Question about Vornado REH1-0001-01 VortexHeat Compact Heater
Have Vornado Vortex EH1-0025-01 model VTH. Had to take apart to replace points on temp. control switch. Pulled wires off to take out the control assembly to replace points. Wrote colors of wires and their positions on the switches on piece of paper. Girlfriend moved everything (because it wasn't out of the way far enough?). Result: paper gone. Any assistance? Can't seem to find wiring schematics online anywhere.
3 Suggested Answers
SOURCE: I need a new on/off switch
I have the same problem with a VH Vornado heater
No need to change switch.
The switch has to sets of contacts, but uses only one. This one is burnt out
Just reconnect the black cable (hot) to the opposite free switch connector.
Then interchange the white (resistance) with the brown cable (ground for switch light)
You may have to turn around the switch because the heater will turn on on the "OFF" position
Check your cables with tester, to avoid any short circuit.
Posted on Jan 21, 2010
Oliver773
SOURCE: I am writing about a vornado TouchStone Vortex 500
Call 1-800-234-0604 - This is Vornado's consumer service line. This manufacturer is well known for great customer service, and they should be able to tell you if something is wrong with the unit. If so, and if the heater is under warranty, they will fix it or replace it for free. You won't even have to pay shipping to send the unit in.
Posted on Oct 22, 2010
Vornadofan electrical wiring. Old fan runs strong but replaced the wiring and now need to check which wires are what...can not find on vornado website, not in manuals either.
Good luck there. Vornado is very vague and does not disclose any information. If it is a vintage vornado, you can type the model number into the search box, hit images and they have a few showing the wiring.
Jul 22, 2017 | Vornado Dryers
Can't figure out how to take model EVH vortex heater apart to clean.
If you have access to a air compressor just blow it out, caned air is so so.You can put put the ca under hot water and get better pressure.
Jul 06, 2011 | Vornado REH1-0001-01 VortexHeat Compact...
I have a Vornado Digital Vortex Heater. The fan stopped running in less than a year though the lights still come on.
Finding parts for a heater like this would be all most imposable you could how ever take it apart and put 115 volts to the 2 wires coming out of the fan to see if it is the fan or the switch that controls it. Check the switch with a continuity meter if the switch is bad you might be able to replace with a toggle switch the safest thing to do would be buy a new one these small heaters are mostly solid state which means you can't repair them .
Good luck.......
Nov 25, 2010 | Vornado DVH Compact Heater
I am writing about a vornado TouchStone Vortex 500 Heater. I plugged in another heat in another room and the lights went out. I reset the circuit breaker but the Vornado will not turn on. Cathy Giuli...
Oct 22, 2010 | Vornado TouchStone Vortex Heat 500 Heater
Model FA1-0013 TYPE SWAN SERIAL # MAY00 VORNADO FAN When you plug it in and turn on the switch it does not work.
The motor has a single-use fuse in the run winding; that may be tripped. Or there could be no power going to the motor. Some of the swans had a power lead that was too short and pulled out of the switch. Take the 5 feet/screws out of the fan and remove the bottom plate. Are any of the wires loose that go to the switch? One power lead goes to the white wire that runsd directly to the motor: is that hooked up? If you need more help, contact me.
cawicks at g mail
Aug 29, 2010 | Vornado Circulating Fan
My panasonic vortex, when in cleaning mode, does not dry and does not **** the water back into the holding tank
Probably due to wire being cut inside cleaner. My cleaning system charges, and the indicator lights for cleaning and charging light up, but I don't believe water is flushed through system. Took apart and found broken wire. Working to replace wire and reassemble, but having issues with disassembly so I can replace wire.
Nice razors, but not as durable as the older models.
Aug 18, 2010 | Panasonic Vortex HydraClean Men's Electric...
Power switch broken
I have the exact same problem...Have you found a place to buy a switch for the AVH2? I'm a licensed electrical contractor and I can replace the switch myself as well...if I knew where to get a switch. Thanks.
Jun 25, 2009 | Vornado AVH2 Vortex Whole Room Portable...
Fan shuts down, shortly after heater is turned on
I have a Lennox furnace that starts but won't ignite.
Turn up the thermostat, you can hear it start but the burners don't come on
Feb 08, 2009 | Vornado TouchStone Vortex Heat 500 Heater
My Vornado TouchStone Vortex heat 500 Heater - temperature
After calling Vornado Corporation, they suggested that the room temperature monitor might be failing as it read 65 degrees no matter where you started the heater. I took the unit back to the store I purchased it from, and we unpacked another unit and found the same problem existed. Therefore, the product is not capable of heating a room properly and I will continue my search for a space heater to control the temperature in my upstairs office which does not have air ducts for heat.
If anyone has recommendations I would be interested in their comments.
Thank you.
Nov 19, 2008 | Vornado TouchStone Vortex Heat 500 Heater
Vornado REH1-0001-01 VortexHeat Compact Heater Logo
376 people viewed this question
Top Vornado Heating & Cooling Experts
Bill Long
Lyle Siemens
Lyle Siemens
Roberto Lopez
Level 1 Expert
Are you a Vornado Heating and Cooling Expert? Answer questions, earn points and help others
