Question about Canon imageRUNNER 1370F All-In-One Laser Printer
La unida canon 1670 f presenta error e810 y la solucion dice revisar el tambor y ya fue hecho y siempre presenta el mismo error
pineworks
  • 4041 Answers
SOURCE: error 5600 Canon ip1700
Hi there
You can try this it some times works.
Super Canon User's method of resetting IP1600
1.Press Resume button hold for 1 - 2 minutes (count to 1 to 15-16)
2.Open the cover right away
3.Release Both cartridges out and then put cartridges them back again
4.Close The Cover
5.Turn Off Then Turn On again.
You can download the Resetter tools program from my website.
Click Link = http://www.4all2sell.com/reset-tools/ip1600st-RESETTER-TOOLS.zip
1. Download software for Canon iP1200, iP1600, 2200 Printers.
2. Unzip downloaded file by etc
3. Run GeneralTool.exe
4. Select the connected USB port number from USB PORT
5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION
6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selected waste ink counter will be reset. MAIN resets the main waste ink counter, PLATEN resets the platen waste ink counter.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
Free WinZip http://www.winzip.com/downwz.htm
Please call back to vote
All the best: Pineworks
Posted on Feb 27, 2010
FSAhead2
  • 214 Answers
SOURCE: tengo una hp photosmart c6280
if you speak english and can read english go here and scroll down to Re: hp photosmart 8250 by Anonymous (7/26/08 2:04 PM) reply There is also help from HP support online chat
http://www.fixyourownprinter.com/forums/printer/51559
si usted no habla Ingl?s o leer aqu? es la conversaci?n que le dir? c?mo resolver el problema paso a paso de este error. si esto no ayuda usted puede ir a CV y obtener ayuda en l?nea o hablar con un t?cnico por tel?fono.
Aceptar que ten?a el c?digo de error CV 0xc18a0001 problema y aqu? est? la conversaci?n que tuve con el ..... James Cowan tecnolog?a: el c?digo de error CV 0xc18a0001 llamarse Ernesto: Voy a ayudarle en este sentido James Cowan: gran llamarse Ernesto: Yo entiendo que una c?digo de error con 0xc18a0001 con "Error de sistema de tinta" se muestra en el panel frontal del dispositivo Todo en Uno de la impresora. En lo correcto? Soy James Cowan: correcta Ernesto: Gracias por la confirmaci?n de llamarse Ernesto: ¿Me puede dar el n?mero del modelo del dispositivo Todo en Uno que est? utilizando: James Cowan c6250 llamarse Ernesto: Gracias por la informaci?n. Gracias Ernesto: James, por favor h?gamelo conocer la temperatura ambiente en el que la impresora se sustituye James Cowan: 67 grados F llamarse Ernesto: Muy bien llamarse Ernesto: Por favor, realice los pasos siguientes en el panel frontal de la impresora para resolver el problema de James Cowan: puede llamarse Ernesto: Pulse la tecla "flecha izquierda" . Presione la tecla "Setup" clave y suelte ambas teclas, la pantalla debe decir "Introduzca Especial Combinaci?n de teclas" Pulse y suelte el bot?n "Aceptar". llamarse Ernesto Por favor, ignore los pasos anteriores, James James Cowan: ok si nada parec?a hacer nada Ernesto: Por favor, realice los pasos siguientes en el panel frontal de la impresora Earnest el: Pulse y mantenga oprimido el "Imprimir fotograf?as" y "ojos rojos" botones. Suelte ambos botones. La pantalla debe decir "Introduzca Especial Combinaci?n de teclas" Pulse y suelte en la secuencia de "ojos rojos", "Imprimir fotograf?as", "ojos rojos" Ernesto: la pantalla debe decir "apoyo" y mostrar el rev FW (algo as? como R0616R) James Cowan : Ernesto COxxFN0723BR: Bueno Ernesto: 2. Pulse y suelte el bot?n de flecha derecha hasta que la pantalla dice "Men? de configuraci?n del sistema James Cowan: puede llamarse Ernesto: 3. Pulse y suelte el bot?n "Aceptar". James Cowan bien y que dice llamarse Ernesto estado de fallo de hardware: pantalla debe decir "error de estado de hardware: Despejado. Pulse Aceptar para borrar". Llamarse Ernesto: Pulse y suelte el bot?n "Aceptar". Mensaje se convierte en "estado de error de hardware aclarados continuar. Pulse Cancelar para":. Llamarse Ernesto Pulse y suelte el bot?n "CANCEL" tantas veces como sea necesario, de modo que, ya sea el "Welcome to Photosmart Express", aparece la pantalla, o bien, la tinta " El fracaso del sistema "aparecer?. NO TRATE DE NO ESCRIBA EN ESTA ETAPA. POR FAVOR James Cowan: puede llamarse Ernesto: Con el bot?n de encendido, apagar la unidad y desconecte el cable de alimentaci?n de la parte posterior de la salida de la impresora y la pared:. Llamarse Ernesto D?jame saber una vez que se realizan con el los pasos anteriores James Cowan: ok su desenchufado llamarse Ernesto: Espere 30 segundos para que el poder ser dado de alta ya continuaci?n, conecte el cable de alimentaci?n al enchufe de la pared primero y luego en la parte posterior de la impresora llamarse Ernesto: Encienda la unidad. La impresora puede mostrar mensaje "USO DE ENERG?A BOT?N DE PARADA DE LA IMPRESORA" seguido de "Pulse Aceptar para continuar". Pulse Aceptar. James Cowan: puede llamarse Ernesto: Quisiera saber el mensaje que muestra en la parte frontal del panel de la impresora James Cowan impresora: preparaci?n ocurriendo - no interrumpir Ernesto Bueno James Cowan: puede hacer su Earnest: Vamos a imprimir una p?gina de autoprueba de la impresora ya James Cowan: tratar bien llamarse Ernesto: 1) Carta de la carga, A4, o de plano no utilizados legales, papel blanco en la bandeja de entrada 3. 2) Aseg?rese de que la impresora est? encendida y cargada sin usar con papel blanco), papel. Pulse Configuraci?n. El men? de configuraci?n. 4) Pulse el bot?n flecha hacia abajo para seleccionar Herramientas y, a continuaci?n, pulse Aceptar. 5) Pulse la flecha hacia abajo para seleccionar Auto-prueba de informe, y pulse Aceptar. El auto-informe de prueba imprime. James Cowan se puede imprimir llamarse Ernesto: Muy bien, por favor, compruebe si todos los colores pritned perfectamente en la p?gina de prueba James Cowan: perfecto llamarse Ernesto: Gran .. Saludos James Cowan:! Muchas gracias Ernesto: James, ahora usted puede seguir utilizando la impresora de llamarse Ernesto: Le agradezco su esfuerzo y paciencia para tratar de resolver el problema.
Posted on Oct 01, 2010
puertobori
  • 7733 Answers
SOURCE: tengo una impresora dell
1-Apague su PC
2-Desconecte la impresora y el tambor
3-Prenda su PC
4-Conecte la impresora
5-Ponga el tambor
Suerte
Posted on Oct 07, 2010
Cogz
  • 1326 Answers
SOURCE: Buenas nochess. tengo una canonimageruner 1023
Hola, a E019 means that the waste toner is full. The waste toner holder is part of the drum unit. You can vac. it out, but you most likely need a new drum unit. Good Luck
Posted on Dec 13, 2010
  • 92 Answers
SOURCE: la canon ir-1630 me saca
ola.
tens que cambiar o tambor ,abrir a porta lateral esquerda éuma peça com um rolo verde.
Posted on May 23, 2011
Acer veriton z291g se apaga sola cuando entra al sisitema escritorio
hola amigos, es la primera vez que respondo en sitios (y ami que? diran, ps nada ya ven que todo dicen lo mismo) .
ok yo teni a el mismo problema con la acer veriton le di muchas vuletas, pensando en virus o si era alguna parte interna.
lo que hice fue entrar a la bios y desactivar el shutdown en el regulador de energia. si hay una opcion en ingles. esta enable solo pasenla a disable o algo asi,, y bueno es una solucion que doy, al menos a mi me funciono. espero que les sirva. y pasen el conociiento
Jul 10, 2012 | Cars & Trucks
Tengo una impresora dell dice error 004-321 le quito el tambor la prendo me pide el tambor y repite lo mismo
1-Apague su PC
3-Prenda su PC
5-Ponga el tambor
Suerte
Oct 06, 2010 | Dell 3000cn Laser Printer
ROS failure
Hola buen dia OKI B6500 la falla que presenta es ERROR DE ROS crei que era el laser scaner pero le puse el de otra impresora en buen estado y nada siguio al poco tiempo igual de hecho el que le quite lo puse en la impresora que esta en buen estado y sigue funcionando, este error OKI B6500 lo hacen muy comunmente este tipo de impresora,En OKIDATA me comentaron que lo provocan varios sensores sobre todo el de tapa superior pero aun que lo corrijas funciona pero al poco tiempo lo vulve hacer que mas puede ser si ya le cambien el sensor de tapa sup.,laser scaner,sensor de deteccion de toner., en OKI no especifican cual es el provoca este error nada mas dicen que son varios sensores.
NOTA: de hecho un colega hizo lo mismo y no le la corrigio lo que hace es la apaga varias veces sacando y poniendo el toner y a veces bingo funciona de hecho tiene una impresora que inicia bien pero al poner el toner se apaga o marca error que hacemos las tiramos tienen menos 80,000 paginas alguien tiene un buen TIP
Aug 19, 2010 | OKI B6500 Led Printer
Tiene bibracion o los esprines estan fuera de lugar o el balance del tanque esta mal puesto no se con las imagenes del sistema creo poder
Podria ser que una pieza parecida a una "y" que sostiene el tambor interno en la parte posterior del mismo se haya corroido por contacto de bimetales ya que la "y" normalmente es en aluminio y el tambor en acero inoxidable. La unica forma de accesar esta pieza es desarmando practicamente toda la lavadora para accesar el tanque y luego separar la cubierta plastica para accesar el tambor. No necesariamente tiene que ser esto, esperemos que no... Tambien podria ser un soporte interno roto. De cualquier forma, remueve la cubierta inferior (si la tiene) y echale un vistazo a los soportes.
Apr 21, 2009 | Kenmore Washing Machines
Error 8002f14e en el 95%
MUST CONNEC YOUR BLURAY TO PS3
THEN UPDATE 100% COMPLETE
ZEUSPOLSKA
ADAMOPOLE@GMAIL.COM
Sep 23, 2008 | Sony Playstation 3 (PS3) Console
Cascabeleo del motor ?³ comose dice en venezuela pistoneo
no abla espanol speak english we might be able to help
May 15, 2008 | 1994 Ford Taurus
Canon imageRUNNER 1370F All-In-One Laser Printer Logo
362 people viewed this question
old marine
old marine
