Question about Ovens
Hi. My oven stopped getting hot (elements still get barely warm) right after the temperature sensor broke off. Could the broken sensor cause this? Thanks.
    Problem Solver:
  • 19 Answers
Yes it can and ur element is probably bad shut off power take out 2 screws on side of it n pull ito ut to disconnect wires n put new one in !!
Posted on Apr 07, 2011
Testimonial: "Thank you. Unfortunately mine doesn't have any screws near the sensor so it looks like I have to pull the whole inside out. I'll try and do that. "
I have a Chef Electrolux wall oven, model no. EXC643W. Using it tonight it stopped getting hot. If the element is the problem, how do I get to it ? Could there be another cause? It has been working ok untill tonight. Many thanks Denis
Posted on Apr 11, 2011
My Candy Model CN100 Oven does not heat up when switched on. The oven light and the fan works though. Can you advise?
Posted on Apr 09, 2011
My Frigidaire dual fuel oven wont get hot. Both heat elements and temperature sensor have been replaced and it still only gets warm. No error codes are displayed.
Thank you for your post, Chrissie!
I understand that your Frigidaire duel fuel oven is not heating properly. I see that you have replaced your temperature sensor and heating elements and your oven is still not working. This could be a possible issue with your control panel or wiring harness. Since it could be anyone of these underlying issues I would recommend having a professional technician out. This will help you avoid any unnecessary part purchases. Hopefully this is helpful information. -Matt
Jun 01, 2015 | Frigidaire Ovens
My oven will not heat up to temperature
It may be the bake element that has gone out. The self clean usually uses the broil element to heat the oven. And most oven will either put 120 volts to the broil element while baking or pulse the broil element while baking. This will cause the oven to get warm but not hot. Check the oven bake element it cound be bad or a wire may have burned off.
Feb 14, 2014 | Ovens
Oven elements warm but do not get hot.
whats the resistance on the elements, how many watts are they?
make sure all wires are good, could have one broke about half way. you will need to check the resistance on the elements. you need to actually check the volts and use whats its closer to 240/220 you will have to find out the ohms so you know the element will get hot. if all the wiring is good start with the elements, you need w/v will tell you the amps. e/i will give you ohms, just use the equations in the pic to figure out what you need to know. it as to have enough resistance to get hot
Mar 29, 2017 | Ovens
My old Jenn-Air W230 wall oven only gets to "warm" in the bake position - even at a temperature setting at 500 degrees. However the broil function works well. Could the problem be a bad thermostat o
the oven sensor could be bad,its a small rod inside the oven cavity near the top,or you could have a bake element with a "hot-spot" in it that can no longer pass enough current to properly heat the oven to the correct temperature setting(most elements with a hot spot will show a discolored area on the element where its been overly hot)this is the "hot-spot" it will soon break apart there
Nov 30, 2012 | Jenn-Air Ovens
I replaced the element in my belling double oven, it wored for a while but was very hot thought it was the thermostat, now it has no heat at all no light but the fan still works.The top oven and gril has...
Hi.
Replace the temperature probe located in the oven cavity. The probe was initially shorted. That caused temperature runaway with the oven getting too hot. After a while the shorted sensor blew completely staying open all the time. That is resulting in no heat.
If the temperature sensor has already been replaced, then problem is either wiring or oven electronic control. Wiring harness is tested checking continuity between different points.
Regards.
Ginko
Jul 17, 2011 | Belling XOU592 / XOU593 Electric Double...
Whirlpool electric oven won't heat just barely
Hello & Welcome to FixYa
This indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then test the door switch. Please get back to me if you have any other questions.
Kevin
Jun 09, 2011 | Whirlpool RBS305PD Electric Single Oven
Hi i have a Samsung oven bf641fst the light and fan come on but the heat side wont work and the led sceen is blank?
Thanks for choosing FixYa and welcome. you have a electric oven or a gas oven that won't heat or doesn't heat properly, here are some things you will need to check. The most likely cause of a oven not heating correctly is a defective heating element. You have two types of heating elements in your oven. The bottom element(s) are the baking elements. The element(s) on the top are the broil elements. If you don't see the bright red glow from the element, chances are they are not working or not working correctly. If a heating element is bad, you need to replace the entire element. If your oven is warm and not correctly hot, one of the elements may be bad. In most ovens, when you preheat, both elements are used. This would make the oven to appear like it is working correctly but it is not. If the elements are not working, they might not be getting power. Test the wires to the elements with a voltage meter to make sure they are getting power before you decide to change them out. Many electrical ovens have a sensor that monitors the oven temperture. Ovens that have this sensor usually contain a digital display on the oven. The sensor could be defective. Those without the sensor use the basic mechanical system to control the oven temperature. You also want to check the thermostat sensing bulb. Make sure the bulb is good and has not come loose. Now, if you have a gas range oven that doesn't heat properly, first, you want to check your bake igniter. It may have burned out or it could be not working properly. It will be located near your burner. It is also possible that you are not getting gas to the burner. If so, it may be the gas safety valve or the igniter. You need to check your selector switch and thermostat as well. They may be defective. Always make sure you test the parts for power with a voltage meter of some type before you decide to change the part. If you have a part that appears to not be working, it may not be getting power because of a bad wire or broken connection.
May 31, 2011 | Viking VESO176 Stainless Steel Electric...
The oven wont get hot, it will warm up and the broiler seems to get hot??
You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results. If the bake element is burned out, replacing it should solve the problem. To determine if the heating element is burned out, you will have to test the element for resistance across the 2 ends , with the meter set on the 200 scale if you get a good reading like 000 it would indicate that the part may be ok but if yoiu get a reading of a 01 or a 1 or lomething like this it would indicate tha part is bad then you need to replace it
However you will also want to
First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly. If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective. Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details. Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat. If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem. It won't broil
Apr 11, 2011 | Frigidaire GLEB27S7A Electric Single Oven
The broiler works but the bake side wont heat up but does warm
Hi There
I have found some stuff for you to read and hope this will help. Let me know how it goes.
It won't bake Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it. It bakes poorly Here are two instances of when food "bakes poorly:" When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out. You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results. If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component. When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly. If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective. Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details. Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat. If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
Best Regards Richard
Dec 30, 2009 | Ovens
Oven wont get hot ,just warm
3 possible causes:
1. Bad bake/broil elements - can you see them glow?
2. Bad temperature sensor - can be tested with an ohm-meter.
3. Problem with the control board. We fix a lot of these oven controllers with this symtpom at www.fixyourboard.com
Oct 08, 2009 | GE Profile JTP56 Electric Double Oven
Ovens Logo
726 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
