Question about HP PHOTOSMART PLUS B209A All-In-One Printer
Black ink wont work. I did the alignment and it stated that the ink wasn't calibrated. I just replaced all the ink cartridges. I cleaned the printheads. The black ink wasn't working before I replaced it.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 144 Answers
Hi there!
please try to shake the ink cartridges then reinstall them again, make sure you hear the clicking sound meaning the cartridges are locked in place. you can try and call 800-HP invent or 800-474-6836 for technical support aswell. here is the link for your printer, you can get drivers, manuals and troubleshooting steps here as well.
http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&lc=en&dlc=en&product=3777182
Posted on Apr 07, 2011
3 Suggested Answers
pineworks
  • 4041 Answers
SOURCE: even though black ink cartridge is almost full, no
Hi There
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Feb 28, 2010
merbuquis358
  • 94 Answers
SOURCE: replaced empty black ink cartridge, wont print
The head of your printer cartrige (black) are not detected by the printer because it was damage and need to be replace. So that no more black ink could print anyway.
Posted on May 26, 2010
Black ink will not print
Have you tried setting the color to black cartridge only. You may be printing the black with a combination of colored inks. I occasionally have a similar problem. Sometimes I can get the black to work by taking a paper towel dampened with distilled water and holding it against the cartridge print head until I see black ink coming out. Replace the cartridge and try printing again. If this doesn't work try a new cartridge and run through your Printer Settings, making sure they are all set properly.
Mar 17, 2014 | Hewlett Packard Printing & Imaging HP...
Replcaed new black ink but it will not print black now
You should make sure that plastic protective tape on the new black cartridge is off. Next, you have to calibrate your printer. Run 'self test diagnostic' and 'print cartridge alignment' to get work of black ink.
Jul 25, 2011 | Canon PIXMA iP90 Mobile Printer
Does not print dark enough to read. Changed toner and adjusted print darkness feature. Still does not work. Any idea what to do?
Hi
When printing, just adjust the PRINT QUALITY to PHOTO because I believe your print quality is set to TEXT. I am sure it will print move darker than before.
I hope it helps you solve your problem.
Regards
Feb 15, 2011 | HP LaserJet 3030 All-In-One Printer
On an HP PSC 950, I'm getting a repeated "Press Enter to Align Cartridges" message when I try to copy. Got a response from a previous expert that wasn't even applicable to this model, and no response...
hello, the reason your printer is constantly trying to align cartridges, is it did not complete the alignment, machine must complete alignment, so this message will go away, this machine requires all #15 black ink cartridge and #78 color ink cartridge, it requires the color ink to be working since it uses either yellow or magenta ink for calibration,also black ink has to working for this to work. now if the ink cartridges are known good ink or printing ink cartridges, then the problem maybe the sensor that detects the color when it prints, you may try with a soft wet or damp paper towel, when cover is open as if you are replacing the inks, unplug printer from power, move carraige to left alittle bit more, on the right hand side of carraige, you might see a black piece of plastic, behind that is the sensor, use the wet towel and wipe the bottom part of carraige and sensor, do this several times. now go ahead and close machine and power up, see if machine will pickup paper, print the calibration page. if all is working it should pass.
Oct 06, 2010 | HP PSC 950 All-In-One InkJet Printer
I changed the black ink cartridge and the printer
Calibrate your new blank ink cartridge, have some nozzle check, cleaning check, and printer alignment. This are procedure that new ink cartridge will have to calibrate before you use. Epson printer are very sensitive when capable of changing ink cartridge. Unlink HP directly work without any print test because the cartridge head and ink join together, Epson with ink cartridge and the head separate.
Have some test on it at Printer Maintenance.
I'm sure 100% works on it.
Sep 23, 2009 | Office Equipment & Supplies
Put in new ink and it is telling me out of ink and will not let me print anythings.. How do you reset ink
Simple oly when you know how ;-)
I think you have a slight blockage, to solve:- (dont know which printer or PCyou have so ill do my best)
Click on Start
All programms
Pick your printer from the list
Open the software
You will have 2,3 or 4 options depending on your printer spec.
You need to 1st remove the cartridge
Print 1 page with no INK a message will pop up saying con not print need ink for example.
You then NEED to calibrate your cartridge, you need to find:-
1 Align Cartridge/Nozzle - Unblocks, and Sets up. (Syncronize)
2 Calibrate Black - unblock black
2 Calibrate Colour - unblock colours
3 Print test Page - See how it looks
5 Align again - Unblocks everything giving good ink flow and gets the print right close to 100%
6 print test page!
It shoud now work ;-)
Good Luck xxx
Jul 15, 2009 | Canon Pixma MP480 All-In-One InkJet...
Dial says to remove cartridges and check. Have replaced cartridge
After cleaning cartridges and replacing refilled black ink, I removed blck ink and replaced with HP 58 photo ink. this aborted the "check cartridges freeze". I still cannot align cartridges after removing #58 and replacing with new HP 57. the operation starts but will not complete.
Any suggestions on how to align cartridges?
dunbarj730
May 02, 2009 | HP PSC 2210 All-In-One InkJet Printer
I have a kodak easyshare5300 printer. The printer will not print in black ink and some times also in color.
Dear Kbrownsr,
Please check the ink/toner levels of the cartridges installed in your printer.
Steps to solve this problem.
1.) Check the ink levels by using the printer software provided with the printer.
2.) if the ink levels are low, the cartridges has to be replaced/refilled with new ones.
3.) if the ink levels are high or medium, try to do a calibration for the printer using printer tools provided by the printer vendor/ software.
4.) please do a cleaning cartridge and align cartridge options in the printer tools followed by a second calibration.
5.) if the ink levels are showing medium/high and still if the problem occurs, remove the cartridges from the printer and shake them well left to right and top to bottom. it may work fine.
if you did all these steps , and still find that problem is not solved, you may have to contact the concerned service technician for advanced help
All the best from FixYa
Oct 23, 2008 | Kodak Office Equipment & Supplies
Cartridge alignment using vista
Option 1:- This method of aligning or cleaning ink cartridges will work for most computers and printers. Follow the instructions below to align (calibrate) or clean the ink cartridges:
(NOTE: If the following steps are not the same as those you see on your computer, skip to the next option. Each option does not work on every computer.)
Click Start, then Printers and Faxes.
Click the desired printer icon to highlight it.
Click File, then Printing Preferences.
Click the Services tab.
Click Open Toolbox.
Click the desired task.
Option 2:- Follow the instructions below to align (calibrate) or clean the ink cartridges:
(NOTE: If the steps below do not match what you see on your computer, skip to the next option. Each option does not work on every computer)
Click File and Properties.
Option 3:- Follow the instructions below to align (calibrate) or clean the ink cartridges:
Double-click the XXXX Printer Assistant icon on the Desktop.
Click the Utilities button or the Tools and Updates button.
Click the Printer Maintenance button.
Option 4:-Follow the instructions below to align (calibrate) or clean the ink cartridges:
Right-click the Printer icon on the Taskbar.
Click Open Toolbox.
On the Device Services tab, click the desired task.
Option 5:-Follow the instructions below to align (calibrate) or clean the ink cartridges:
Click Start, Programs, HP DeskJet (your printer) series vX.X, then HP DeskJet (your printer) series vX.X Toolbox.
Click the Device Services tab.
Option 6:-Follow the instructions below to align (calibrate) or clean the ink cartridges:
(NOTE: If the steps below do not match what you see on your computer, go to one of the other options. Each option does not work on every computer)
Click Start, Programs, Hewlett-Packard, HP DeskJet XXXX series, then Printer Assistant.
Option 7:-Double-click the HP Director icon on the Desktop.
Click the Utilities option.
Jul 17, 2008 | HP DeskJet 5150 InkJet Printer
Ink cartridge alignment problem
well, what i did, and it seemed to work, in the short run anyway. i took and threw my hp in the back of a waste management truck,  then i called amazon.com and i ordered a new epson printer,
Oct 26, 2007 | HP PhotoSmart C4180 All-in-One Color...
HP PHOTOSMART PLUS B209A All-In-One Printer Logo
284 people viewed this question
Seeker5211
Seeker5211
