Question about Hotpoint First Edition WMA12 Front Load Washer
Hotpoint ultima wma75
The water will not drain on hotpoint ultima wma76
  • 203 Answers
Sounds like the filter is blocked you can take the filter out and clean it and check the hole for lint a sock or a coin etc. if this helps please rate me joe
Posted on Nov 21, 2008
Hi my wma12 has a filter. Turn all electrics off. Take off the back panel at bottom left is a black bendy pipe with a clip on it. Obviously drain all water via the hose lower than the washer first. remove the clip from the black pipe that connect to the washer this is the filter it has a plastic ball inside. Remove all debris inside replace ball and reconnect to the washer drum with clip. Hope this works. If not it sounds as if your drain pump has died. These are around £16 to replace it is the part the outlet hose connects to it is helf on with plastic clips and should be easy to replace. Thanks
Posted on Jan 05, 2009
  • charlie Jan 05, 2009
    ebay item
    delivered for £10 bargain
    check models
Hotpoint WMA76 - been on a normal wash cycle but wont spin to drain water - cycle finished, drum full of water and cant empty. How do we empty it to open machine?
Remove drain outlet hose from point where it discharges into waste pipe, and lay the hose down into a bucket or bowl, this should let the water syphon out, enabling you to open the door.
Dec 29, 2010 | Hotpoint WMA76 Front Load Washer
Light of a red tap
This is indicating a problem with the water supply, check the inlet hose/s for a restriction or kink in the hose/s.
Make sure the tap/s are fully turned on, and that there is a good water prerssure.
May 27, 2010 | Hotpoint WMA76 Front Load Washer
Hotpoint ultima wma76 water level switch loaction?
Should be located under the lid near the top edge, round shape with a tube going to the bottom of it and wires in the front. To remove from the frame turn the whole thing 90 degrees as fitted with with rectangular fitting on rear.
Jan 21, 2010 | Hotpoint WMA76 Front Load Washer
Hotpoint wma76 stops and displays ON
Could be rinse water valve ..Faulty Solonoid coil
Nov 10, 2009 | Hotpoint WMA76 Front Load Washer
Hotpoint ultima wma76 stopped spinning is the motor /brushes in top or bottom of casing had other hotpoints and the brushes seem to go evry 5 yrs or so? are they as easy to change as the older models?
it is as easy as the older modles but the motor is at the bottom and you have to take out the motor to replace the carbon brushes hope this helped.
Aug 29, 2009 | Hotpoint WMA76 Front Load Washer
Hotpoint ultima
The filter is located in the sump hose at the rear bottom of the m/c.
You need to remove the large clip that holds the hose on
Access is gained by removing the lower rear panel.
Oct 25, 2008 | Hotpoint WMA76 Front Load Washer
Hotpoint WMA76 Ultima 6kg
either you got a clog behind the drum or a clog in the draining tube behind the washer i would call sears or where you got it to get someone out there to check it out or if you got the manual of the washer and specs to see maintenance tasks that it requires if you know the make and modal i could get that for you ..
Jun 26, 2008 | Hotpoint WMA76 Front Load Washer
Washing Machine
Which symbol is illuminated? Red keyhole? Child safety? Red tap? End status?
Jun 27, 2007 | Hotpoint WMA76 Front Load Washer
Hotpoint First Edition WMA12 Front Load Washer Logo
201 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
