Question about Drills
I have ceramic (terra cotta) block walls in my basement (house was built around 1920. The blocks are ridgid and were not laid very evenly, although the walls are sound. Plastering is an option, but with the wall so uneven, it doesn't look as good as desired. I would like to find out how to fasten cement board or some other type (waterproof) wall to the blocks. They can be fastened at the top to the double 2" x 4" floor plate under the floor joists, but need to know how to fasten them at the bottom. Thought of drilling and securing a board across the bottom using molly screws, tried a masonary bit, but were not successful. The blocks are 11.5" x 12" x 8". The center is divided into 6 sections and the thickness between the outer ridges is 1/2". We would have to drill through the 1/2". Would a ceramic bit work? If so what size do you suggest? We thought of gluing a board across the bottom, but would have difficulty putting pressure onto it to hold it in place while the glue dries. Any suggestions are appreciated.
  • 843 Answers
My house is of similar age and construction. I built a nice TV room in the basement several years ago. My method was the same as the way interior walls are built in new construction. I nailed a 2x4 to the ceiling near the wall. I nailed another 2x4 (pressure treated) to the concrete floor directly below the 2x4 on the ceiling. Then I toe-nailed vertical studs in place. For the studs I used 2x3's since this allowed me to get a nice flat plane on the front surface while allowing an inch of space on the back for irregularities of the block wall. I then covered the studs with water resistant drywall. The results were excellent and have held up very well. I also use a dehumidifier, since my basement was somewhat damp. I built the dehumidifier into a cabinet so that it draws air from the space between the block wall and the 2x3 wall. I don't need to run the dehumidifier in the winter. For the interior walls separating the TV room from the rest of the basement (furnace and workshop area) I used 2x4s for the studs, but the 2x4 along the top and bottom were just like the first wall I described. And by the way, in order to nail the pressure treated 2x4 to the floor, I used a power-nailer that uses charges that look like 22 caliber gun blanks. This seems spooky, and is wicked loud (use earplugs and safety glasses!), but it is inexpensive and very effective. The nails don't have to resist pulling out, they only have to resist being slid around, since the wall stud holds the pressure treated 2x4 against the floor. Good luck!
Posted on Apr 07, 2011
Testimonial: "Good ideas submitted for possible solution to my problem. Thanks"
  • 1 more comment
  • kayw2r3 Apr 07, 2011
    I sincerely appreciate all your information and congratulations on your success with your basement.
    One thing that I didn't mention and possibly should have is that I live in an area with a very high water table and clay soil, therefore, have french drains with chip stone on 3 of the walls. They work very efficiently to keep the water out of my basement unless the gutters ice up and overflow during thawing as they did once this winter
    With this in mind, perhaps a treated 2' x4' could be placed along the peremiter with spacers to the cement floor to hold the 2' x 4' against the wall. It would not be the best solution, but could it work?
  • Al Kupchella
    Al Kupchella Apr 08, 2011
    Kay, Not sure of the configuration you are describing. I think you mean that the french drain is inside the basement along the base of the wall. Assuming that, I suggest that you lay the PT 2x4 along the base of the wall on top of the chipped stone. Drill holes in the PT so that you can drive 2 ft pieces of rebar down into the chipped stone. This will hold it against the wall. Then fit vertical studs (2x3 or 2x4) between the PT and a 2x4 along the ceiling.
  • kayw2r3 Apr 10, 2011
    Sorry to be so long getting back with my comment.
    Sounds like a good plan, if I am allowed to use the PT inside and not sure if the code will allow that, will have to check. I figured if it were against the wall under the chip stone it might be acceptable. Yes the French drains are on the inside of the wall. Thank you for all your help. Will check on codes and go from there. The only other solution would be to plaster. I don't need to use it for living space for myself, just want it to look better, but in case a future owner would want to use it for more, I want it done to where they could use it. Thanks again.
How do I moisten it so it is not dry
Depending on how much tobacco you want to re-hydrate, get a terra-cotta pot and break it into pieces and soak a piece (or several pieces) in distilled water. Put the soaked chunk(s) in a plastic zip-lock type bag with your tobacco. Leave it overnight and check the tobacco for moistness.
Be sure to use distilled water and a new pot to start. It might be a good idea to boil the terra-cotta in water for ten minutes or so in order to kill bacteria. Using tap water can introduce bacteria and chemicals (chlorine) into your tobacco. You do not want that.
The terra-cotta will prevent soaking your tobacco with too much water and causing mold.
Apr 07, 2015 | Cooking
Woodstove smokes into the house
I've never used a ceramic chimney, or seen one for that matter. I know that the dual walled vent pipe works better when warn/hot. Can't explain it real well but the inner pipe gets hot while venting the heat and smoke. And between the inner and outer wall is cooler air, which is drawn down towards the wood burner. Creates a suction by the exhaust out of the center pipe. Mine smokes up the house when I leave the doors open and when it's a low flame inside. I'm sure you've checked on the manufacturers' specs for venting but, if you don't already know, look into the thermal dynamics of a dual walled vent pipe. And also a ceramic as you have. Has to be something with your stove install or vent pipe. Hope this couch advise helps!
Apr 04, 2017 | Heating & Cooling
Wendy Wu and the Terra Cotta Mystery
You gotta go to your left, it is in the corner
Oct 19, 2012 | Bandai Digital Entertainment Gundam: True...
Rigid band saw tires come off
Glue them on. You might need to replace them. They're standard for just about all brands of 14" band saws. If you do that, check into replacing the blocks that rub the sides of the blade with ceramic. They work great.
Mar 29, 2012 | Ridgid 14" Band Saw with Stand
I have noticed blue mold in my basement coming from behind the area that has wood paneling, but also around the entire edge of the floor even where the walls are concrete (both interior and exterior...
This mold is from dampness in the basement.
Often this is a result of no vapor barrier installed when the insulation is put into the walls. Moisture is allowed to seep through the walls and gets into anything, even concrete.
The other problem may be from a lack of weeping tiles outside the house.
When the contractor formed the foundation walls, he was supposed to install weeping tiles to keep moisture out from outside.
Most older houses don't have this, and I'm seeing it more and more.
I would advise contacting a general contractor and getting some advice from them. You may have to have weeping tiles installed, which consists of tearing up the ground around the foundation to do so.
Then you may have to remove the flooring and wall panels as well as the drywall to install a vapor barrier.
Good luck.
var geo_Partner = '1890d1e7-e721-4f9c-b474-1a19eda23e94'; var geo_isCG = true;
Sep 22, 2011 | Computers & Internet
Condensation on double glazed windows
hi check the air bricks built into your walls are not blocked
Nov 17, 2009 | Flex 3" Condensation Drain Horizontal
Leaking basement foundation
It sounds like the ground has settled around the area where the leak is, hence the traveling water. The right way to fix the problem would be to remove the porch, dig up around the basement wall, apply a sealant to the outside of the wall, install weeping tile and re-grade the soil to drain away from the house. Your best bet to begin with may be to try to re-grade the soil so it is sloping away from the house, however this is only a temporary patch, if temperatures get below freezing there is a possibility that moisture in any crack in the wall could cause further cracking and leaks.
May 25, 2009 | Hand Tools
Drills Logo
298 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
