Question about TDK Computers & Internet
Tape life What is the expected life in hours and data (GBytes) of these tapes? Thanks Robert
  • 661 Answers
It depends on which tapes are used.. it should be on the packing of the tapes themselves, it should tell you how many write cycles they are good for... just like video tapes and audio cassetes these tapes wear out in the same way.
Posted on Sep 30, 2008
I have a Fisher RS636 receiver. I can't seem to record from "Tape 2 to Tape 1" or from 1 to 2. I don't have a remote. Will this be a problem? Can you guide me through procedure. Do...
Most receivers have a dub switch and it would still be in one direction only, say Tape 1- >> Tape 2. Lacking a dub switch the Tape Loops are in an order like that so monitoring the one upstream of the other allows the second one to see it as a source.
Aug 22, 2011 | Audio Players & Recorders
Can you run a vhs tape 24 hours
everything in life needs rest at one time or the other..
but then running a vhs tape for 24 hr isn't going to kill it..
it can work for 24 hours.
just ensure to off it when you are not using it ie when you sleep
Jan 09, 2011 | 1999 Daewoo Lanos
I need to locate a "reel to reel tape deck repair service" in the Washington DC/Baltimore Maryland area. The deck is a "Dual, model # TG 28". Do you know of any service providers?
Hi ajn55,
I am currently working on restoring a Dual TG28 RTR tape deck. Let me know what your problem is with your unit and I will tell you if I can repair it. I am located in Northern Virginia - Reston Area. Contact me directly at tnuh_trebor@yahoo.com.
Thanks,
Robert
Sep 13, 2010 | Dual Audio Players & Recorders
What is the life time of 400 / 800 GB Data Cartridge for LTO Ultrium 3 Tape ?
The life expectancy for LT03 tape media is 30 years if kept in the proper storage environment (cool and dry). BTW StorageTek warranties LTO media for as long as you own the media and store it within the specified parameters.
Ideal conditions are 60 degrees F and 20% relative humidity. Note a 10% change in either temperature or humidity will shorten the lifespan by 50%
411byJay
Aug 14, 2010 | Dell 400/800 GB Data Cartridge for LTO...
Whats the life span of an ultrium 2 tape??
15 to 30 years archival
5000 cartridge loads/unloads
Approximately 260 full file passes. (One file pass is equal to writing enough data to fill an entire tape.)
Jun 23, 2010 | Dell 200/400 GB LTO Ultrium 2 Tape Media...
Tapes 4 years or older won't play - blue screen/no audio
Answer is No. 2. You probably had light clogged heads and by running couple of tapes, you have cleaned it somewhat. Now complete the cleaning using a new head cleaning tape. Run it for about 10 seconds but not more and you'll be ok. It is recomended to clean head by professional soon. Technician will be cleaning each head manually and you would be sleeping well for a lot longer. -James
Mar 29, 2009 | Sony Handycam DCR-TRV120BT Digital...
Canon es900 8mm camcorder won't allow tape insertion
Canon ES series camcorder was designed with 1000 hour capacitors on the processor boards. When the time comes these capaictors loose value and create problems for the main computer to communicate with other mechanical system in the camcorder. We were able to service well 7 years ago but the life of these component has aged too much to make it good anymore. I wish I have a better news for you but the success repair on 'ES model is very slim and if repaired, the labor charge may run many times over of the value of this camcorder. You can probably obtain a newer used camcorder at decent price and get all you tapes into DVD quick. Good luck -James
Mar 27, 2009 | Canon ES900 Camcorder
Backup Problem
80GB is the non compressed and 160GB is fully compressed. Based on my experience youll never get a compression rate of more than 1.5 to 1, so you should expect to get more than 120GB on the tape.
The issue that you are having is that you are using the drivers that either are built into windows or came with the tape drive and not the driver from symantec.
Go into Tools->Wizards->Device Configuration Wizard and follow the step to "Install tape device drivers". This should take care of the compression issue.
Dec 09, 2008 | Dell PowerVault 110T DLT VS160 DLT Tape...
New tape drive
Didn't realize i had to install a Veritas tape driver to allow Veritas to see the drive.
Mar 24, 2008 | Veritas Backup Exec 10 for Windows Servers...
Computers & Internet Logo
54 people viewed this question
Top TDK Computers & Internet Experts
David Payne
David Payne
Are you a TDK Computer and Internet Expert? Answer questions, earn points and help others
