Question about Whirlpool Duet GHW9150P Front Load Washer
I have a new machine. It won't run on a ground fault plug. It will run on a regular grounded outlet. It is in a bathroom and the ground fault is required by code.
  • 31 Answers
Hi Gary, It is possible that your ground fault plug is at fault itself. Sometimes the GFIB becomes weak and will trip off without there being a real problem. Some GFIB are rated at 15 amperes and some are rated at 20 amperes. I would recommend that you check it out and make sure that your GFIB is rated at 20 amperes and is new. Even though a GFIB might be rated at 20 amperes, the fault condition that allows the GFIB to trip is a very small amount of current detected between the safety ground...the round hole and the neutral (the larger vertical blade). The 'trigger' circuit is looking for any current flow between the safety ground wire and the neutral wire and that will probably be in the range of 100 milliamperes and above. FYI, refrigerators and washing machines do not like GFIB's
Bottom Line: You can make your washer operate on your GFIB plug by using a ground buster which is an adapter which you plug your washer power cord into the ground buster and the ground buster into the wall receptable. Please keep in mind that if you use a ground buster.....your washer will not have a safety ground. Hope this helps you! Handy Henry
Posted on Apr 09, 2011
Installing sprinkler timer
GFCI is just a protected plug for use in wet areas - like Te one in your bathroom. Your sprinklers will work fine plugged into a regular outlet but it may void your warranty if something happens. If your timer is outside or not well protected from weather then consider installing one of these outlets. 7_11_2013_1_40_33_pm.png
Jun 22, 2013 | Garden
Installing arc fault interrupter with ground fault
Question is vague. Arc fault and ground fault are slightly different.
Are you installing arc fault breaker?
http://waterheatertimer.org/How-to-wire-GFCI.html#arc-fault
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
Code says Maximum 12 boxes per circuit breaker.
Arc fault breaker and GFCI outlet in bathroom?
>>> do not connect this way.
Do not install 2 fault protections on same circuit.
Install the arc fault circuit breaker, and then remove bathroom GFCI, and replace with ordinary outlet, or switch-outlet.
How many outlets can be connected to a bathroom GFCI?
It depends on total boxes on circuit.
Count the boxes. Max 12 boxes per circuit breaker.
How many amps can be connected to 15 amp device?
15 x 80% = 12 amps
Electricians use 80% rule to calculate safe maximum
http://waterheatertimer.org/Color-codewire.html
http://waterheatertimer.org/See-inside-main-breaker-box.html
Add a comment
Apr 21, 2013 | Siemens Seimens Arc Fault Breaker
I am trying to install the light/outlet combo into my 80 year old bathroom. The outlet box only has 1 black wire and 1 white wire which come down from the top of the box...no other wires are available
If the wiring is BX cable (that is, the two wires are inside a flexible metal jacket that looks like a fat coil spring) (you would see the end of the metal jacket inside the box), and the box is metal, then the box is already grounded and you can install a jumper wire from the box to the ground terminal on the outlet. You might have to add a screw to the box. But if you don't have a grounded box, then the right thing to do is to rewire it all the way back to the main panel. On the other hand, if you simply skip the ground wire, the switch and outlet will work but they will be a little more dangerous than before because now you will have what LOOKS like a grounded outlet, but isn't. By the way, you should be using a ground fault protected outlet in a bathroom.
Good luck, be safe.
Oct 10, 2012 | Cooper Wiring Devices Combination Switch &...
Ground fault from box
In California It is code to have a ground fault receptacle where ever water is, Bathrooms, kitchen, laundry ect.
I have a older home that has 1ground fault for all receptacles located in the garage, so to update I have installed ground fault receptacles in all locations where water or dampness is present, even under the kitchen sink cabinets.
Apr 22, 2012 | Cars & Trucks
Had a storm, blew all the breakers got the breakers re-set but now the coffee maker won't even start
Hi, W/D here.
Try something else in the outlet. Most kitchens have ground fault outlet circuits, so you may have a tripped outlet breaker. These type of circuits can come from the panel through a ground fault circuit breaker, or they can go to the first outlet on a run of outlets. If the first outlet is ground fault protected, the others on that same run are protected as well. If another device will work in your coffeemaker outlet, the coffeemaker is probably dead. If another device will not work in the outlet, and your coffeemaker will work in a known, good outlet, you'll need to look at all of the outlets in your kitchen and bathrooms for an outlet with a "test" and a "reset" button on it. If your outlet is on that circuit, you will need to push the reset button to restore power to your coffeemaker's outlet.
Best regards, --W/D--
Aug 12, 2009 | Cuisinart DCC-1200 Coffee Maker
No power in the two bathroom electric outlets.
What do you mean protected, if they where ground fault they have a test button,or the breaker
can be a ground fault, but it is a lot cheaper to buy the outlets. Call someone that knows electric,
because you need to check to see which outlet has power coming from the breaker,because this one
is probably bad, which will not allow any power continue on to the next outlet. Just say you were
going to do this yourself , you need a tester to make sure power is coming to the outlet.
You could buy a ground fault outlet and a regular outlet, but you have to make sure that the ground fault
is wired from the breaker, the power from the breaker, then the wire that Leeds from the ground fault
to the other outlet will also be protected, one ground fault can protect two other outlets that are connected to it in what is called a series. Unless you have a multimeter to test what needs to be tested
you should ask someone that knows electric. If you have any more questions please post back as everyone is more than happy to help. I don't feel comfortable trying to explain to you how to replace
the outlets, it can be dangerous and I would not want you to get hurt just to save a few dollars.
Mar 25, 2009 | Electrical Supplies
Kenmore 417.40412700 tripping GFI circuit breaker
Unfortunatly washing machines are too sensitive for GFI outlet.only way to fix is too take it off the GFI.
Mar 19, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Ground Fault circuit Breaker trips each time a load is applied
The most likely causes in their order of probability are: 1) water somewhere in the circuit causing the hot wire to ground; 2) a legitimate trip caused by a defect in a device plugged into the circuit; and 3) a defective GFCI breaker. In the first case, wait until it has been dry for about a week and see if it trips. In the second case, make sure there is nothing plugged into the circuit and try resetting. In the third case go ahead and put the regular breaker in, then put a GFCI outlet into the first box downstream from the breaker. If installed according to the directions, that outlet should protect all of the outlets downstream.
Feb 26, 2009 | Cutler Hammer 1 Pole 15 Amp Ground Fault
My ULine icemaker just started triping the GFCI plug.
Ground fault should not be used when you have a compressor plugged to it. The start amps can trip a ground fault. You can try to plug the unit on a regular outlet and if it doesnt trip the breaker then unit should be good. You can try to replace the ground fault if you need it (but make sure you have a higher amperage on the new one.)
Dec 23, 2008 | U-Line Icemaker
Ground fault issue
This is not an unusual issue, but an unusual fix. When appliances that use water and heating elements use a ground fault breaker, it often thinks there is a problem to ground, since it is not the regular short to ground like an element. Move it to an area that has a regular outlet, and turn it on the first time. From then on, it should work right.
Dec 19, 2008 | Rancilio Silvia Espresso Machine
Whirlpool Duet GHW9150P Front Load Washer Logo
70 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
