Question about Refrigerators
How do I access the 3/32 allen head screw to tighten the handle on my kbrs22kvbl freezer?
    Problem Solver:
  • 19 Answers
U have to open it and take out the inside plastic lining it is also screwed in just look close around the rim n take em out !!
Posted on Apr 07, 2011
How to tighten loose set screws on freezer door handle on ken more fridge with bottom mount freezer, model no. 269-76353019
I think that the handle is attached either to the door edge or the face. In either case the screws are usually hidden behind a small trim panel. This needs to be removed to expose the screws. I don't know what type of screws have been used. They're usually cross heads but occasionally they require an allen key to remove them.
Jul 19, 2015 | Kenmore Refrigerators
Loose handle
There is a long vertical handle held to the door by two short horizontal pieces. Run your finder along the under side of the two short pieces and feel for a very small indentation under each one. Each one is a set screw with an Allen head. Insert a small Allen wrench (English not Metric -- I don't know the size, but it is probably the next to the smallest in the set) into each one and back them out (counterclockwise looking up at the screw). The big vertical handle should come off when you back the Allen screws out far enough Now look into the short pieces sticking out from the door. Inside each one is a Philips screw holding the piece to the door. Tighten those screws with a small Philips screw driver making sure that the indents on the front of pieces will align with the vertical bar when you put it back on. When the Philips screws are tight, put the vertical bar back on and tighten the Allen screws. If you have some Loc-Tite, you might use that as well.
Mar 11, 2013 | Marvel 6BAR-BD Beverage Cooler
GB2FHGXB01
Are you sure of the model number? I don't see a Whirlpool GB2FHGXB01 ; I do see a model GB2FHDXWB01.
For this model, there are several different door handles. One has a Philips head screw hidden under a trim piece. To expose the screw firmly push the trim away from the center of the handle. (This is for a standard Whirlpool fridge door handle.)
The French door style refrigerators have slightly different door handles. One uses Allen screws as set screws to secure the handle. (This screw needs a 3/32" Allen screw (hex key) and you can access it through a small hole in the underside of the handle on the loose side.) Be careful not to overtighten the screw or you may strip the threads and have to replace parts.
The other option has the handle mounted on brackets on the door. To access the bracket, grasp the freezer handle and pull it to the left. Then pull the handle away from the refrigerator.
For pictures of the handles, see pages 9 and 10 of the manual. It's available here: https://www.whirlpool.com/digitalassets/MLPDF/User%20Instructions%20-%20W10366204.pdf .
I hope this helps. If you do have the GB2FHGXB01, check if any of these directions help. Most refrigerators use one of the above door handle designs.
Apr 28, 2012 | Whirlpool GB2SHDXP Bottom Freezer...
LFX25975sw
There are Allen set screws on each end of the handles (Top/bottom for the refrigerator doors, left/right for the freezer compartment.) These screws are accessed through small holes in the side of the handle with a 2.5 mm (3/32") Allen wrench. There are on the bottom side of the freezer handle as it's installed. There are also mounting brackets under the handle that can be tightened with a 1/4" Allen wrench with the handle completely removed.
For pictures of the handle hardware, see page 9 of the manual for the LFX25975SW. This is page 10 of the pdf here: http://www.managemylife.com/mmh/owner_manuals/2228/LG-Bottom-Mount-Refrigerator-L0906255 . This link should display in your browser.
I hope this helps.
(Allen wrenches (Hex keys) are L-shaped tools with a hexagonal design where it contacts the screw head. You'll need the long side to get into the holes. Do not overtighten the screws - this can strip the threads. Then you'd need to replace the entire handle unless you can work a new screw into the spot.)
Apr 26, 2012 | LG LFX25975SW (247 cu ft) Bottom Freezer...
I have a kitchenaid KBLS19KTSS 01 bottom freezer, and the freezer handle has come off on one side. do I need to disassemble the door to reattach it? Or, do the small screws on the bottom of the handle...
It looks like your handle is the style that slips over a screw that is threaded into the face of the door...
According to your owner's manual you most likely just tighten the small allen head screws to secure it. It lists the screw size as 3/32. You should have been left the allen head with your paperwork when you bought it.
Jun 12, 2010 | KitchenAid Refrigerators
Handle is loose on refrigerator,how to tighten the handle
There should be some small Allen (Hex) screws on each bottom side of the handle. Just use a Allen wrench and tighten it up.
Jun 06, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Loose freezer door handle
There is a "set screw" on the underside of the posts that connect the handle to the mounting posts on the face of the door of my Jenn-Air bottom freezer. Use an Allen wrench to loosen the set crew, which is very small (my Jenn-Air requires a 3/32" Allen wrench), and then tighten the bolt on the mounting post on the face of the freezer door. Position the handle over the post, then tighten the set screws with the Allen wrench. Cynthia
Jul 21, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
The door handle on the freezer of my GE Profile Bottom Freezer Refrigerator came off.
Hi, Please get me the model # from the label inside the refrigerator and I will look this up for you. Most handles have a set screw that tightens down.
Vic
Jul 11, 2009 | General Electric Profile PFSS2MIXSS...
Fisher Paykel fridge door handle loose
Yes hello, I had the same problem - similar fridge model.  Mine was the fridge (not freezer) door handle ie. the upper door.  There are no small holes on the bottom of my fridge handle.  Working from the outer door edge, I gently prized loose the plastic trim located under the door.  I didn't take it completely off, just loosened about one quarter of the length, enough to flex the trim downward so that I could then access the phillips head screw that secures the fridge handle from the inside of the door.  The trim will prevent you from using a conventional screw driver to tighten the screw.  I used a screw driver bit which is only 25mm long.  It has an hexagonal end to which I applied a small spanner and voila - the handle is once more secure.  Good luck.
Nov 07, 2008 | Refrigerators
Handle loose on Refrigerator
To fix this you will need an Allen wrench small one there are 2 set screws on the inside part of the handle (on side toward the center) you wil need to tighten these to fix your problem
Feb 12, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
