Question about Tomtom XL 340S Car GPS Receiver
I think my screen needs calibration. i left under the hot sun and the screen is impossible to click the right choice especially the upper part of the screen . please help
    President:
  • 1,623 Answers
I would say you will need more than calibration , you will probably need a new touch screen. The hot sun has probably distorted the touch screen which is why it no longer responds correctly
Posted on Apr 07, 2011
Testimonial: "I agree with you"
How do I make it go full screen
There is going to be a setting in your television menu under display or video. You will have multiple choices and the most effective is automatically select but the second choice would be Cinerama.
Jan 26, 2016 | Televison & Video
I have a Garmin Nuvi 255 GPS and the touch screen will not respond to touch, How do i fix?
Try recalibrating the screen with this procedure. If you can not calibrate the screen, then the touchscreen will need to be replaced.
Nuvi 2xx/2xxW Series: Turn the Nuvi off. Place your finger on the upper left-hand corner of the screen and then slide the on/off power switch to the left and hold until you see the calibration screen.
Touchscreen information here: SHARCNET USA Out of Warranty GPS Digital Camera Repair
Jan 28, 2015 | Garmin Nuvi 255 Car GPS Receiver
How to calibrae my gps nuvi garmin 255????????????????
For the Garmin 2x5 series GPS
Calibrating the Screen:
1. Turn off the nüvi.
2. Hold the upper-left comer of the screen white turning on the nüvi
3. Release the power key when the Garmin screen appears.
4. Continue to hold the upper-left corner of the touch screen for 30 seconds until a white screen with "Press dot" appears.
Here are links to the manual for both the 255 and the 255W (wide).
I hope helped & good luck! Please rate my reply. Thank you.
Jun 30, 2011 | Garmin nuvi 255W GPS Receiver
I have a tcm 217362 watch with a digital compass how can i set it up to show me north it currently shows cal. and when i press the top right and left button it shows err.(probably error) it is a black and...
Hi john30x,
You have to calibrate the compass.
1. Press the upper right button (switching to compass mode)
2. Press and hold upper left button. The "CALL" will appear on the display. You are in compass calibrating mode.
3. Rotate the watch horizontally (around his vertical axis) slowly, so to be sure that he point the North at least 2 times.
4. Now press the upper left button again to input the
declination (this is the angle between the magnetic and real pole). It is different for the area around the world, that you want to explore.
5. Switch between the positions of the cipher by pressing bottom left.
6. Change the cipher by pressing bottom right.
7.
Switch between the active position by pressing bottom left. Now you have to enter East or West declination
8. If you are ready press the upper left. "END" of calibration will appear on the screen
Once you calibrate and set the declination you can use the the compass by pressing upper right button. As the compass is very sensitive It is good idea to calibrate it on a field, far away of metal objects and electromagnetic fields (cables, ect.). You need to calibrate the compass each time you want to use it by different surrounding.
Remember the compass function of your watch need much more energy than the watch itself. Don`t worry to change the battery when dead. The water resistance remains good even after. Very robust and accurate device. I hope that should help.
May 15, 2011 | Watches
How do I correct distorted screen saver pictures?
You will need to ensure you have the latest drivers for your graphics card. Try the following:
1. Right-click your desktop and select "Screen Resolution"
2. Click "Advanced settings"
3. On the Adapter tab, click "Properties"
4. On the Driver tab, click "Update Driver"
If this doesn't work, try using the color calibration tool.
1. Right-click your desktop and select "Personalize"
2. On the bottom left, under See Also, select "Display"
3. On the left, click "Calibrate color"
4. Click "Next" in the bottom right corner and follow the instructions
Mar 11, 2011 | Microsoft Windows XP Professional
I need to calibrate my Garmin Nuvi 1260T. It's been alittle off ever since I got it. I tried holding the power button for 30 seconds and waiting until the calibration screen pops up but nothing pops up. ...
In order to calibrate the screen on the Nuvi 1260T, you need to follow these few simple steps.
- Turn off the device
- Hold the upper-left corner of the screen while turning on the device
- Release the power button when the Garmin screen appears
- Continue to hold the upper-left corner of the touch screen for 30 seconds until a white screen with "Press dot" appears.
This should allow you to calibrate the screen. I hope this helps!
Mar 01, 2011 | Garmin nvi 1260T 35 in Car GPS Receiver
I have leapster l-max and am having trouble with the stylus working. when i try to calibrate, i can't click on center targets
Leapster L-Max recalibrates differently. I was trying to use the instructions and it kept asking for a blue button. For the Leapster L-Max push B, A, Hint, and Home when you turn it on. Do not have a cartridge in the player or it will think it is a regular Leapster. Once it says calibrate screen it will say to press A, then wait until a target appears in the upper left hand corner, touch it and you should hear a sound, then a new target appears in the lower left hand, repeat actions, then lower right hand screen, and finally the upper right hand screen. If it stops at any time and doesn't get more arrows, try it again or turn it off and see if the pen works. It may take several times to get it working again.
Feb 05, 2011 | LeapFrog LeapSter L-Max Console
When my daughter touches any object with the pen nothing happens. It will keep telling you to touch a picture on the screen with your pen.
You need to recalibrate. Try pushing B, A, Hint, and Home when you turn it on. Do not have a cartridge in the player or it will think it is a regular Leapster. Once it says calibrate screen it will say to press A, then wait until a target appears in the upper left hand corner, touch it and you should hear a sound, then a new target appears in the lower left hand, repeat actions, then lower right hand screen, and finally the upper right hand screen. If it stops at any time and doesn't get more arrows, try it again or turn it off and see if the pen works. It may take a few tries to get it to recalibrate correctly.
Jan 05, 2011 | LeapFrog LeapSter L-Max Console
The desktop is default blue and will not change. What do I do?
OK !..Go to the apple in the upper left hand corner. Scroll down to System Preferences.Open it. On the first line is something called Desktop and Screensaver. click on that to open. On you left you have many choices. images from Apple. Click on a category images come to box to the right. Select one and it will automatically change your screen picture. You will see your picture choice above the left column of screen choices. You can also chose photos from your desktop from that folder. Ask again if needed more info!
Apr 05, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
I just got a garman nuvi gps 200 and it is all new to me some how I need to change the language back to english. Can you help tks.
Turn Garmin ON.
Click on TOOLS(bottom right corner)
Click on Settings (upper left corner)
Scroll down arrow (right bottom of screen)
Click on Red Lips Language (upper left corner)
YOUR CHOICES ARE HERE,
Voice :American English,
Text:American English
Key Board :American English
Hope it helped you.
m.k.
Dec 27, 2008 | Garmin nuvi 200W GPS Receiver
Tomtom XL 340S Car GPS Receiver Logo
596 people viewed this question
Top Tomtom GPS Experts
k24674
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
