Question about Garden
How do I rekey the Schlage F60SK deadbolt? - Garden
SOURCE: how to change the battery on my BE365-CAM-716 Schlage Keypad Deadbolt
Problem fixed by having my wife look it up on the Schlage website. The deadbolt has a flash memory so your combinations and codes will not be lost when the batteries are changed.
Posted on Sep 30, 2008
  • 384 Answers
SOURCE: new schlage deadbolt stuck in locked position
Make sure that the tang from the lock side actually engage the mechanism in other side of the door. If the tang is too short or not engaged the lock will not work. Also check that the two screws connecting the lock to the other side is actually tight.
Posted on Jun 24, 2009
tbirdfan1
  • 3051 Answers
SOURCE: deadbolt stuck on lock position
hello there:
you will need to dissasemble the deadbolt there is a plastic piece that wears out over time and once this wears out it wont work right probably best just to replace the deadbolt (sorry)
Posted on Jul 22, 2009
  • 670 Answers
SOURCE: How do I unmount a schlage keyed deadbolt?
There should be two hole plugs on the face of the interior deadbolt housing, above the key slot. They must be pryed out to access the screws. Unless it is installed inside out, then the the plugs will be outside. Yes I have seen this before or I wouldn't have mentioned it.
Posted on Sep 27, 2009
  • 3 Answers
SOURCE: remove schlage deadbolt
Schlage B160 - need small screwdriver to insert at bottom of faceplate to pry cover off. Face plate appears flush, but with a penlight you can see the recess at the bottom to pop it off. Screws lie under the cover for disassembly. Seems to be a lock design improvement once you figure out how to remove the faceplate.
Posted on May 07, 2010
How do i remove the plugs covering the screws on the schlage deadbolt?
Schlage FAQs Schlage
The double cylinder deadbolts are keyed on both sides. On the interior side of the home there are drive pins (sometimes called screw covers) covering up the screws. Recommended method: Indent the center of each drive pin with a nail punch. Then use a carbon tip drill bit (about the size of a pencil lead) and ONLY go down 1/8". The drive pin will disintegrate. The drive pins will need to be replaced as they are no longer usable.
Sep 16, 2014 | Schlage Deadbolt. Double Cylinder Deadbolt...
Can i purchase multiple keypad deadbolt with same key?
Yes, Thank you for your inquiry; At FactoryLocks.com we carry Schlage BE365PLY505. The key number is stamped on the key. You can purchase the same entry on our website, factorylocks.com with your existing locks key number. Enter the 5 digit key code on our shopping page that is on the key. We'll get it keyed and out to you quickly.
May 09, 2014 | SCHLAGE LOCK COMPANY Schlage BE365VPLY505...
How to remove plugs from schlage deadbolt?
Thank you for your inquiry. These are small plastic plugs on your double cylinder deadbolt. These are just held in through friction. Just take a small screwdriver and pop them out. Factorylocks.com can help you with your Schlage hardware needs.
Mar 29, 2013 | Schlage BE365-PLY BE365PLY626 Satin...
Will a schlage b60 fit in the same holes as a schlage regent deadbolt
I'm not sure what the regent deadbolt is, but if you look at the attached Factorylocks.com youtube video it will show you how to resize a Schalge B60 deadbolt.
Dec 18, 2012 | Locks & Locksmithing
Do I have to reprogram my lock after changing the battery?
Does the Schlage Keypad Lock or Keypad Deadbolt need to be reprogrammed after changing the battery? The Schlage Keypad Lock and Keypad Deadbolt does not need to be reprogrammed after replacing the battery. All settings are retained in the memory of the lock, including valid user codes and the programming code.
I'm including a link to the pdf file of the complete installation and programming instructions:
http://consumer.schlage.com/Project%20Documents/P515-859.pdf
You may also find more useful information on this page:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx#1
Apr 05, 2011 | Schlage Camelot Deadbolt Keypad, Satin...
Schlage Secure key deadbolt is seized up. The reset key will not move at all in the lock. It is supposed to move 30 degrees to the left to reset the lock. It worked once. We have been using our front...
The best way to free up a lock is with graphite powder. Give it a good dose (put down some newspaper first to catch any falling particles) and "puff" it in. Do this several times, working the key between times and after. If it is still stubborn, loosen the interior bolts that hold the halves together. Loosen just enough so that the halves can re-orient themselves slightly (called "wiggling in"). You'll find a spot where the lock works smoothest. Tighten up the blots, but don't over tighten. Continue to work the key until you're satisfied that the position is as good as you can get it. Graphite is available at Lowe's, Home Depot or even Hobby Lobby (used for Pinewood Derby cars). Same stuff. By the bye, you should use graphite on all your locks from time-to-time. It keeps the cylinder, springs and pins freed up, making the action of the locks very smooth. I never work on a lock without adding graphite powder first.
Best regards, --W/D--
Jan 16, 2011 | Garden
How do i rekey the deadbolt to fit the doorknob key?
You would need to take it to a lock smith or an ace hardware. also bring one of the doorknobs so they can key it alike. Unfortunately, keying locks is not something that you can do without advanced equipment and experience.
Aug 15, 2010 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
I have a schlage deadbolt without the original key. is there any way to rekey without having to take cover plate off top of cylinder?
yes call lock smith for about thirty dollars they can make you a key right on the spot without removing lock.
Jan 05, 2010 | Electrical Supplies
I have several ''gatehouse'' deadbolts and i can't get the core out in order to rekey them. how can i get it out or find instructions?
Here is a link to the manual for rekeying all Schlade/Gatehouse locks.(It's in PDF format)You can download,save,print,or view online.
Please take time to rate this fixya
May 14, 2009 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
How to change the battery on my BE365-CAM-716 Schlage Keypad Deadbolt
Sep 21, 2008 | Schlage BE365-CAM BE365CAM613 Oil Rubbed...
Garden Logo
73 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
