Question about Fujitsu fi-6130 Flatbed Scanner
I see error message 8 on my fujitsu 6130 and the computer doesn't find the scanner.
- Replace new Control PCA.
Posted on Jul 05, 2011
  • ScanCare
    ScanCare Mar 07, 2014
    Check the harness/cable that joins Panel PCA & Control PCA. It might have been punctured. Check by replacing the harness first then by Panel PCA, if not resolved, then the Cintrol PCA may have to be replaced.
What's the price of Fujitsu scanner model 5130?
As far as I can tell, a Fujitsu 5130 is a desktop computer, not a scanner. It sells for $2820 new.
A Fujitsu 6130 is a scanner, and sells for about $400 used.
May 16, 2015 | Fujitsu Office Equipment & Supplies
Error code C6
On a later model, 6800, C6 indicates hardware error. Not user fixable. http://www.manualowl.com/m/Konica%20Minolta/Fujitsu-fi-6800/Manual/284852?page=149
Jun 07, 2014 | Fujitsu fi-6130 Flatbed Scanner
Fi-6130 door is lock how to unlock
The ADF Lock Lever is broken and need to be replaced. you are recommended to contact a Fujitsu scanner expert for the replacement. Please let me know your location, so that I can refer you a Fujitsu scanner expert.
Thanks,
Scancare
Apr 30, 2012 | Fujitsu fi-6130 Flatbed Scanner
Fujitsu 6130 background switching mechanism error
Hi how do you fix Fujitsu 6130 F4 error? Thanks
Mar 20, 2012 | Fujitsu fi-6130 Flatbed Scanner
Fujitsu 6130 Scanner speed has gone down considerably
Scanner speeds are dependent on the Computer System and the hard disk capacity. You need to create contiguous and Large space in Hard disk. Delete unwanted files and also run 'disk defragment' to create contiguous space.
S. Mohan, Chennai, India
Aug 30, 2011 | Fujitsu fi-6130 Flatbed Scanner
Fi-6130 scanner attached and on; but computer says no scanner attached
Have you installed the Twain driver? You can download it on Fujitsu's website.
Jan 18, 2011 | Fujitsu fi-6130 Flatbed Scanner
Code DS42003 PAD ASY IN PAPER FEEDER
After you've been scanning for a while with your Fujitsu 6110 or 6130 scanner, you will get a message from the scanner recommending that you replace some of the scanner's consumable parts, such as the pick roller and pad assembly. Although you can ignore these messages, they will keep showing up, even after you have replaced the parts, until you also clear the scanner's page counters in the Software Operation Panel.
http://www.scan123.com/blog/index.cfm/2013/3/15/How-To-Reset-Page-Counters-for-Fujitsu-6110--6130-Scanners
Sep 30, 2010 | Fujitsu fi-5120C
Hi, my fujitsu fi-6130 hangs after a few scans. This happen once in a while where i have to kill all my application in order to work again. Any idea why this is happening?
Does the scanner have any error code displayed on its display? If so, what it it? What software are you using to run the scanner?
Sep 28, 2010 | Fujitsu fi-6130 Flatbed Scanner
Fi-6130 scanner displays J1 paper jam after
Does the message shows after few pages scanning or is there any panel error message like J-1 on scanner start up?
If the issue occurs during scanner start up, then there are staple pins or dirt might be stuck inside the US Sensor panel inside the scanner. Cleaning and removing the objects will resolve the issue.
If the error occurs after few pages scanning, then you may have to check the Pick Roller, Brake Roller, Pinch Roller and US Sensor FX status. you may have to replace any of the above, if damaged or worn off.
Hope the above information is helpful.
Please check your device first and get back to me.
Thank you.
Regards,
TechSatya
Jul 19, 2010 | Fujitsu fi-6130 Flatbed Scanner
Fujitsu fi-6130 Flatbed Scanner Logo
2,873 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Smidler
Level 1 Expert
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
