Question about Kitchen Ranges
I AM NOT GOING TO PAY FOR ANY ONLINE ANSWER I just need a manual for my tankless water heater
    Guru:
  • 257 Answers
Hello Smurflover,
I would like to help you with your problem. However, I need a make and model of your tank-less water heater. Thank you
Justin
Posted on Apr 07, 2011
How to wire tempra 24 plus
1) Copy following link for wiring tankless electric water heater:
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
2) Look at label on side of unit for total KW
3) Product manual shows 24 Kw or 24,000 watts
24,000 watts divided by 240 volts = 100 amps
So your service panel must be about 250Amp rating to support this tankless electric water heater.
http://waterheatertimer.org/pdf/Tempra_tempra-plus-Tankless-electric-water-heater-manual.pdf
4) Look inside the unit to see how many L1L2 terminals show.
You should have two sets L1L2 terminals
http://waterheatertimer.org/images/Terminals-2-tankless-200.jpg
5) You need TWO 60 amp double pole breakers to supply power to this unit.
This means you need TWO #6 wires from one breaker going to L1L2.
And you need TWO MORE #6 wires from 2nd breaker to other set of L1L2 terminals.
6) Add comment for more help Jan 2013
Jan 07, 2013 | Stiebel Eltron TEMPRA 24 Tankless Water...
I have a new Richmond tankless. Every time someone turns on the water for a second the water heater comes on for a second. Is this ******* the unit ? I tell people to just use the cold water tap if th
Before calling service technician, copy following link for troubleshoot resources:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
If tankless comes on when HOT tap is turned on, then that is normal.
If tankless comes on when cold is turned on, then you might have crossover:
http://waterheatertimer.org/Crossover.html
If tankless comes on when single handled faucet is lifted in center, then that draws water from hot pipe and will activate tankless > so don't install single handled faucets to save water heater energy, regardless what type water heater you have.
Tankless require monthy-to-yearly maintenance to avoid common error codes. The product manual recommends yearly service. Since Rheem does not post service manuals, you generally have to pay somebody to take apart and test the unit. The cost of this far outstrips expected savings from owning expensive water heater that requires lots of maintenance, yet is heavily promoted as the solution to water heater problems.
Never install tankless water heater is best way to avoid complications of expensive water heater that is maintenance heavy, hard to diagnose, expensive to fix, etc.
Never expose tankless to more than 11 grains hard water.
http://waterheatertimer.org/pdf/Rheem-CondensingTankless-maintenance-2012.pdf
Aug 25, 2012 | Rheem Richmond Encore Condensing Tankless...
My Bosch Water Heater keeps going off. I reset it and then A7 keeps coming up. We had a power outage for about 6 days. I do not have the manual. Do you know what it is and how to fix it? Thank...
Questions might be asking for a manual, and asks what error A7 means, and asks how to fix error problem, but model number of Bosch heater is not given.
Error codes are start-point for troubleshooting, and can include multiple causes.
So following answer provides general do-it-yourself resources, without saying that problem can be 100% diagnosed or fixed by homeowner.
1) Error code A7 is outlet temperature sensor fault.
Problems include: need for descaling, dirty inlet water filter, debris in faucet aerators, dirty wiring terminals, bad wiring harness, or bad temperature sensor.
http://waterheatertimer.org/pdf/Bosch-GWH2400ES-error-codes.pdf
2) Before calling service technician who can test failed parts and catch tankless up on yearly maintenance, open following links for Bosch resources including error codes, phone number, possible manual, and descaling instructions, and cleaning inlet filter:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
http://waterheatertimer.org/pdf/Rheem-De-lime-tankless.pdf
http://www.boschhotwater.com/Portals/7/TechBulletins/TWH-G1-12_Cleaning_inlet_filter.pdf
3) Product manual: Question posted under model 125HX-LP
Open following link for possible manual:
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/125HXTechSupport/InstallationManuals/tabid/542/Default.aspx
4) Do it yourself service bullitens for 125HX-LP
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/125HXTechSupport/ServiceBulletins/tabid/548/Default.aspx
5) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 07, 2011 | Bosch AquaStar Propane Tankless Water...
Flashes il
Before calling service technician, open following link for Rheem tankless resources including error codes and possible manual.
Read your manual for troubleshooting, advisories and required maintenance.
Tankless are maintenance heavy.
1L means tankless heat exchanger has lime build-up.
De-lime tankless unit.
U-tube has videos for de-liming tankless, but there is more to consider:
De-liming is yearly maintenance requirement.
Tankless are prone to lime build-up
Regular de-liming will not restore full efficiency to tankless unit.
Tankless cannot be exposed to water with more than 11 grains hardness.
Temperatures over 135 can cause minerals in water to harden on metal surfaces of any water heater.
Also clean Tankless water filter each month, and clean and maintain burner and combustion chamber yearly.
The cost of maintenance and cost of expected repairs and cost of parts plus cost of original installation will never pay back the $1-8 monthly savings on gas bill. All costs are energy.
Make sure there is qualified service technician in area before buying tankless.
Upvote the help.
May 24, 2011 | Rheem Tankless Hot Water Heater...
I have a Bosch GWH 2400 CTD EFS NG tankless water heater. It has been installed on operating for over a year in the last several days it has an error code A3. The first two times I was able to reset it....
Call qualified service technician, and ask that person questions about maintenance and tips.
Then keep service technician number in rolodex-wallet.
Resourceful do-it-yourselfer will find following links handy.
Tankless are maintenance heavy, and Bosch and Rheem etc say to call service technician for recurring problems. Especially when short-hand troubleshoot section doesn't solve problem.
People spend years learning how to service tankless.
Bosch has online tech support form:
http://forms.boschhotwater.com/Home/BoschTechSupportForm/tabid/614/Default.aspx
BOSCH error codes online:
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/2400ESTechSupport/Troubleshooting/tabid/1295/Default.aspx
Bosch manuals:
http://www.boschhotwater.com/HelpfulResources/BrochuresManuals/tabid/354/Default.aspx
Bosch problems at Fixya:
Open following links and read about tankless problems to understand the field and glean useful information.
http://www.fixya.com/support/p949576-bosch_1600h_lp_liquid_propane_aquastar_a/solutions
Install DIY tank-type gas water heater and avoid the whole headache
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Post question on pro water heater forum: This is where I go to catch up on latest info in always-evolving water heater industry.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Pay for an answer at fixya:
Also take advantage of fixya expert assistance live.
Mar 18, 2011 | Bosch & Tankless LP Hot Water Heater
Bosch manuals:
Mar 17, 2011 | Bosch & Tankless LP Hot Water Heater
My Richmond tankless water heater is flashing the error code 76 and C8
Richmond is Rheem.
Following links are meant to assist resourceful do-it-yourselfer solve long term maintenance issues that tankless pose.
Error 76 is communication fault with remote control.
Check following links for Paloma 'Rheem" error codes:
http://www.palomastore.com/paloma_error_codes.html
http://www.palomatankless.com/owners/homeowner+trouble.lasso
Best place to start is your manual. Following link show typical Rheem manual with the words troubleshoot and maintenance throughout manual.
Read manual several times before buying product to see yearly maintenance requirement and complexity of tankless water heaters.
http://waterheatertimer.org/pdf/Rheem-RTG74IndoorOutdoor_owners.pdf
Rheem offers on-line chat, which you rarely see for typical tank-type water heater
http://www.rheem.com/products/tankless_water_heaters/customer_support/
Contact Rheem: they will usually kick you back to local service technician.
http://www.rheem.com/Contact.aspx
Check following link for recall list:
http://www.tankless-recall.com/tanklessSearch.aspx
Rheem website is not easiest to navigate, but manuals appear for current models.
Read other Rheem questions at fixya to gain wider experience with potential problems and solutions.
http://www.fixya.com/tags/rtg_74pvn
Post question on pro water heater forum: This is where I go to catch up on latest info in fast-evolving water heater industry.
Pay for answer at fixya:
Mar 17, 2011 | Rheem Tankless Hot Water Heater...
Bosch 250 sx ng tankless water heater showing error code. checked fuses and they are fine. tried resetting many times still not working
BOSCH error codes:
Best place to start is troubleshoot section in manual. Page 24
http://www.boschhotwater.com/Portals/7/TechManuals/250SX_English.pdf
Problems range from air supply, gas supply, venting, part failure or combination of listed things.
Don't forget, tankless require yearly maintenance, outlined in manual, and cannot be exposed to more than 11 grains hardness in water, and should be de-limed each year.
I suggest reading entire manual several times, so you are pro about your tankless water heater.
Even with this knowledge, trained service technician will have to be consulted
some day, and tankless should never be installed if factory trained technician not available in area.
Install tank type water heater that can be put online when Bosch is not working
Add a comment for more free help.
Mar 04, 2011 | Bosch & Tankless LP Hot Water Heater
Kitchen Ranges Logo
44 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
