Question about Proscan 32LB30QD 32 in. LCD TV
I have a Proscan 32LB30Q about 2 years old and and suddenly it will not turn on. I have tried to unplug it and then retry to no avail.
  • 592 Answers
Hi.
You are describing what has been happening all over the world lately.
There are several companies around the world that, about 10 years ago made around 10,000,000 defective parts, namely the capacitors.
These capacitors are junk, but the companies that made them put them all on the market anyways.
Now, most of them wound up in flat screen tv's and computer monitors.
The capacitors were supposed to last 25-30 years, as that is the life expectancy of the good versions of the parts.
However, the junk ones are only lasting anywhere from a few weeks to just a couple or three years.
About 1/10th of the time of what they should, that's why so many people are having this type of problem.
That's the good news, the bad news is that these capacitors are very expensive to replace with good ones, sometimes the repair cost can exceed the cost of a new tv.
When you take it in, I would just to get an estimate, due to the cost being so prohibitive.
There are a couple of places that have special techs trained to do the repair, one is Fry's electronics...and the other is Best Buy.
These two companies seem to be up to the task of doing the repair in a rather quick turn-around time.
Instead of dropping it off, and not getting it back for maybe a month, they can usually get you back up and going in 2-3 days.
I hope this helps you out, and feel free to give me a top rating if this tip helps you out.
Thanks !
Posted on Apr 07, 2011
I have a Proscan 32 in LCD Model # 32LB30Q . I had TV mounted base misplaced where can I order replacement base
You will have to order it from Proscan. The part# and web address should be in your owners manual.
Jul 14, 2011 | Proscan 32LB30QD 32 in. LCD TV
I NEED closed captioning on 32LB30Q. IS IT AVAILABLE?
You should have it within your Menu under Audio or Features. The rest will be up to the broadcast if it being sent in Closed Caption.
Nov 07, 2009 | Proscan 32LB30QD 32 in. LCD TV
Proscan 32lb30Q. I need to hook up wireless
You can buy a digital to analogue converter that connects to your COAX digital output and then connects to you RCA jacks. They run around $75. The only problem I've encountered is the DVD does not work through the COAX output, just TV. I'm looking into it.
Jul 01, 2009 | Proscan 32LB30QD 32 in. LCD TV
PLEASE HELP ME CONNECT MY DVD PLAYER TO MY NEW PROSCAN 32LB30Q.
Use either another HDMI cable (available at your local electronics store) or a component video and left/right audio cable to connect the two pieces together. The connections on the back panel of both pieces should be color coded and clearly marked.
Apr 10, 2009 | Televison & Video
Proscan 32LB30Q HDTV Just stopped working--1month old
This unit need to be taken to a service center to repair to be tested for component failure. The PROSCAN website for customer support is www.oncorpus.com. go to the customer support and find out where you can take your television for service. The PROSCAN customer support telephone number is. 1-888-977-6722. I hope this helps you with your problem.
Feb 26, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Remote code for a tivo remote
Ok I found it!  For the Proscan 32LB30Q from Costco, the 5-digit code for the Comcast remote is 00030, and the 4-digit code is 0030.
However, I still haven't found the code I need for the TiVo remote... but we're making progress.
Jan 31, 2009 | Proscan 32LA30Q Television
Proscan Tv is humming
This made my humming sound go away completely;
From JD at oncorpus.com [manufacturer of the 32LB30Q]
Please follow these instructions, should fix the hum issue:
1. Turn tv on
2. Input mode should be tv
3. Turn volume to zero
4. With remote enter 9 8 7 6
5. A menu will appear on left side
6. Arrow down to backlight and with right arrow key move number from 81 to 83, press menu button twice,
7. Turn up volume and listen if hum is gone.
John
Dec 15, 2008 | Proscan 32LA30Q Television
Proscan 32LB30QD 32 in. LCD TV Logo
346 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
