Question about Toro Lawn Boy Self Propelled CARB Walk Power Mower
The self propeller is messed up. It sounds horrible. I might need parts for the gears.
    Novelist:
  • 111 Answers
On this mower it will probably need a new transmission assembly. If you replace the gears you may still have problems. The transmissions on the Toro product line, before 2009 have a bad tendency to go out. If the unit is still under warranty I would take it in and get it replaced. If you decide to do the work yourself it will take a while. If you provide a model number in the add comments section I can get you a parts breakdown, and maybe a parts manual for your model. Also if you get a new transmission assembly, take the four bolts off of the bottom and add grease yourself. We use high temp grease in the transmissions. Add the grease until the box is full then put the bolts back in. This will help it to stay working longer. Depending on which transmission you need, the price of an assembly is somewhere between 65 and 75 dollars. I've seen some of them go for over 100. It just depends on which one you need. I hope this helps.
Posted on Apr 07, 2011
Cub cadet 524. Why won't it propel itself and makes an awful ticking noise?
Sounds like the plastic gears in the self propelled gear box are stripped or out of mesh for some reason. The clicking is most likely the gears trying to mesh
Jan 24, 2016 | Garden
I have the Toro time master 30" self propelled. The self propel doesn't work. How do I fix it?
These are very expensive units, a little overpriced. If the self propelling system isn't working, see if the cable is actually disengaging the self propelling clutch, if it is and there is still no movement, the trans is shot and the way you fix that unfortunately is to buy a new transmission gear box. Save money and do it yourself if your kinda handy.... Go onto you tube, search for self propelling transmission replacement and you will have a few to choose from. If you are going to take it to a shop, be prepared to pass out when they give you the estimate for the parts and labor. Maybe you will get lucky and it's just the cable which is a very easy fix and the cable shouldn't run ya more than 20 to.25 bucks. BUT get a Toro part no aftermarket! !
Oct 04, 2015 | Toro Garden
Remove self propel gears and axle from Troy bilt push
Most of the self propelled mowers have a pin in them. you need to use a pin punch and a hammer to knock it through. The gears will come off then. Post a picture if need more info.
Sep 02, 2014 | Troy Bilt 5.5hp Self Propelled Mower
Why won't my 22 in. Kohler Low Wheel Variable Speed Self-Propelled Gas Lawn Mower self propel anymore?
i would guess that the belt is'nt tight enough when engaged. when you press the drive bar on the handle it should make the belt really tight if not it will need replaced. sometimes the gears in the wheels will mess up. there are videos on you tube that describe that and also the belt.
Apr 22, 2017 | Garden
Mower won't move
Judy sounds like an obstruction in the self propelled mechanism. Check underneath and make sure it's clear. If it's ok it may need a repair.
Jul 21, 2013 | Troy Bilt 5.5hp Self Propelled Mower
How do you remove the gears on a front wheel self propelled troy bilt push mower?
Take the front tires off, pull gears and take out pins, put tires back on and you have a "non-self propell" mower.
Apr 13, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Toro self propell is not working and making grinding sound
sounds like the gear case may be sticking or locked up. what you could be hearing is the plastic teeth inside the wheels getting chewed up. take the
cover off of the self propel assembly and try to clean it out. possibly grease it.
Aug 31, 2009 | Garden
Self Propelled mower quit self propelling
you probaly have a broken gear or engagment lever. the part the cable goes through before the cable goes thru the deck. you also could have sheared a pin or the plastic gear that drives it.
Jul 02, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Toro Lawn Boy Self Propelled CARB Walk Power Mower Logo
311 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
