Question about AOpen (MX4SGI4DN2PRE) Motherboard
I have a Aopen motherboard. The power is coming thru. And the hard drive is powered up. However, its not giving any bios information of the black screen. That means it is not booting at all. There is not even a beep sound. Thanks Alsha'im
  • AOpen Master
  • 27,725 Answers
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
Posted on Apr 07, 2011
I have a rebuilt computer with various parts, when it would boot up it would just come to a black screen where I could see my muse and move it but only had a black screen. I was told to unplug everything...
test all leads that attach to your hard drive including electrical extensions SATA
the leads from your ((motherboard to your hard drive)) Sata make sure they have a secure connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause this problem
a computer needs all of the data and electrical current to travel through every working device and to have an end for a computer to be able work properly
make sure your graphics card is securely seated with no dust in its socket
if you physically remove your graphics to check the socket card restart your computer this should activate found new hardware wizard
hope this helps
Sep 19, 2011 | AOpen AX4SG-UN Motherboard
Anyone know what the manufacturers MINIMUM psu requirements are for the AOpen AK77-8XN motherboard? No such info on the global aopen site! My previous psu was 300w. Trying to test with an old but working...
It actually depends what you are all hooking up to it. In my experience, if you just have a hard drive, cd/dvd drive and thats it, a 250 would power it up. I would recommend a decent 300-400 watt PSU if you plan on putting anything more than a hard drive and dvd drive in it. But for testing purposes, a 250 watt should do the job. I don't know about a motherboards minimum requirements though, depends on the CPU, Memory, # of fans etc. that you have.
Feb 15, 2010 | AOpen AK77-8XN Motherboard
Hello, I have problems with a computer. It seems
I need more information but, it sounds like either the jumpers are NOT set right on the hdd. Is this an IDE or SATA drive? Have you checked the BIOS settings?
Dec 30, 2009 | AOpen AX4B-533 Motherboard
Acer Aspire 5100 problem
You don't want to hear this I know, but your symptoms are very much like those of a computer in which the motherboard or processor has died. It is defnitely not the hard drive as you would still get a display and be allowed to go into Bios even if the hard drive was totally out of the computer. And missing memory would result in bios beeps indicating a faulty bios configuration, but all of that requires that the motherboard and processor be good. If they are not, you have the situation you are speaking about.
Aug 25, 2008 | Acer AOpen AX4BS-V (91.89J11.001)...
Power up problems
To enter setup (Refering to the bios/cmos), press the Delete key very two seconds untill the bios main menu loads. You need to go to the menu heading - Boot.
If you added another hard drive to you're system the IDE (hard drive) it's jumper settings may not be correctly set. If there are now two IDE drives both the primary master & secondary drive's jumpers must be set correctly. You will ned to look at the white sticker on the drive for the correct jumper settings. Many primary IDE drives pin jumper is set as a single master drive with out a secondayr drive attached in the system. When you add a second drive the pin jumper one the master drive will most likely need to be changed to master with a slave. The second drive will also need it's jumper set as a slave drive. Once this has been adjusted you need to enter the bios & make sure you're primary master drive is set in the boot order. Most PC's boot order is as follows.
1st Boot device, floppy drive. (If one is connected to the system).
2nd boot device, CD-ROM drive.
3rd boot device, master IDE drive.
Please use the help of you're manual to guide you for these settings.
AOpen MX46L web site. http://download.aopen.com.tw/Default.aspx
You must set the three drop down menu's to get you're board's drivers & manual. In the first menu choose motherboard, in the second menu choose MX46L & in the last menu choose manual. For drivers, the third menu choose drivers.
Still heave more questions? Just ask.
Mike
May 18, 2008 | AOpen MX46L Motherboard
Aopen help
It's very possible that while you were swapping out the dvd-rom you in bumped other data cables & power cables to other devices, just enough to cause the bios not to see them. Re-check all connectors & power cables. Start the system. Still no windows? Enter the bios make sure your devices are showing up. Like your hard drive floppy & dvd-rom. If you have to pull the cables off & reconnect them.
Jan 23, 2008 | AOpen MX46-533V (91.89U10.061) Motherboard
Mx45 u2-cn motherboard
Your not getting any video at boot up? I would be looking at your video card first. Remove & reinstall. Than try again to enter bios. Still no? Reset the bios on the motherboard. You'll have to remove the battery & check it for 3volt. Replace, got video enough to enter bios? Disconnect all non needed items. Like diconnect CD/DVD rom drives power cable & data cable. Got two Hard drives. Connect only one. Two banks of dimms. Use only one. 1PS2 mouse & keyboard. Try boot up again. Listen for post beep. (1 beep). Any other beeps, count how many and if long or short. Let me know. Lastly did you apply thermal grease between the cpu & heatsink?. The idea here is to get down to basic needs only. If it were your cpu it wouldn't even power up. Than again every board is a bit differant. Give this all a try & poat back. Good luck!
Jan 15, 2008 | Computers & Internet
Hard drive shuts off?? I think.
replace your power supply, you need to upgrade this to at least 500watts to avoid problem like this, there is no problem with your hard drive its your power supply
Dec 11, 2007 | AOpen AX45-V (91.88I10.004) Motherboard
Boot problem
check the bios for video option.
Nov 11, 2007 | AOpen AX34-U Motherboard
Computer won't power up
the wiring isnt the problem i dont think, as the system wouldnt have started in the first place, the message would have read NTLDR not found, this means that the processor cannot find the system files to load windows and that there is either a hard drive fault or a system fault. If you can get into the bios you need to change the first boot device to cdrom and start the system up using your XP disc and do a system repair.
Aug 24, 2007 | AOpen s760GXm-US Motherboard
AOpen (MX4SGI4DN2PRE) Motherboard Logo
47 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
