Question about Kenmore 600 6965 Electric Dryer
Can I change the door swing? How???
  • 93 Answers
I read through the product specifications and didn't see any reference to switching the door around. I have a lot of appliance repair experience and have never seen a drier with this option, only refrigerators.
Posted on Apr 07, 2011
Do i have to purchase new door hinges to change the swing of the doors or will exiting hinges work to make the change???
never saw duel swing hinges . righties swing right lefties swing left , so I would say YES you need to buy the other ones
Jul 27, 2015 | Samsung RB215ACBP 20.0 cu. ft. Bottom...
How do you change door swing direction?
Refrigerators with reversible doors have mounting holes that are plugged on the opposite side. You have to remove the plug(s), remove the door and its hardware, position the door hardware to match the exposed holes and install the door with the opposite swing. Careful attention must be paid to proper door alignment so that it closes properly and seals properly.
Jun 03, 2014 | Roper Refrigerators
How to change door swing?
Hello Rich, I am happy to assist you!
I see that your question is listed under front load washer, ATF6000F. If this is your correct model number, the doors on this particular model is not designed with reversible doors. Please reconnect if you have a different front load washer. I hope this information helps to some degree.
Feb 19, 2014 | Frigidaire Affinity ATF6000F Front Load...
I AM USING SOMEONE ELSE'S SWAY & PLAY. HOW DO I CHANGE THE BATTERIES AND WHAT SIZE ARE THEY?
tools needed : 1 Phillips head screw driver, 4 d cell batteries.
as you look at the swing, from the front, you will see a mobile set into the side of the leg on the RIGHT side.
it's the leg with the on off switch.
insert the screwdriver through the hole in the mobile and into the screw inset at the top of the leg. You will see that it's at the top of a rectangular door..this is the battery door.
unscrew the 1 screw and remove the door. the mobile will come off as it's attached to that door. change the batteries and put the door back on and re-install the screw.
hope this helps!
Aug 02, 2013 | Cosco Juvenile Cosco Sway n Play Swing...
Reverse door swing
Hi halej308 - Unfortunately Frigidaire front load washer doors cannot be reverse.
Sep 29, 2012 | Frigidaire Affinity ATF7000E Front Load...
How to change doors from right to left on Whirlpool Duet
Duet dryer doors cannot be reversed for the swing. They wil only open one way. Depending on your model of washer the newers ones will allow you to reverse the door swing without a kit. The older units require a kit to reverse the washer door.
Apr 22, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Is it possible to reverse door swing on dryer? My daughter has a new Elite front load dryer that swings from left.
REVERSING DOOR SWING
Your dryer is designed so the door swing may be reversed at any time without additional parts. Conversion is accomplished by transferring hinges to the opposite side of the cabinet.
To change the direction of the door opening:
1. Open the dryer door. Remove the four hinge hole plugs from the left side of the door opening. Place nearby for future installation. NOTE: You may need a plastic knife to help pull out the plugs. Be careful not to scratch the paint.
2. Remove the four screws that secure the door hinges to the dryer front panel (see below). NOTE: Remove one screw from each of the two hinges first. Hold the door firmly before removing the last two screws.
3. Rotate the door 180° and reinstall the door hinges to the dryer front panel with the four screws.
4. Install the four hinge hole plugs in the open screw holes on the right side of the door opening.
Hope this helped Tim
Dec 01, 2010 | Kenmore Elite HE4 Electric Dryer
Can the door swing be changed?
Yes the door can be changed to open from the opposite side, there are removal plugs that need to be removed from the opposite side and just change all the hardware from one side to the other, change the middle hinge first and put on the bottom door first, after its is mounted you can put the bottom part of the top door on the hinge and last the top hinge, and just make a few minor adjustments.
Apr 16, 2010 | Amana ARB1917CSR Bottom Freezer...
How do you change the way the door swings for hoover HE370TC
if you have plugs on both sides you can change the door swing . not all doors will change l & r / hardware on left returns to other side and so on .. but look for the screw hole's before removing doors. mm
Dec 03, 2009 | Dryers
Kenmore 600 6965 Electric Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
