Question about Garden
I have a 72" liquit
  • 10,319 Answers
Wiring has a short in the harness to the ignition switch most likely if all these parts wre replaced as you stated
Posted on Apr 07, 2011
Toro lx 500 riding lawn mower
check the connections from the battery to starter-check the fuses -and relays than start with the safety switches --seat-clutch-and cutter deck the safety switches are a kill switch
May 24, 2013 | Garden
Toro riding mower electrical issues
there is a safety switch on the clutch/brake pedal
Apr 27, 2012 | Garden
I drove my 1999 accord EX to work & 8 hrs. later I tried to start it and it did nothing. Tried jumping still nothing. Put new battery on and it still did nothing.What is the problem?
Hi, diagnosing a no-start condition requires a logical approach to figuring out what might be preventing your car from starting. First, if the engine won't even crank over when you turn the ignition to START, your car obviously won't start.
When you turn the ignition key to start your car, voltage from the battery flows through the ignition switch to the Park/Neutral safety switch and/or brake pedal or clutch pedal safety switch (you have to push the pedal down before the circuit will complete) to the starter relay or solenoid. When the relay or solenoid is energized by voltage from the ignition switch circuit, it closes a contact that routes more power from the battery directly to the starter to crank the engine. The starter motor spins, pushes the starter drive gear to engage the flywheel and cranks the engine.
If the engine fails to crank, there is a fault in one of the components in the battery/ignition/starter circuit.
Ten Reasons why you car won't start..
  1. Low battery (Check battery voltage, recharge if low, or jump start with another vehicle or battery charger).
  2. Loose or corroded battery cables (Inspect, clean and tighten BOTH ends of BOTH battery cables).
  3. Bad starter relay wiring connections or ground connection (Inspect, clean, tighten wiring connections).
  4. Bad starter relay/solenoid (Check for voltage at relay, if relay has voltage but there is no "click" when key is turned to start, replace relay).
  5. Bad starter (Jump battery voltage direct to starter to see if it spins, or remove starter and have it bench tested at auto parts store).
  6. Damaged starter drive or teeth on flywheel (Remove starter and inspect drive gear and flywheel teeth, replace damaged parts if necessary).
  7. Bad ignition switch (Check to see if voltage reaches starter relay/solenoid when turn to start. If not, check for open P/N switch and brake or clutch pedal switch. Replace ignition switch if defective).
  8. Open P/N safety switch, or open Brake Pedal Safety Switch (automatic transmission) or open Clutch Pedal Switch (manual transmission). Bypass switch with jumper wire to see if engine cranks, or use test light or voltmeter to check for voltage passing through switch when ignition is turned to start.
  9. Engine seized due to bearing failure or internal damage (Use socket and long handle to see if engine can be turned by hand, if not engine is locked up).
  10. Engine hydrolocked due to coolant leak from leaky head gasket (Use socket and wrench to see if engine rotates, remove spark plugs and see if coolant comes out or engine can not be cranked with plugs out).
Hope it helps identify and solve the problem
Jan 16, 2011 | 1999 Honda Accord
I have a 2003 Saturan Ion that won't start
Hi, this is what you should do when your car won't start. Diagnosing a no-start condition requires a logical approach to figuring out what might be preventing your car from starting. First, if the engine won't even crank over when you turn the ignition to START, your car obviously won't start.
If the engine fails to crank, there is a fault in one of the components in the battery/ignition/starter circuit. Check it out.....
  • Low battery (Check battery voltage, recharge if low, or jump start with another vehicle or battery charger).
  • Loose or corroded battery cables (Inspect, clean and tighten BOTH ends of BOTH battery cables).
  • Bad starter relay wiring connections or ground connection (Inspect, clean, tighten wiring connections).
  • Bad starter relay/solenoid (Check for voltage at relay, if relay has voltage but there is no "click" when key is turned to start, replace relay).
  • Bad starter (Jump battery voltage direct to starter to see if it spins, or remove starter and have it bench tested at auto parts store).
  • Damaged starter drive or teeth on flywheel (Remove starter and inspect drive gear and flywheel teeth, replace damaged parts if necessary).
  • Bad ignition switch (Check to see if voltage reaches starter relay/solenoid when turn to start. If not, check for open P/N switch and brake or clutch pedal switch. Replace ignition switch if defective).
  • Open P/N safety switch, or open Brake Pedal Safety Switch (automatic transmission) or open Clutch Pedal Switch (manual transmission). Bypass switch with jumper wire to see if engine cranks, or use test light or voltmeter to check for voltage passing through switch when ignition is turned to start.
  • Engine seized due to bearing failure or internal damage (Use socket and long handle to see if engine can be turned by hand, if not engine is locked up).
  • Engine hydrolocked due to coolant leak from leaky head gasket (Use socket and wrench to see if engine rotates, remove spark plugs and see if coolant comes out or engine can not be cranked with plugs out).
Dec 02, 2010 | 2003 Saturn ION
Toro Z Master Cooling fan will not turn on.
i would check water temp sender in engine block or thermostat housing.take wire off with key switch in on position touch wire to clean ground tis completes ground curcuit to relay fan should come on if so test sender with test lite or ohm meter. should be open curcuit or no lite when cold and go complete or lite when comes up to temp. clamp test lite to sender and probe to positive. hope this helps
Jul 17, 2010 | Toro 60" Cut Zero Turn Rider Diesel...
I have a 1997 grand prix. Most days it starts. once in a while it will not start. You can sometimes rock key back and forth quickly and it will catch. But most of the time odly enough wait over night and...
Jul 14, 2010 | 1997 Pontiac Grand Prix
My car does not start or turn over. The radio works and so does the fan.
Jul 14, 2010 | 1995 Suzuki Sidekick
2002 GMC Envoy, i put the key in ignition and vehicle will not start sometimes and other times is starts fine. we have checked the starter, battery and battery connections, all fine. Changed the starter...
Ignition switch and neutral safety switch. Next time it happens wiggle thekeys in the ignition switch and try to restart.If it starts its probably the ignition switch. Then locate neutral safety switch on brake pedal and put meter on B+ wire from switch to starter relay and see if you get B+ on the would -be- crank. Next locate B+ wire from starter relay to starter hook a meter to it and see if you get B+ on the would -be crank.
Where ever B+ is missing is your problem.
Apr 14, 2010 | 2002 GMC Envoy
Toro lawn and garden tractor will not start all of the stafety switches are working and the battery is charged but the safety relay will not energize.
Remove the two wires going to the switch and use a jumper wire to bybass the safety switch if it starts replace the switch, make sure power is getting to the relay, relays have two power wires one that activates the relay coming from the physically activated safety switch the other is a power wire that is activated by the ignition switch, you must have power to the relay with ignition key on.
Jul 15, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
