computer still does not detect the unit, make sure that you plug the USB cable directly into the computer USB port and not the USB hub. If the cable is already plugged directly into the computer, try plugging it into a different port.
If you still experience problems, please contact Product Support.
Garmin car gps
Sep 23, 2012 | Garmin nuvi 1350 Car GPS Receiver
Garmin shows picture of computer
When the Garmin shows the picture of a computer, it means that the Nuvi is in mass storage mode. This mode is used to load software and map updates to the Nuvi and will usually go into this mode when connected to a computer or improper USB cable.
If this is occurring when it is connected to the vehicle power cable, chances are that the vehicle power cable is the wrong one.
You may also want to contact Garmin Tech Support for assistance.
1-800-800-1020
Feb 23, 2012 | Garmin nuvi 1450 GPS Receiver
Garmin 265 wt is charging via USB cable.It will not connect to the garmin website.
The Garmin Communicator Plugin needs to be installed on your computer.
http://www8.garmin.com/products/communicator
Also check to be sure that the data cable is the correct one.
When connect between the nuvi and the computer, the nuvi should show that it is in mass storage mode by displaying a computer on the screen.
The correct cable is Garmin part number 010-10723-01.
http://www.gpscity.com/garmin-usb-pc-cable.html
Aug 18, 2011 | Garmin nuvi 265WT Car GPS Receiver
My computer windows XP can't see/recognize my garmin nuvi 1250. I just bought it .The garmin was made in Taiwan. I have intention to upgrade the map.. coz it is old map (2010).but I cannot register...
Assuming the Garmin communicator plug-in has been installed in the Internet Browser and registered at Garmin.com with a user account - the Garmin goes into (PC) communication mode when its connected to the USB port of a PC.
If that doesn't happen - i'd suspect the USB cable first.
Assuming the cable is ok - including the USB port of the PC - the Garmin must go into (PC) communication mode. If not the Garmin USB jack could be defective.
Jul 01, 2011 | GPS
I just bought a Garmin 265WT. I ran the registration program, but the computer does not recognize the Nuvi. I've checked My Computer and it does not show a new drive ( the Nuvi should like like a drive...
Try these steps:-
  • Unplug the USB cable from the computer.
  • Turn the unit off and then back on again.
  • Plug the USB cable into your computer.
  • The unit either automatically goes into USB Mass Storage Mode or displays USB Mass Storage Mode as an option on the screen.
Also, in some cases the operating system does not support the device. Try upgrading it to the next higher level. In most of the cases windows Xp service pack 2 does not recognise this Garmin device. Try upgrading it to service pack 3.
If you are still experiencing the problem then you will need to contact Garmin for repair.
Thanks for using Fixya.
Good Luck and have a nice day.
Jun 12, 2010 | Garmin nuvi 260W GPS Receiver
When connects to power in the car, it thinks it is connecting to the computer.
if your charger not original garmin you should make this modification on mini usb port. tested works with non original chargers (min 500mA).
Nov 14, 2009 | Garmin nuvi 260W GPS Receiver
My Garmin 265wt will not turn on for navigation when connected to a computer anymore. It displays the computer connection but I cannot get to the navigation while charging like I had before. Any help how...
I asked Garmin how to display maps when connecting a 265WT to a PC with a USB cable. Based on the following reply I received from Garmin the answer is you can't. Have you ever updated your software in your Garmin 265WT. Perhaps you were able to display a map with the USB cable connected with an earlier version of the software. Whereas the latest version of the software will not let you display a map with a USB cable connected.
"Thank you for contacting Garmin International.
I will be happy to help you with this. Unfortunately when your unit is
connected to a computer you will not be able to use the device. The unit
is designed to go into mass storage mode when connected to a computer."
Sep 20, 2009 | Garmin nuvi 265 Car GPS Receiver
Garmin nuvi 660 in PC Sync mode even it is not connected to PC USB or AC power supply. So the GPS is useless since it is not even in navigation mode. Any idea how to solve it?
Here's a work around. 1) Plug the USB cable in and let enter Sync Mode as usual. 2) When the Garmin unit is in Sync mode, unplug the USB cable. 3) The Garmin unit will start to exit Sync mode, at which time, IMMEDIATELY plug the USB cable in again. 4) If you plugged in the USB cable in time, notice the Garmin unit will remain out of the sync mode.
Jul 04, 2009 | Garmin Nuvi 660 GPS Receiver
Getting started with new Garmin nuvi660
Plug your 660 with usb into the usb port, computer must not set on sleeping mode (screensaver).
It will take 3-4 hours to be full charge
Dec 18, 2007 | Garmin Nuvi 660 GPS Receiver
Garmin gps
you must have the garmin in data transfer mode/ menu-activesetup-data transfer
Dec 02, 2007 | Garmin StreetPilot c340 GPS Receiver
Garmin Nuvi 265W GPS Receiver Logo
177 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
