Question about Sony Optiarc AD-7260S - DVDRW (R DL) / DVD-RAM drive - Serial ATA DVD±RW Dual Layer Burner
I have an Optiarc DVD RW AD 7260S which was working fine. Now, however when I double click on the shortcut, it just ejects the cd and says that I need to insert a cd. Help pls
  • Sony Master
  • 27,725 Answers
Make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on Apr 07, 2011
    Habit-Forming:
  • 73 Answers
The software driver might be damaged, reinstall and try using it againg.
Posted on Mar 25, 2015
Does not read or write dvd or cds
Let's start at step 1:
1: Is the drive listed in My Computer?
2: Have you checked the cables to insure they are plugged in firmly?
3: Has it always been this way or has it worked ok in the past?
Apr 03, 2014 | Sony Optiarc AD-7260S - DVDRW (R DL) /...
Unable to push Sony Optiarc AD-7585H to write at 1x
You're not "pushing" with 1x speed, that's the slowest speed at which a burner will burn at. You can change the write speed in the burning software settings.
Nov 09, 2013 | Sony Optiarc AD-7260S - DVDRW (R DL) /...
I cannot write to a CD-R at speed slower than ~8x
It should be 100% reliable at 8X if you use Verfy at the end of the burn. If that does not work for you because you have a special application that only accepts CDs burned at 1X, then you might have to buy an old PC with an old CD burner in it, then keep that equipment around to support your application.
Sony AD-7260S does not write or read Dual Layer DVDs
i think your drive Lens is weak that reason your disk is not read or write
Sep 08, 2011 | Sony Optiarc AD-7260S - DVDRW (R DL) /...
Driver Sony Optiarc AD 7260 ATA
This post is not a question. There is nothing to answer.
May 18, 2011 | Sony Optiarc AD-7260S - DVDRW (R DL) /...
I installed the new cd/dvd driver, but the compter won't install it.
If this is the only drive on your PC you have to make sure that you have set up the jumper to master. the jumper is located in the back of the drive. you must also install the driver for the drive to work properly.
Feb 28, 2011 | Sony Optiarc AD-7260S - DVDRW (R DL) /...
Hi, My Optiarc DVD RW AD 7530B doesnt read or play DVDS or CDs. it has power but when you click on E drive, an error comes up, that there is no disc
hey gues... we have some problem about my dvd/cd rewritable Drives model AD-7530B . it's my note book HP 520 can detect disk drive , but can not work anything . could you help me and give me information . how i can solution this problem ?... thank's
Jan 26, 2010 | Sony NEC Optiarc AD-7530B 8x DVD?±RW DL...
Laptop Optiarc DVD RW AD 7530 B is not reading CD or DVD media. 1.DVD icon displayed in My Computer. 2.When I insert DVD or Cd in the drive,Green light flashes and tries to read the nedia and goes off...
2.When I insert DVD or Cd in the drive,Green light flashes and tries to read the nedia and goes off within few seconds.
3.DVD drive in My Computer when clicked shows empty folder
4.Uninstalled DVD drivers in Device Manager and let windows find it on reboot
5.Issue still persists.
6.Right now external DVD RW works perfect.
Please help
Oct 29, 2009 | Sony NEC Optiarc AD-7530B 8x DVD?±RW DL...
Sony Optiarc AD-7260S - DVDRW (R DL) / DVD-RAM drive - Serial ATA DVD±RW Dual Layer Burner Logo
1,746 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
