Question about Kitchen Ranges
How old is Rheem Model 81v52d c water heater?
4 Suggested Answers
  • 3 Answers
SOURCE: Rheem energy miser. Model 81v52d c, 50 gal. Is not
The water heater was taken out to tile the floor and put back in 2 days later. It has power but is not heating the water. Can you help?
Posted on Feb 17, 2010
mkh5094
  • 145 Answers
SOURCE: TRYING TO REPLACE MY OLD RHEEM WATER HEATER MODEL
I would say your water heater is from the fury series; new model number 82V52-2. I've included a link with my solution that you should take a look at. You could also look at water heaters of a different brand if this one isn't available in your area. Kenmore, GE, and Hotpoint are all very good brands of water heaters.
http://www.rheem.com/product.aspx?id=09DF2BDD-5E11-4D32-B574-84ACFB8A4619
Posted on May 25, 2010
  • 5245 Answers
SOURCE: Rheem 50 gallon Electric Water Heater 81V52D C repair ideas needed
It could be element shorted to ground through steel tank, so don't touch tank when breaker is ON.
Or you have undersized 12 gauge wire and 20 amp breaker and the heat has loosened breaker on the busbar. Breaker trips when heat exceeds breaker limit. Jiggle breaker and listen for crackling sound.
To restore hot water now:
Turn off circuit breaker, and open top cover then Push in reset button on top of heater to restore functionality. Put back insulation and factory cover.
To fix water heater: test and replace bad element.
http://waterheatertimer.org/How-to-test-water-heater-element.html
If problems continue
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#trip-breaker
http://waterheatertimer.org/Troubleshoot-household-electricity.html
Posted on Sep 25, 2012
Water heater is not heating water, but it is getting electricity (81V52D C)
I would start by checking the circuit breaker and the reset button if the heater has one just to get the easy possibilities out of the way. Next check the ground wire to may sure the ground wire is firmly connected. Electronics need a complete circuit in order to work. It is always possible that the wires have become corroded or broken. Please test the wiring to insure that all wires are unbroken. Please see the link below for more specific information.
http://waterheatertimer.org/Test-electricity-to-water-heater.html
Dec 14, 2012 | Rheem 81V52D Water Heaters FOR 220 VOLTS
Sep 25, 2012 | Rheem 81V52D Water Heaters FOR 220 VOLTS
Please help!! I can't find the reset button on my Rheem 81V52D C model water tank! I opened the top panel and didn't see a red reset button. Totally confused now. Please help?
if there is no reset button, you should be able to turn the breaker off for a few minutes. then turn it back on. if its an electric water heater! it should reset it. good-day !
Mar 26, 2012 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
How many amps does a Rheem 81V52D with both elements hooked up pull?
Does it have the wattage on it anywhere? For simplicity if it is a 4400 watt and you are running it on 220 volts, it would be 4400/220 which would be 20 amps. Now you can put in your own numbers and figure it out yourself. Hope this will help you. Please rate my answer so I am rewarded points for it.
Feb 01, 2012 | Rheem Water Heaters
My 50 gal elec water heater model #81v52d only stay hot during a shower for 10 min how do I make the water hotter is there a dial on it?
Remove the four screws that hold the covers on the side of the water heater and carefully spread the insulation apart to see the thermostat,reset button and heating elements. The thermostat will have a adjusting screw on it that you can turn with a small blade screwdriver.There is a arrow pointing to temperature setting that you can adjust by turning the screw clockwise to increase the temperature. They normally come from the factory set at 120 degrees so you can turn it up to 135-140 and see if that helps.
Thank you and I hope this helps you.
Jan 20, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
I have a Rheem model number is 81V52D and I think I need to check the thermostat. Do I need to drain the unit in order to check the thermostat?
No you do not need to drain water heater when checking or replacing thermostats:
Water heater is drained when replacing elements or cleaning sediment out of tank.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
Also look at following links: These links can teach you everything about fixing ordinary tank-type electric water heater using generic parts from hardware store.
http://waterheatertimer.org/How-electric-water-heater-works.html
http://waterheatertimer.org/How-to-replace-element-and-clean-sediment-out-of-electric-water-heater.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 20, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
TRYING TO REPLACE MY OLD RHEEM WATER HEATER MODEL NUMBER 81V52D C SERIAL NUMBER RH 1297B30669 50 GAL US TANK ELECTRIC WHAT IS THE UPDATED VERSION?
May 25, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Rheem energy miser. Model 81v52d c, 50 gal. Is not heating any water. I don't have the manual for it to see what troubleshooting options there are.
Nov 14, 2009 | Water Heaters
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
