Question about Dell Inspiron 531s Desktop Computer
Solution to computer shutting down and restarting. This problem can be corrected by replacing this part in the front of the computer under the ON BUTTON> Dell Inspiron 530 531 Vostro Power Button Cable NT294. Ebay price $7!
MDoe
  • 156 Answers
SOURCE: Dell Optiplex GX260 Tower flashing yellow power button
Hi
Power up the Optiplex GX260 and check the QUAD Pack Diagnostics LEDs (located at the back). Compare the LED pattern to http://support.dell.com/support/edocs/systems/opgx260/en/ug/solvprob.htm#1167139 for more info.
Ideally, to troubleshoot and resolve the issues, try removing all PCI devices, disconnect all external devices/peripherals including keyboard and mouse. You may leave the Monitor connected. Power up the PC and check for successful Power On Self Test (POST). If POST completes (generally fails on "Keyboard not present"), shutdown, connect keyboard and try POST again.
If all goes well, install PCI devices one at a time and test successful POST. This will help identity a failing device.
If issue persists, after removing all devices, remove the CMOS battery for about 90 seconds and try POST again. If same, remove all DIMMs (Memory) and check for beep codes. Compare beep pattern to http://support.dell.com/support/edocs/systems/opgx260/en/ug/solvprob.htm#1176760.
NB: Ensure to remove power lead and press power button briefly to use up flea power before working in the system.
If the system beeps, it suggests that the CPU and systemboard are "likely" fine. Install one DIMM at a time and test successful POST. If there no beeps then the systemboard and/or CU is/are at fault.
Regards
Mike
Posted on Mar 27, 2008
gurutim
  • 68 Answers
SOURCE: Dell Inspiron 530 randomly shuts down and restarts
Sounds like it could be a virus. Or, a heat buildup problem - are all fans inside machine working? Is the fan inside the power supply operating? Was there any work done inside the computer recently?
If the hdw is all ok, go out and buy yourself a copy of Norton Internet Security 2009 - 1 user lic - $49.99 @ Staples. Do *not* buy any earlier vers. of this software! Install, update it, run computer computer scan - probably will find/remove some/many viruses.
If this helps, please take the time to rate my response to you.
Thanks and good luck.
gurutim
Posted on Mar 22, 2009
SOURCE: Dell 5150c shuts down orange flashing light
It was a faulty or worn out power supply fan. I just replaced it and the computer has been running for about an hour and a half and still no shut down. The system temperature is stable. It runs quieter now. New fan cost 13.88CAD.
Posted on Apr 06, 2009
As a temporary measure, taking the side panel off the dell 5150c stopped it from shutting down, so in my case it was clearly a heat problem, as suggested by previous the poster. The following instructions assume you're comfortable replacing computer hardware components - do at your own risk!
The solution is to buy an 'air duster' and some thermal compound for the CPU heat sink. If your CPU fan doesn't sound healthy (mine didn't), also buy a new one (ca. £20 on ebay: search for G9474 ).
Read the service manual: http://support.dell.com/support/edocs/systems/dim5150C/en/sm/index.htm for details on how to install / remove the fan and heat sink.
Clean out dust from the heat sink with air duster. Remove the fan, and clean or replace (recommended). Also clean the grill in front of the fan. Clean off old thermal compound from the CPU / heat sink and replace with a thin layer of fresh compound. Replace heat sink and side panel and you're done.
Posted on May 12, 2009
P0W3R GL1CH
  • 185 Answers
SOURCE: i want to restore my Dell inspiron 531 back to factory,
u can try to look in the controll panel to see if there is a restore button in there insted of using a cd
Posted on Nov 05, 2009
Configure acer sk 9610 keyboard
shut down computer are if computer is shut down unplug keyboard from back of computer, restart computer and after the desktop is up and running replug keyboard back into the computer.The computer will then search for the correct driver and install it.
Apr 16, 2014 | Computers & Internet
I am uable to listen any type of sound from speaker and in device manager it is not showing option of enable disable it is showing only hardware scan and properties
Shut the computer down and remove the sound card, restart the computer without a sound card installed then shut it down again. Re-install the sound card and make sure the monitor is connected before you restart. The computer should have seen the card and loaded the correct driver. If you are still having problems shut down and restart in safe mode and troubleshoot.
May 19, 2011 | Compaq Audio card Sound Card
Restarts automatically
If you shut down your Windows XP-based computer, your computer may restart instead of shutting down. The computer may also restart unexpectedly while you are using the computer to perform certain tasks. An error message may appear on a blue screen when the computer restarts.
This behavior may occur if Windows stops responding during a typical operation or during the shutdown process. By default, the computer is configured to automatically restart when Windows stops responding. To view this setting, follow these steps:
  1. Click the Start button, right-click My Computer, click Properties, click the Advancedtab, and then click Settings under Startup and Recovery.
  2. Under System Failure, view the Automatically restart check box. If theAutomatically restart check box is selected, Windows automatically restarts if the computer stops unexpectedly.
To configure the way that Windows responds when the computer stops unexpectedly, follow these steps.
Note: You must be logged on as an administrator or a member of the Administrators group to complete this procedure. If your computer is connected to a network, network policy settings may prevent you from completing this procedure.
  1. Log on to the host computer as either an administrator or the owner.
  2. Click Start, and then click Control Panel.
  3. Under Pick a category, click Performance and Maintenance.
  4. Under the or pick a Control Panel icon section, click System.
  5. Click the Advanced tab, and then click Settings under Startup and Recovery.
  6. Click to select any one of the following check boxes under System Failure:
    • Write an event to the system log
    • Send an administrative alert
    • Automatically restart
I hope this has answered all your questions. If you have any other questions, please contact us at info@custompcrepair.org
Mar 16, 2011 | Microsoft Windows XP Professional
The computer start after 3 or 4 attempt when I press the power button. When the computer is on & I restart my computer from Start - Turn off computer - Restart. - my computer shut down instead of...
If the computer is not truing in first attempt then check for the earthing is OK or not. Then check the power is correctly supplying or not. There may be a chance in loose connection of the switch of your cabinet. If the system is shutting down when you give restart, then it may be problem of power. If the power part is is OK then the operating systems is to re-installed or repaired.
Jan 13, 2011 | ASUS M2NPV-VM Motherboard
PC is restarting while booting
  1. Click the Start button, right-click My Computer, click Properties, click the Advanced tab, and then click Settings under Startup and Recovery.
  2. Under System Failure, view the Automatically restart check box. If the Automatically restart check box is selected, Windows automatically restarts if the computer stops unexpectedly. If your computer constantly restarts while you are using it, or if you are trying to shut down the computer after it has stopped unexpectedly, click to clear the Automatically restart check box.
Dec 20, 2010 | Dell Vostro 1510 Laptop
Computer shut down on it's own and will not restart. I get the blue lights on front but no other activity
You could have a faulty fan and/or heatsink/fan assembly clogged with dust.
When a laptop shuts down and will bot boot up again until it has cooled down, then this is a CPU thermal shutdown and if not corrected then eventually the CPU will fail completely.
Check the fan to see if it spins freely and turns on, if not replace the fan. Also remove the dust off the fan and heat-sink assembly.
If you are still having problems you can purchase a fan assisted cooling pad. Place the laptop on the cooling pad and it provides addition fan assisted air to the bottom of the laptop vents.
Mar 06, 2010 | HP Pavilion dv6000z Notebook
My computer sarts automatically when I want to shut down
it seems that your computer restart when you attempt to shut down. this problem due to short in power button in the cabinet. open the right side of the cabinet.most probably there will be red&white twisted thin wire from front panel for power, the colour may vary manufacture to manufacture.be carfull with it. see at left bottom of your dell PC mother board the wire will lead to two pin specifying power, restart, hdd etc.. short it with your screw driver. if system turn on then it is problem with switch replace it or if it not work then reboot the os.
Oct 24, 2009 | Dell OPTIPLEX 745 PC Desktop
Mar 09, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
My computer won't shut down it just keeps restarting
The most common shut down problem is that the system will reboot rather than shutting down. In most cases, the reboot is triggered because Windows XP is designed to reboot after a critical failure. To stop windows from rebooting in case of a failure, you need to take the following steps:
Right click on My Computer, Select Properties, Click on advance tab, Click on Settings under Startup and Recovery, Uncheck the option Automatically Restart under System failure, Click Ok twice and try to shutdown the pc. If it shows any error code then let me know
Nov 24, 2008 | Toshiba Satellite M65-S809 Notebook
Computer not started properly
the window is corrupt try to repair the window with window xp
May 30, 2008 | Intel D845GVSR Motherboard
Dell Inspiron 531s Desktop Computer   Logo
80 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
