Question about Microsoft Windows XP Professional
Can anyone help me out please. I installed my new HDD and later i try to play my mp3 and other video files and i encounter this problems: volume controllers not enabled, files are not supported using the media players. I fo to Add hardware on control panel and find that the following devices needs drivers to be installed: Multimedia Audio Controller, SM Bus Controller, Video controller, Video Controller (VGA Compatible), Ethernet Controller. Do i have to download each drivers for the following devices stated above or is there a single driver that can enable all these devices? Please reply me through address "hopu.zulubravo@gmail.com". Thank you
    President:
  • Microsoft Master
  • 1,623 Answers
No there isnt a single driver and you will need to download them all individually, you will also have to identify what each device exactly is to determine the correct driver to download. Reply to this with make and model of computer
Posted on Apr 07, 2011
  • Martin Murray Apr 07, 2011
    in hindsight if you go herehttp://support.dell.com/support/download... a\nd eneter your tag number it will find the drivers for you
    Please take a minute to vote for me if you found this info useful
Samsung link the selected file is not currently supported
Hi
I have Samsung TV UE46ES8090 with which I use PC with Win7 b64 with Samsung link installed. Everything was fine up to some weeks a go, I was able to stream media files (mp3, images, video) from PC to TV without problems... Now for some time I am unable to do so and for any file that I choose to play on TV I get "the selected file is not currently supported". This msg is returned for any file (image, mp3, video...) I have tried to switch-off firewall and played with network setting etc but no luck. I am now only able to use USB to watch the same content which previously played over LAN.
If anyone has advice please post.
Sep 03, 2013 | Samsung UA55ES7100 Series 7 55 Inch 140cm...
My sandisk sansa clip mp3 player does not play songs/no sound.
I later found out that while trying to download more songs, the entire songs in my sandisk mp3 was corrupted by a virus. I solved the problem by formatting the device and thereafter downloaded new songs into it. As soon as I did that, the songs started playing normally at full volume.
Mar 06, 2009 | SanDisk Sansa Clip MP3 Player
No volume on downloaded videos
Hi!
Your PC might not have an appropriate audio decoder for your video files. You may try downloading and installing an MPEG-2 codec (such as this one http://www.softpedia.com/get/Multimedia/Video/Codec-Packs-Video-Codecs/Mpeg-AudioVideo-Filter.shtml) to get it working.
Hope this helps!
Nov 14, 2008 | JVC Everio GZ-MG360 HDD Camcorder
HDD with videofiles not working
I had the same problem on memory stick. If I have pictures only on memory stick it is working (pictures played in a slide show). After that I've try with a mixed CD (MP3 + pictures) and was the same problem - only MP3 played. I think KD AVX33 doesn't know to read both type of files at the same time.
Feb 26, 2008 | JVC KD-AVX33 Car Video Player
Philips HDD 6330/17, doesnt play music..
The rule for this device is first reset (hold power on/off and volume + simultaneously and continuosly while the player is turned on; reset works when the power turns off), and then Repair if that fails. The problem with Repair is that it deletes every file from the GoGear. Here are better instructions for repair than the manufacturer's:
1) Open up Philips Device Manager (Start --> All Programs --> Philips) - if you don't see it, then re-run the installation CD or grab the "Device/Firmware Manager" from the Philips website
2) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
3) Disconnect the GoGear from the computer and turn the GoGear off (if you haven't done so already) - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new.
-Tha Mp3 Doctor
Jan 11, 2008 | Philips GoGear HDD6330 MP3 Player
Windows media player won't allow me to sync files to my My Musix mp3 player....
This player doesn't play well with WMP-11. Try reformatting inside Windows Media Player, but this may not work. Other methods you can try:
MyMusix's PD-6030:
If you have a Windows-based computer,
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If that fails,
Check the battery polarity. (+ and - must be in correct psoition)
Set the hold button to the unlock position.
Check if the file system is NTFS. If yes ,format it to FAT or FAT32. - Connect player to computer, click my computer, right click on icon of mp3 player and select format
If that fails,
go to www.mymusix.com to see if the latest software update will correct the problem
-Tha Mp3 Doctor
Nov 03, 2007 | MyMusix PD-6030 MP3 Player
My RCA Lyra RD1072A just doesnt play songs
it freezes at the start menu just saying RCA and others times it plays a song and freezes when i turn the volume up or down can someone anyone help me please...thanx
May 16, 2007 | RCA Lyra RD1072 MP3 Player
HELP ME!!
Try upgrading to the latest firmware which is here http://files.creative.com/manualdn/Drivers/PDE/9147/0xAF48418C/MuVoN200_PCFW_LF_1_20_04.exe Then, press and hold the Play button while connecting your player to the USB port of your PC. This is connecting your V200 in what is called Recovery Mode. Keep pressing the Play button until the New Hardware Wizard starts. Complete the wizard. If it doesn't work, let me know. Later.
Aug 24, 2006 | Creative Labs MuVo V200 MP3 Player
Microsoft Windows XP Professional Logo
137 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
