My hard drive, I'm trying to update it and I think it'd work, because it use to flash so I'm assuming if I update the harddrive it'd work. Anyways, when I try to update it. It's under the name SM Bus Controller or I'm pretty sure it is. When I try to re install it, it says it can't find it's infomation to install It's a Digital Research 320GB external hard drive thank you:)
  • xxgraciehh_r Apr 07, 2011
    My brand is Microsoft and my model is... Prod # ex320aa#aba
    If that is correct. :P
  • 27,725 Answers
Make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
hope this helps
Posted on Apr 07, 2011
  • 36 Answers
The SM Bus Controller is not the driver for your Hard Drive actually. What Brand and model is your computer? You will need to go to that companies website and download the appropriate driver.
It will usually be labeled as "Chipset Driver" or "Chipset Support". Very likely to be "Intel Chipset Software Installation Utility", depending on what computer you have.
My Hard drive has just stopped functioning properly. It is connecting to my PC but I cannot access it through my computer and when it is connected my computer is not functioning correctly either. It has...
Hi ,
The best way I can think to recover your data is to extract the HDD from it's box ( box will be lost ) and connect the drive directly inside your desktop .
You could also try a recovery tool , from here for instance http://www.geckoandfly.com/3163/crashed-hard-drive-hard-disk-data-recovery-software-tools-and-service/
Best regards .
Jan 23, 2011 | Maxtor Personal Storage 3200 (U01E200) 200...
While installing windows Xp it says no hard drive found but displays in BIOS
Sounds to me like your harddrive needs a driver for windows to recognize it. You could try this harddrive utility.
Jan 10, 2011 | Seagate (AU-80GBSATAHD) 160 GB SATA Hard...
DataStation Maxi M.U. 500 Gb blinks red and blue, doesn't read
I just had this problem with both my external drives (I was using the same power cable and just alternating between them). I went and got drive B's power cable and they work fine now. Try replacing the power cable
Jul 19, 2009 | Trekstor DataStation maxi m.u SATA 3.5"...
Maxtor 3200
Seagate troubleshooting Error Code 10, states that drive has failed. (Seagate bought out Maxtor)
Before you resign yourself to everything is lost on this harddrive, how about trying one more thing?
How about putting the harddrive inside in a new external enclosure, and see if it works? I suggest that perhaps the external enclosure it's in, is bad.
The harddrive inside is a 3.5 inch harddrive. Same width as used by a desktop computer. It is a Sata harddrive.
Here's an example of a 3.5 inch Sata, external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3901268&CatId=2780
Just pop the external enclosure open that holds it now, take it out, and install it into an external enclosure like the example above. Plug in the USB cable.
Don't know if this applies to your particular Maxtor Personal Storage 3200, but when I went to search for the type of harddrive it uses just now, I ran into thsi, and thought I would pass it along. http://www.seagate.com/www/en-us/support/downloads/personal_storage/ps3200-sw)
May 10, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Ps3 went blank after software 2.50 update.
it does that 2 me sumtimes try turning on and off
Oct 24, 2008 | Sony Playstation 3 (PS3) Console
INSTALLATION
I don't think this is possible. Still we can work on this.
Even I am verymuch Intersted with these kind of issues. I haven't tried installing XP on USB flash drive. But I installed the XP on USB harddrive and it worked.
We can try this with your co-operation. To boot with the USB devices, first your computer or laptop should have the option to boot with the USB devices. You can check in BIOS, under BOOT order for this option.
If USB boot option is not there, then you cannot boot with the Flash drive, not only flash drive all USB devices. They will work only after booting into Windows.
Comming to installation procedure, installtion is same as installing the XP on harddrive. While installing the XP, at partition page, you can see the USB flash drive, select it and continue the installtion.
If your computer has the option to boot with the USB devices and if the flash drive won't boot into Windows after installtion, then we have to set Flash drive as Active partition from Disk Management, and then we can try. In Disk Management, right click on the USB drive and select set active partition. If it won't allow to set the USb flash drive as active, then it is not possible to install XP on flash drive.
Even I googled everywhere on how to do this, but not information.
Try that and let me know the status. But I am sure, it is possible on Pocket drivers or USB harddrives.
Aug 09, 2008 | Computers & Internet
Computer not reading the hard drive
i have formatted the hard drive and put in all three recovery discs and it still won't load windows xp home edition.. i thought that was what the recovery discs were for.. maybe the hard drive is bad i don't know but if someone is having the same problem i could sure use some help here..
May 10, 2008 | Balance CN6555 Notebook
Strange files on usb drive
The only thing that can make that to your flash is a virus or physical damage to your flash of which i syuspect much of the former.
Do you update your antivirus before running these clean up checks.
If your information on the flash is backed up somewhere or is not that much valuable (which i doubt ) try reformating your harddrive.
If reformatting does not work then it means your flash was physically damaged.
Mar 25, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My harddrive will not save files larger then 4 GB
What is the filesystem format on your external hard drive? there are limits on certain file systems, like maximum size of a single file in fat32 is 4gb. let me know the filesystem on your external hard drive and i will try to consult a few friends for you. regards
Apr 18, 2007 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Computers & Internet Logo
194 people viewed this question
David Payne
David Payne
