Question about Canon PIXMA MP130 All-In-One InkJet Printer
I changed the black ink but nothing is printed. It came out blank
  • 1,218 Answers
This issues looking printer head problem. check the following Steps for cleaning printer head :
Click on the Start button if you have Windows XP. If you have Windows Vista, click the Windows icon that resides in the lower left corner of your computer screen.
Click on "Control Panel," then "Printers and Other Hardware." Finally click on "View Installed Printers or Fax Printers."
Right-click on the name of your printer and choose "Printing Preferences." This should open a new window; next look for a tab or button marked Maintenance, or something similar.
Find the button that says "Print heads" or "Clean the Print heads" and click on it. You may be asked to choose which print heads; choose them all if you are. Make sure there is paper and ink in your printer, and that it is turned on ahead of time.
Take out the page your printer has printed and see if there are any grids or boxes missing. If there aren't, then you can just exit the program--your print heads are not clogged. If there are grids missing, then click on the "Cleaning" or similarly worded button.
Once the cleaning process has completed, print another page to be sure that your print heads are no longer clogged. If they are still clogged, repeat Steps 1-5 until your printer is printing clearly.
Posted on Apr 07, 2011
My HP C4780 PRINTER WILL PRINT A TEST PAGE BUT NOTHING ELSE. How do I get it to print?
Check the settings in Windows Print Manager.
Make sure that the paper quality matches what is in the printer. If set to glossy, minimal ink is deposited on the page. Also, check the print quality - draft quality provides a minimal amount of ink as well.
Jan 17, 2015 | HP PS C4780 All in One InkJet Printer
Changed ink, now display panel is blank and nothing prints
You need to change your black ink cartridge so that they cannot print. Just check the ink level of your printer then replace the cartridge if they're needed. Make sure that the cartridge you have change are the same and compatible with your printer. Because if they are not compatible with your printer it will not recognize the cartridge.
Jun 03, 2010 | Canon MP520 All-In-One InkJet Photo...
No blank ink being printed or received by fax.
the m/c needs the 5 tank for faxes!Is it a canon cart?The head might be blocked!Go to your printer properties and under maintanace do a deep clean!!Good luck!!
Mar 31, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Color is low but cant print black on printer paper runs through blank
good day, if nothings coming up then u might need to run a maintenance check, use cleaning then test print and see if somethings changed. hope this helps, have a nice day
Feb 07, 2010 | Canon PIXMA MX310 All-In-One Printer
Canon MX850. Print blank after ink changes. The black ink, PGBK-5, ran out so I replaced it with a cheap generic ink tank. But it didn't work, nothing print, not even color copy. I thought the ink is bad...
That is a common problem on all Canon printers, the purge assembly on the right where the printhead parks, has a pump inside and hoses that go to the filters and ink absorbers. When that unit goes out you need a replacement. A job best done in a shop. When the printhead is not cleaned and primed properly you get blank pages no matter how full the inks are.
Dec 24, 2009 | Canon PIXMA MX850 Multifunction Printer
Epson 9800 is printing blank paper
Sounds like a head issue. May need replaceing
Jun 05, 2009 | Epson Stylus Pro 9800 InkJet Printer
Black ink won't print
check printer preferences and settings.
May 31, 2009 | HP PSC 1350v All-In-One InkJet Printer
Canon iP90 only prints blank pages
Did you try to wipe the cartridge.Maybe there's a clogs. inside.
May 28, 2009 | Canon PIXMA iP90 InkJet Printer
Remove the printer from control panel, under installed printers, then unplug the usb cable and reinstall the printer drivers using printer cd, or download from canon support website.
Apr 27, 2009 | Canon PIXMA iP90 InkJet Printer
Printing only blank pages
you have to go to the printer settings start printer properies ink or color than change to color because you can set your printer to print color or just black does not matter if that one has color if the setting is for black it will print just black
Dec 02, 2007 | HP DeskJet 3940 InkJet Photo Printer
Canon PIXMA MP130 All-In-One InkJet Printer Logo
227 people viewed this question
old marine
old marine
